Old Jan 17, 2007, 06:58 PM
racin06 is offline
Find More Posts by racin06
United States, IN, Indianapolis
Joined Dec 2006
Tail rotor housing is turning on tail boom.
I noticed while flying tail-in that the tail rotor housing (and of course the tail rotor and motor) had turned counter clockwise a bit on the tail boom. After further inspection, I discovered that the tail rotor housing was somewhat loose and was turning freely on the tail boom. I tightened the two screws on each side of the metal tail rotor gear, but the tail rotor housing still is able to be turned by hand. First of all, should the tail rotor housing be able to turn like that? Secondly, if not, any answers on how to tighten the tail rotor housing to keep from turning? Thanks.
racin06 is offline Find More Posts by racin06
Old Jan 17, 2007, 07:03 PM
Spongebob is offline
Find More Posts by Spongebob
Spongebob's Avatar
Chicago O, Illinois, United States
Joined Jan 2003
It should not happen, because those come pre-glued to the boom. If you can, desolder the motor wires (don't lose them inside the boom or cut them however!) and remove the housing completely. Spread a small amount of CA over the entire contact area, and push the housing back on. Be 100% sure that it is going on vertically, however, because it will be near impossible to remove it after this.
Sponge
Spongebob is offline Find More Posts by Spongebob
Old Jan 17, 2007, 07:04 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Which heli do you have?
If it's a Honey Bee (or similar) the plastic tail rotor housing is glued to the tail boom. It is possible for it to break free and rotate. It should NOT rotate! A drop of thin CA (superglue) should fix it.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Jan 17, 2007, 07:09 PM
SCORP27 is offline
Find More Posts by SCORP27
Joined Nov 2005
just becareful with the CA and not glue the motor wires to the inside of the boom or the motor housing. That would make it extremely hard to replace a tailboom if you had to.
SCORP27 is offline Find More Posts by SCORP27
Old Jan 17, 2007, 07:16 PM
racin06 is offline
Joined Dec 2006
I have the HB FP. I also just noticed that the two screws in which I was talking about are used to secure the tail motor to the housing. Boy do I feel really dumb! Anyway, thanks again and I will use some CA to fix the problem.
Old Jan 17, 2007, 07:35 PM
racin06 is offline
Joined Dec 2006
I was able to pull the tail rotor housing to the rear about a 1/8". I applied a drop of CA, then pushed forward and squared things up. Worked like a charm. Oh I forgot to mention how the housing became loose. I've been working on my nose-in hovering and I got a little close to the concrete wall in my basement while attempting to do some pirouettes from the nose-in orientation. I'm still having a great time with my HB FP!
Sorry Chris, I thought I posted this in the Honey Bee FP thread. I just noticed that I started an entire different thread. Now, I see why you asked which heli I had.
Old Jan 17, 2007, 08:41 PM
Austin, TX
Joined Sep 2005
No worries, I'm glad you got it fixed!
-Chris
Discussion Rear tail rotor housing HBFP Norm66 Micro Helis 4 May 30, 2007 10:21 AM
Discussion Using a Tail Rotor for Rudder on a Plane?? Butch777 Scratchbuilt Indoor and Micro Models 3 Nov 15, 2006 08:47 PM
Discussion Trex tail rotor housing fit nawk Mini Helis 2 Dec 29, 2005 11:09 AM
F/S- Tail Rotor Drive Wire Corona Short Boom Funzy Aircraft - Electric - Airplanes (FS/W) 0 Apr 15, 2003 06:14 PM
Tail Rotor Push Rod on your Corona / LMH ? Kevin Murray Electric Heli Talk 5 Jan 23, 2002 01:24 AM
