Old Jan 16, 2007, 11:13 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Min safe voltage for 7.4V lipos?
Whats the minimum safe voltage you can drop a 7.4V lipo down to? Specifically I'm looking at the Stormlauncher and XPV lipos. Will they handle 5V and charge again with no issues? Thanks for the info.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jan 17, 2007, 06:47 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
You can run them down to 2.7V per cell (5.4V for a two cell) but you really should not. The deeper(lower) you discharge them then few number of cycles they will last.
If you use this link and take a few minutes to study post you should develop a better understanding.
http://www.rcgroups.com/forums/showp...68&postcount=1
Old Jan 17, 2007, 12:59 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
and also longer time to restore the low Z ( impedance) if discharged too low
hall woo is offline Find More Posts by hall woo
Old Jan 17, 2007, 11:15 PM
Evansville, WI
Joined Dec 2006
Thanks for the info. Looks like 6V would be a safe cutoff for a 7.4 and still be above the 80% mark(although barely).
Old Jan 18, 2007, 07:14 AM
Southern Pride
If you came to that conclusion after using the link and studing the graph then you are mis reading the data.
At 3.2V V per celll under load the cell is approx. 95% depleted.. 1300*80%= appro. 1000 mAh and that amount apacity had been used when the test packs were at 10.5V (3.5V per celll under load).
In fact if you look at the Graph closely at 10.5V (3S pack) 1100 mAh had been discharged so in fact the pack was 84% discharged at this stage.
With 12C cont. and greater LiPolys any cut off below 3.2V per cell is really very risky.
How to read a CBA Graph
http://www.rcgroups.com/forums/showp...89&postcount=2
Charles
Old Jan 18, 2007, 11:50 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
I too have a hard time understanding what hal woo is talking about. I may be putting words in his mouth (if so I hope he corrects me) but I think what he means by voltage clamp is a charging circuit that has a fixed voltage but a current limiting circuit to prevent over current when charging a fully discharge battery. If so this is usually know as a "Limited Current/ Constant Voltage" device.
Rodney is offline Find More Posts by Rodney
For Sale NIP E-POWER 20C 2s 540mah 7.4v Lipos punkindrublik Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 18, 2007 01:52 PM
Discussion Safe voltage for GWS edf motor? Fallout Power Systems 7 May 05, 2007 11:10 AM
Off Site NEW ELECTRIC POWER 20-30C 2S 7.4v Lipos - E-Power punkindrublik Aircraft - Electric - Batteries & Chargers (FS/W) 3 Aug 03, 2006 02:04 PM
MM Flashback on 2S (7.4V) lipos and Himaxx 2025 markusj Parkflyers 4 Nov 30, 2005 02:59 PM
ESC for 7.4V Li-ion battery hty Batteries and Chargers 1 Apr 26, 2004 02:31 AM
