This thread is privately moderated by bmwbob, who may elect to delete unwanted replies.
Old Sep 22, 2002, 01:22 PM
bmwbob is offline
Find More Posts by bmwbob
Trader Rating: 8
Cocoa, Florida
Joined Dec 2001
Trader Rating: 8
WTB: Power plant for "Jerry"
No one bought my Jerry kit, so I want a suitable drive train for it.
I'm thinking a geared Hacker setup, but am open to any other suggestions, especially if someone has some info on those new rotating can direct drive motors like the AXI's.
Also, if not personal property being offered, any sources for the best prices on what you suggest would be appreciated.
Thanks!
Bob Cowgill
Cocoa, Florida
E-mail:rcowgill@cfl.rr.com
bmwbob is offline Find More Posts by bmwbob
Old Sep 22, 2002, 04:21 PM
amapmfg is offline
Find More Posts by amapmfg
Trader Rating: 35
amapmfg's Avatar
United States, CA, Pleasant Hill
Joined Dec 2001
Trader Rating: 35
Jerry
Jerry flys best at 50amps with 14.4x9.5 prop wont stand low power my best set up was late ver FAI 15 astro 4.4:1 planet on 12 zapped 4/5 2400 same size and weight as cp1700 .tip stalls big time George
amapmfg is offline Find More Posts by amapmfg
Old Sep 22, 2002, 04:58 PM
bmwbob is offline
Trader Rating: 8
Cocoa, Florida
Joined Dec 2001
Trader Rating: 8
Jerry power plant
I've been wringing out Motocalc, and without going into the B50 series Hackers, the best thing I could come up with was a B40-9L with 4.4:1 gearbox, swinging a 14 X 8 or 14 X 9.5 prop on 10 zapped CP1700's. Current, run time, wing loading and climb rate all look pretty good.
The 10 RC2400's looked good on paper, but I'm not sure if I could squeeze 'em in the plane.
Just for grins, I used my digital scale and weighed all of the Jerry components. They came out just under 28 oz.
Curiously enough, there is over 1/4 oz. difference in the weight of the two wing panels!
I'll be using a carbon wing joiner, so that saves a couple of ounces over the steel one that comes with the kit.
So, unless someone has a better idea, I'll probably go after the B40-9L setup.
I understand that your setup may be a bit heavier than the one I am planning, and I wonder if that is part of the cause of the tip stalls?
Doesn't make any sense to ME, but then I'm no aeronautical engynear/enemageer/imbeceer/....Whatever! :-)
Bob Cowgill
Cocoa, Florida
Old Sep 23, 2002, 06:06 AM
bmwbob is offline
Trader Rating: 8
Cocoa, Florida
Joined Dec 2001
Trader Rating: 8
No AXI for the Jerry!
A fellow just sent me the data on the AXI motors that are available. It looks like they are all too small.
So, I'm back to seeking the Hacker B40-9L with the 4.4:1 gearbox
unless I decide to go with the slight overkill Aveox setup I've been offered.
Whatcha got out there???
Bob Cowgill
Cocoa, Florida
E-mail: rcowgill@cfl.rr.com
Old Sep 23, 2002, 12:35 PM
kaboom is offline
Find More Posts by kaboom
Trader Rating: 0
Brampton, Canada
Joined Jun 2002
Trader Rating: 0
Power plant for jerry
A couple of things about the jerry I have learned.
10 rc2400 cells fit in fuse fine without any problems (two sticks of 5 cells side by side). some guys have put 16 cells in this thing.
I have found as have others on this site (do a search in electric flight sailplanes) that it flies fine if its heavy. mine is around 76 oz. (10 rc2400 + hacker b50-7S F5F) and with this setup is the fastest climbing plane at my field by a wide margin.
kaboom is offline Find More Posts by kaboom
Old Sep 23, 2002, 12:59 PM
Steven Horney is offline
Find More Posts by Steven Horney
Trader Rating: 4
Steven Horney's Avatar
Joined Jan 1999
Trader Rating: 4
You shouldn't have any problem fitting fairly high cell counts into the Jerry. I've always flown mine on either 14 or 16 2400 cells (2 packs of 7 or 8 cells, respectively). My plane was powered by either a Jeti 30-3, 11x6 prop, and 14 cells, or a Jeti 45/3, 16 cells, and 13x7 prop. Current draw was 55 amps with the 30-3, 50 amps with the 45/3. Climb is near vertical to vertical (depending on which setup), with plenty of speed. Use a fair amount of aileron differential for improved turning. It will tip stall, but it's not usually much of a problem unless you get it real low and slow. This plane generally likes to be flown fairly fast. Mine weighs 89 oz with 16 cells and the 45/3.
Steve
Steven Horney is offline Find More Posts by Steven Horney
Old Sep 27, 2002, 02:18 PM
gavoss is offline
Find More Posts by gavoss
Trader Rating: 125
gavoss's Avatar
USA, OK, Oklahoma City
Joined Mar 2001
Trader Rating: 125
Brushless motor for Jerry
Bob, I have a Phasor 45/3 and Jeti 70P3 for $200. email me direct if interested.
gavoss@swbell.net
gavoss is offline Find More Posts by gavoss
Old Sep 27, 2002, 02:36 PM
Atindra is offline
Find More Posts by Atindra
Trader Rating: 187
Balsa Snob - Mostly
United States, PA, Riegelsville
Joined Jul 2001
Trader Rating: 187
And I have the Jerry motor/ESC as well
I have a NIB Phasor 45/3 and a used Jeti 70P listed in Sale/Wanted for ... let's see now... $125 + $80 shipped.
Atindra.
Atindra is offline Find More Posts by Atindra
Old Sep 27, 2002, 02:50 PM
gavoss is offline
Trader Rating: 125
gavoss's Avatar
Joined Mar 2001
Trader Rating: 125
Jerry
Atindra, how much are you selling your motor/SC combo for?
Old Sep 27, 2002, 02:53 PM
Atindra is offline
Trader Rating: 187
Balsa Snob - Mostly
Joined Jul 2001
Trader Rating: 187
Hi George,
Right now they are listed seperately.. NIB 45/3 $125 shipped
Jeti 70-3P White label $80 shipped.
Regards,
Atindra.
Sorry to do this on your thread bmwbob !
Old Sep 27, 2002, 02:54 PM
bmwbob is offline
Trader Rating: 8
Cocoa, Florida
Joined Dec 2001
Trader Rating: 8
45/3
Guys,
Thanks for the offers on the Phasor motors!
I'm going for the geared, lower cell count type setup.
BTW, wen I was selling a bunch of stuff for my buddy a couple of months ago, I sold a NIB 45/3 for $90 shipped! :-(
Bob
Old Sep 27, 2002, 02:56 PM
gavoss is offline
Trader Rating: 125
gavoss's Avatar
Joined Mar 2001
Trader Rating: 125
Agreement!
Well, it looks like we agree on what they are worth. ;-)
Old Sep 27, 2002, 03:01 PM
Atindra is offline
Trader Rating: 187
Balsa Snob - Mostly
Joined Jul 2001
Trader Rating: 187
Uh-uh, price revision pending !
WTB power setup for park flyer budorren Aircraft - Electric - Airplanes (FS/W) 3 Jul 10, 2004 12:04 AM
Power systems for new 40" Super Cub Adrian Page Power Systems 2 Jul 02, 2004 05:18 PM
WTB: prop adapter for "Zagi" props for 2mm motor shaft JohnM Aircraft - Electric - Airplanes (FS/W) 4 Dec 18, 2003 09:52 PM
Power plant for big lazy bee with extended wing Gumby007 Sport Planes 3 May 02, 2002 02:43 PM
Power plant for Silent Dream Amigoone Electric Sailplanes 3 Dec 26, 2001 01:25 PM
