Old Jan 15, 2007, 12:04 PM
shemy is offline
Find More Posts by shemy
Joined Jul 2006
How deep does a one of these Submarines go?
Well as the title says, how deep do these submarines go and how do they stay under there? Thanktoy.
shemy is offline Find More Posts by shemy
Old Jan 15, 2007, 05:42 PM
CG Bob is online now
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
All the way to the bottom. The models are usually run at depths of 3-5 feet (1-1.5 meters) in most cases. The chlorine and other chemicals in swimming pools reflect the radio waves at depths of 3-5 feet; below that depth, the subsafe (failsafe device) - if installed - will blow the ballast tank and send the boat to the surface.
If the question is "how long do they stay under; the answer is a long time, much longer than the batteries will last if you have a major malfunction. Operating time depends on the Ah (or MAh) rating of the battery, generally speaking 100 MAh = 1 minute of operating time.
If the question is really "how do they dive" the answer varies. Dynamic diving models rely on forward speed and the dive planes to dive. Dynamic divers have a minimum hull speed, slow down below that speed and the sub will slowy surface. Static diving subs have a working ballast tank and use several different methods to flodd and empty the tank. Reversible pumps are used in some models, with the periscope acting as an air vent. Some boats use compressed gas (usually air brush propellant) to blow the ballast water out of the tank. These gas boats have a separate vent at the top of the ballast tank that opens to let water in. Some boats use a piston assembly, much like a hypodermic syringe. Other boats use a blood pressure cuff inside the ballast tank to displace the water.
CG Bob is online now Find More Posts by CG Bob
Question How Much Does One Emoly Cell Weigh? wannabe Power Systems 2 Jun 12, 2006 12:47 AM
Does one of these work very well for cutting foam? Jim_W Foamies (Kits) 8 Nov 30, 2005 10:36 AM
Wanted how much would one of these sell for?? Eeeeky Aircraft - Electric - Helis (FS/W) 17 Sep 16, 2005 08:01 PM
How does one go converting a Wing to brushless? ScYcS Flying Wings 5 Jun 13, 2004 09:26 PM
