Old Jan 15, 2007, 07:56 AM
DaleM is offline
Find More Posts by DaleM
Dale Lindsay
Mt Airy, Maryland, United States
Joined Sep 2001
CX2 motor sounds strange
I noticed here recently that the upper rotor motor has started making a strange noise in the midrange. It's the speed about what it takes to hover at eye level. When coming off the throttle the motor makes a buzzing noise. When under load (as in throttle up to climb) the sound stops for a moment and eventually comes back once the load has lessened. It also seems to affect the gyro somewhat as I get a slight nose left twitch as I throttle down.
When holding the CX2 and powering up with right rudder I can get the sound. I've checked the linkage, nothing is binding, etc. Is this a sign that the brushes/bushings are already going out? I've had this since Christmas and fly a good bit, but not excessive and let things cool down between flights.
Just curious if anyone else has experienced the same noise.
DaleM is offline Find More Posts by DaleM
Old Jan 15, 2007, 08:20 AM
Rob Hair is offline
Find More Posts by Rob Hair
Michigan
Joined Apr 2001
Have you checked to see that the motor mounting screws are tight?
Rob Hair is offline Find More Posts by Rob Hair
Old Jan 15, 2007, 08:37 AM
DaleM is offline
Dale Lindsay
Joined Sep 2001
Yes, I checked the screws and made sure the gear lash didn't seem tight by 'slightly' loosening them and then retightened.
Old Jan 15, 2007, 02:22 PM
venomoussvt is offline
Find More Posts by venomoussvt
Joined Dec 2006
mine was making a similar sound.... I took the lower gear out and removed the inner shaft. Checked everything and put it back in being careful to pay attention to detail as I put it back together. It stippoed after that. I am not sure exactly what the issue was but I think when I installed my aluminum inner shaft and aluminum bearing I didnt line the keyway up with the screw at the base of the shaft where the gear goes on. I think it was trying to spin freely and was skipping over that keyway making a grinding noise.
venomoussvt is offline Find More Posts by venomoussvt
Old Jan 15, 2007, 06:24 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Joined Dec 2005
Tough to say, but a source for some noise can be found in the two screws that retain the lower rotor head to the outer shaft. In some cases the screws will protrude far enough into the inner shaft that they will be touched by the spinning inner shaft. This is particularly so if the inner shaft has a slight bend to it.
If you are confident that the mechanics are good, you can try reversing the motors to see if the noise moves with the motor. These are brushed motors and as the brushes wear they tend to change their 'sound'.
Lou is offline Find More Posts by Lou
Alert Brushless motor sounds strange, please help! D-Man Electric Plane Talk 3 Aug 08, 2005 01:06 PM
Question Brushless motor sounds strange...again D-Man Electric Plane Talk 0 Aug 07, 2005 07:42 AM
electric motor sounds like it is missing agriebel Power Systems 1 Aug 24, 2003 01:07 PM
Brushless Motor Acting Strange fly4fun Power Systems 20 May 27, 2003 10:00 AM
Motor sounds like a squealing pig. Balin Power Systems 4 May 04, 2001 11:27 PM
