Old Jan 15, 2007, 07:06 AM
capecoral is offline
Find More Posts by capecoral
United States, FL, Cape Coral
Joined May 2006
Question
Motor question 5turn VS 6 turn DUALSKY ?
First I am looking at a .46-.50 size motor 1 is 5turn and the other 6 what is the differance??? second the motor is a dualsky unit are they good? or any suggestions for a good affordable .46 size? Thanks for the help Joe.
capecoral is offline Find More Posts by capecoral
Old Jan 15, 2007, 08:05 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I've tested a couple of smaller Dualskys and they are good. The main difference between 5T and 6T is that the 6T can run a larger prop. The 5T may be able to take a bit more current, and can be used to spin a smaller prop faster.
I see your problem - on the 2DogRC website they have the same info for both motors! The 5T will be higher Kv than the 6T but what those Kv's are I don't know - maybe the 5T is 840?? If so perhaps the 6T might be 760 or so???
Dr Kiwi is offline Find More Posts by Dr Kiwi
Discussion Motor Question - Medusa vs. Mega Abrams Flying Wings 30 Jan 19, 2007 09:31 PM
Astro 020 6 turn pylon motor dwatkins Aircraft - Electric - Airplanes (FS/W) 2 Dec 26, 2001 01:23 PM
Astro 020 6 turn pylon motor dwatkins Aircraft - Electric - Airplanes (FS/W) 0 Dec 25, 2001 09:05 PM
Astro 020 6 turn pylon motor dwatkins Aircraft - Electric - Airplanes (FS/W) 2 Dec 23, 2001 09:40 PM
Promax (MPI) 05 6 turn motor dr.E Aircraft - Electric - Airplanes (FS/W) 0 Dec 10, 2001 12:43 PM
