Old Jan 13, 2007, 08:25 PM
flyingvranch is offline
Find More Posts by flyingvranch
Will fly for food...
flyingvranch's Avatar
Huntsville, Texas USA
Joined Aug 2005
Do you need to cycle NiMh batteries?
I've heard conflicting stories. What's the real deal?
Thanks!
flyingvranch is offline Find More Posts by flyingvranch
Old Jan 13, 2007, 08:47 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The real deal it depends on the batteries and thier useage.
Old Jan 13, 2007, 09:12 PM
roosevelt is offline
Find More Posts by roosevelt
Make 'n Break!!
roosevelt's Avatar
Walled 'tucky, MI. USA
Joined Apr 2006
If mine seem weak I cycle em 2 or 3 times at a low setting. 1/2c or less. It seems to help
roosevelt is offline Find More Posts by roosevelt
Old Jan 14, 2007, 02:14 AM
GoLikeaFish is offline
Find More Posts by GoLikeaFish
The BA
Joined Oct 2006
What about brand new? I've been told to cycle the batteries 10 times before using for the first time.
GoLikeaFish is offline Find More Posts by GoLikeaFish
Old Jan 14, 2007, 03:29 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No need for cycling but it is not a bad idea for the first few charges to be at a slow rate around C/10. You can still charge then fly, just don't fast charge immediately.
Even that is not strictly necessary. I have NiMH batteries which were fast charged from day 1, have never been cycled and are still going well 4-5 years later. As "everydayflyer" says it depends on exactly what batteries you have.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 14, 2007, 05:47 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
... on the other hand, my GP3300s would not take a charge initially (at 1C) until I gave them a 1/10C 12-hour charge. Maybe 1/2C would have worked also, but 1/10C is what I used and it worked.
Depends on make and model, as the others have said.
abenn is offline Find More Posts by abenn
Old Jan 14, 2007, 06:29 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
The main purpose of cycling a battery is to know the capacity of the pack. As the pack ages the internals break down and capacity is lost.
New cells should be cycled AFTER a formation charge is completed. A formation charge is a C/10 (capacity/10) for 18-22 hours. The initial charge does need to be longer than the normal 15 hour time frame.
How many cycles? That is an easy question. As many as it takes to get to the rated capacity of the cell. Most packs will reach rated capacity in just 1 cycle, but I have had to do it myself as many as 3 times.
Why so many times? Depends on the age of the battery. Nicad and Nimh cells typically have a shelf life of 3 years in a factory set discharged state. The older the cells, multiple cycles may need to be done. Also, should you need to do multiple cycles, each charge should be a 15 hours C/10 charge.
How often should you cycle the pack? Once a pack is proven to be at rated capacity, cycling only needs to be done to check the capacity of the pack. 1-2 times a year is all that is needed. Once a pack is at 80% of the actual initial capacity, the pack should be properly discarded. Since battery packs are very inexpensive, I replace mine every 2 years. While Nicads have been known to last more than 5 years, it is cheap insurance.
Why do some packs never get to rated capacity? It may not be the packs fault. When you cycle, you need to ensure that the cut off voltage of the cycler is not too high or too low. .8V or .9V per cell is what you want the cut off to be. If it is higher than .9V per cell, the cut off takes place before the pack is finished. If it it is too low, below .8V per cell, you risk the the chance that the cell could reverse. Nicads and NIMH's cells are pretty durable but not immune to damage.
Evan Chapkis
RC Accessory, Inc.
Auth US Bantam Importer
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Jan 14, 2007, 06:41 AM
Joined Aug 2005
Thanks for the informative answers. I was mainly refering to Sanyo 1100MaH flight packs in my planes.
Thanks Again!
Bud
Old Jan 14, 2007, 07:22 AM
Make 'n Break!!
roosevelt's Avatar
Joined Apr 2006
I don't know who told you that but it seems like you'd be doing away w' 10-20% of the best usage.
I bought 6 packs and cycled the first three per the instructions. 25% of the c rating for first 3 cycles. The other 3 I charged at 1c and flew. Guess which ones "died" first. It was the first three.
Like i said earlier though I'd charge/ cycle new ones at half c for 2-3 cycles max and then charge at 1c thereafter. If they seem to get weak from storage or use the go ahead and repeat the cycle process. Sometimes it helps and sometimes it don't.
Old Jan 14, 2007, 08:35 AM
gulio is online now
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I have heard the "cycle new packs x number of times" , and buy a lot of unmatched/unzapped packs. I sometimes will slow charge and run a discharge test on a new pack, but have noticed on any of my packs that the very first cycle is the best capacity/voltage. 10% of the time it is the second or third cycle.
Most of mine are new gp 3300 and generic 3000 cells or generic AA cells. I am confidant to slow charge 1 time and then put them to whatever use. Occasionally I will use a lower voltage pack in a new model to breakin the motor, battery and allow me to get used to how stuff handles and set radio up. After 1 or 2 runs I'm ready to "cell up, gear up or motor up to full speed"
gulio is online now Find More Posts by gulio
Old Jan 14, 2007, 10:19 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Check out http://members.aol.com/davthacker/balancecharging.htm for some good advice on the care of your batteries and the value of occasional slow charges.
Rodney is offline Find More Posts by Rodney
Old Jan 14, 2007, 12:37 PM
The BA
Joined Oct 2006
I have 1500mah batteries and a Triton Jr that will charge at either .1 or .2 amps. Which setting should I use for the formation charge?
Old Jan 14, 2007, 12:43 PM
Joined Jan 2004
If I remember, the Triton Jr has a 2 hours non adjustable time cut off. If correct, you will not be able to use a Triton Jr for a formation charge. It could be for lipo only, I would have to refer to Red's comments online as well in his magazine column.
Site Sponsor
Old Jan 14, 2007, 01:33 PM
The BA
Joined Oct 2006
You're correct. Given that, the minimum I can charge at is .8A.
Do You Need A Special Motor Controller For Lithium Batteries? phil_013 Batteries and Chargers 6 Jan 19, 2004 12:39 PM
Do You Need A Special Motor Controller For Lithium Batteries? phil_013 Power Systems 4 Jan 17, 2004 08:48 AM
Do You Need A Special Motor Controller For Lithium Batteries? phil_013 Foamies (Kits) 2 Jan 16, 2004 05:50 PM
What do you use to cycle your batteries? GUIS Batteries and Chargers 4 Apr 28, 2003 04:30 PM
How Do You Condition New NiMh Batteries? vkmaynard Batteries and Chargers 1 Oct 26, 2002 11:07 PM
