Old Jan 13, 2007, 12:32 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Found out in a hurrythat lipo's are fradgile!
Been using nicads for years and recently (about a fortnight) swopped to lipo's.
A glitch crashed my spitfire and now my new TP 3C is punctured and smells.
I'll buy another lipo but will also stop useing GWS micro receivers.
wellington53 is offline Find More Posts by wellington53
Old Jan 14, 2007, 01:11 PM
Glenn
Joined Jan 2004
Well Iv'e left my dammaged 3 cell battery outside for 2 days now and nothing has happend yet. When I squeeze the dammaged area you can see fluid but it does'nt drip out but it smells. One cell is good. What do I do next.
Old Jan 14, 2007, 01:15 PM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
soak in salt water and toss.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Jan 14, 2007, 01:18 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
That is not a reliable means to discharge a LiPoly.
http://www.rcgroups.com/forums/showp...3&postcount=27
Old Jan 14, 2007, 02:33 PM
Glenn
Joined Jan 2004
So can't even salvage the cell that insn't punctured?
Old Jan 14, 2007, 02:50 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Testing has shown this does not necessarily work.
http://www.rcgroups.com/forums/showp...3&postcount=13
"So can't even salvage the cell that isn't punctured?"
You can try to save the remaining cell if it isn't damaged but what would you do with it? Don't set it on fire during dis-assembly.
hoppy is offline Find More Posts by hoppy
Old Jan 14, 2007, 02:57 PM
Glenn
Joined Jan 2004
How about adding it to a 2 cell equivilent to make a 3 cell.
Old Jan 14, 2007, 04:33 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Sure you can. The biggest problem would be using it. You'll either need to use it as a single cell in a low voltage application or obtain a new cell to pair it with. The problem with the latter is that the cells come matched to begin with, now you have one used cell that will be difficult to match with a new one..... charging and discharging at equal rates may be a problem, a balance charger may help in that circumstance. It's going to be tough to justify trusting it in the air.
It's much safer and easier to take a bad cell out of a 3 cell pack and turn it into a 2 cell than to do the reverse.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jan 14, 2007, 05:18 PM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
Discussion - Found out in a hurry that lipo's are fragile!
This is where A123's are good. I lost a brand new $160 pack because of a glitch.
That was on a ducted fan doing 100mph 4' off the deck. The only other thing to break was a servo gear.
Eagleburger is offline Find More Posts by Eagleburger
Question PolyMax LiPo's, are they any good? bobber Batteries and Chargers 27 May 31, 2006 06:04 AM
And the best Lipo's are made by....? lammy1000 Batteries and Chargers 487 Sep 24, 2005 09:45 PM
Here is how Lipo's are made and other info hoppy Batteries and Chargers 13 Apr 07, 2005 01:05 AM
upgrade in the works, Lipo's or Brushless? machine Parkflyers 30 Feb 13, 2004 01:26 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 08:58 PM
