Got up way too early today so I got busy and made the blades. I had traced the blade patterns onto 3mm depron and then I painted the depron sheet last night. The pen marks show through the paint. This morning I cut them out and glued on the spars.
Next I need to make the rotor hubs. This is always the hardest part for me to do well. Dan |
Latest blog entry: Quick Stick
It's good to have a pilot on board. If it crashes I can blame him. Dan
I wanted to create something with a kind of fun, cartoon feel to it. I also wanted it easy to build and fly. It actually builds very easy except the rotor hub. It requires a bit more precision/patience than the rest. I would love to figure out a very simple way to make a decent hub to accomodate the three blades of this type. Flight as soon as possible. Video as soon as it is warm enough for my wife to stand outside and shoot the footage...could be a while. Dan |
Pilot graphics
Here are the graphics I used for the pilot. Just print out the word document on a color printer. Glue the two sides two 3mm depron and cut out. The colors from my printer were'nt real vibrant so I used color markers to make it look a bit better.
In this format you can click each drawing and change the scale to suit...just do both by the same amount Dan |
Al,
The cg was initially in line with the spindles. With the battery moved it is about an inch behind the spindles. My gut feeing is that the blades have a bit too much negative incidence and aren't lifting as much as they should. I've been contemplating a fairly easy to build hub design for this style of blades that will let me ground adjust the blade incidence. Dan |
| Thread Tools | |
| Discussion GyroStick better video | leadfeather | Foamies (Scratchbuilt) | 6 | Feb 05, 2007 03:30 PM |
| Discussion GyroStick flight video | leadfeather | Foamies (Scratchbuilt) | 4 | Jan 20, 2007 07:49 PM |
| Bullet flight video posted on EAM | steve neill | Electric Ducted Fan Jet Talk | 3 | Sep 22, 2001 03:22 AM |
| Flight Video | docphi | Power Systems | 19 | Sep 08, 2001 02:45 AM |
| first flight of video xmitter on Wingo a success! | yb2normal | Electric Plane Talk | 19 | Jun 25, 2001 01:00 PM |
