Old Sep 06, 2001, 01:32 PM
ragtop is offline
Find More Posts by ragtop
il
Joined Sep 2001
13.5VDC power supply
I have a 120vac power supply that put's out a constant 13.5vdc at 16amp. I plan on using it as a power supply for my 12vdc hitech 330 quick charger instead of using the car battery. Is the 16amp output too much for this type of charger I don't want to burn up the charger. Thanks
ragtop is offline Find More Posts by ragtop
Old Sep 06, 2001, 01:49 PM
tbogli is offline
Find More Posts by tbogli
Middletown,CT,USA
Joined May 2001
The 16 amp means that it will handle a draw of 16amp. Think of it like the fuses in your house. If you have a 15amp fuse and you overload it will a 20amp draw lets say of a power-saw it pops the fuse.
You should be fine just as long as your charger loaded with batteries isn't going to draw more than 16amp.
I have a Samlex 13volt 23amp power supply attached to a dymond super smart charger which draws a max of 5amps (A little over kill but....).
tbogli is offline Find More Posts by tbogli
Old Sep 06, 2001, 01:52 PM
ragtop is offline
il
Joined Sep 2001
Thanks for the fast reply that answers my question
Discussion 17Amp/13.5V Power Supply Conversion JRuggiero DIY Electronics 7 Sep 10, 2006 06:58 PM
Sold 10 Amp 13.8V power supply f/s Fatair Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 07, 2006 06:09 PM
Wanted Cosel 12 volt 13 amp power supply nirenkinikar Aircraft - Electric - Airplanes (FS/W) 1 Jul 29, 2005 09:04 AM
12 VDC 13 amp power supply FLYERFRIEND Aircraft - Electric - Airplanes (FS/W) 2 Apr 06, 2005 07:52 PM
13.5V Power Supply HELModels Modeling Science 5 Aug 26, 2003 12:24 PM
