If you are using the stock prop EP1047, then try EP9070. That will make a major difference.
Perry AeroMicro Source of Electric RC Supplies http://www.aeromicro.com |
Central Pennsylvania
Joined Jun 2002
GREAT Responses, Thanks~!
OK, here's some responses to your suggestions.
(Addressed in the order which they were posted) 1) OK, I'm staring Nose-to-Spinner with my Pico FD. On the left I can read "GWS", and on the right "EP1047". If I understand what I have read here correctly, then the prop is indeed installed correctly. 2) next, spinning the prop. Well, it depends on how hard I flick it. A "normal" spin gets me 1 revolution (sometimes a little less). Spinning it "as hard as I can" gets me 1 1/2 revolutions.My conclusion? I think its binding. Yours? 3) Lube the gear? Uhhhmm. No, I didn't... Oooops! OK, that's one mistake for me... Where can I get some synthetic lube?4) Crashes? None. (wow, I think thats a record for me ). The closest thing to a crash that has happened to my FD is a few "nose overs" on landing in not-so-short grass. None hard enough to cause any damage, IMHO.5) Bent shaft? I don't think so, let me check....Nope, it appears to be straight. 6) Motor going out? I don't think so. I have only had the plane about a month, and only have maybe a dozen flights on it. (and I installed the heatsink to help the motor live longer) ![]() 7)EP9070 prop: What type of difference will I see? Best place to get one? (I don't have a LHS )Thanks again for the help. You E-Zoners are a great bunch.
| Thread Tools | |
| Wing flold on pico stick fd at 40 feet, NO DAMAGE! | Thomas Manson | Parkflyers | 3 | Jul 08, 2002 08:58 PM |
| Question on the pico stick fd's wings | j_z_123 | Parkflyers | 0 | Jun 17, 2002 10:38 PM |
| Pico stick FD vs Pico Tigermoth | dshuen | Parkflyers | 1 | Sep 06, 2001 05:49 AM |
| Pico Stick or Pico Stick-FD - Which flies better? | mrebman | Parkflyers | 2 | May 31, 2001 10:06 PM |
| Pico stick newbie question on battery and charger | Skywalker | Parkflyers | 2 | May 07, 2001 09:53 PM |
