Old Sep 20, 2002, 11:46 AM
redtiger is offline
Find More Posts by redtiger
who put that TREE there?!
redtiger's Avatar
Northern Westchester, NY
Joined Aug 2002
Scratch built p-51
The wife loves the way p-51s look, and we got TONS of blue-cor lying around. So we want to give a home built a shot.
I figured flying weight around 10oz or less, with elevator and aileron controls with a 24in wingspan or so. Basically, light, cheap and easy to build (and fun to fly )
What kind of powerplant would you folks recommend? We got a spare GWS IPS flying around, but that may not provide enough oomph.
I'm thinking the fuse can be almost 2-d to make life easier, just cut the profile out of 3/4" foam. Then shape the wings accordingly.
Any other thoughts? Gotchas I should worry about?
redtiger is offline Find More Posts by redtiger
Old Sep 20, 2002, 11:50 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
WHat about the mini BL ac 1215/20 with a MPI gearbox? It would Drill holes in the sky.
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Sep 20, 2002, 12:11 PM
member73 is offline
Find More Posts by member73
member73's Avatar
Wakefield, MA
Joined Feb 2001
At 10oz AUW, the GWS EPS-300 B should work fine. This is the same set up that powers the Switchback and Radical 540. Both around 10oz AUW. Price is usually $18-$20.
member73 is offline Find More Posts by member73
Old Sep 20, 2002, 12:38 PM
iamDerrick is offline
Find More Posts by iamDerrick
Joined Dec 2001
I'd suggest a direct drive 280 class motor on 2/3 aa cells
lightest and with the high pitch speed a model like a mustang would like.
have had experience with the GWS mustang with 24 inch span on an IPS s2 and 8X6 , flew fine but the large but slow spinning prop really held back the sleek airframe.
in dives you can practically hear the big prop braking
iamDerrick is offline Find More Posts by iamDerrick
Rave Scratch building a P-51 or Spitfire A_Langman Scale Kit/Scratch Built 13 Feb 08, 2010 09:25 PM
Scratch built p-38 36" wingspan - I'm probably nuts Tim Cullip Scale Kit/Scratch Built 21 Sep 26, 2005 02:31 PM
Scratch built P-51 paint ideas Mac8 Scale Kit/Scratch Built 11 May 12, 2005 07:04 PM
Scratch Built P-38 Bruzer Fuel Warbirds 6 Nov 22, 2003 09:57 AM
Plans Built P-51 FS/T dirtdiver Aircraft - Electric - Airplanes (FS/W) 7 Mar 31, 2003 05:59 PM
