Old Jan 11, 2007, 02:48 PM
Jupeli is offline
Find More Posts by Jupeli
Pirkkala, Finland
Joined Jan 2005
Looking for a cheap 500-600 size brushless
I'm looking for a motor that'll spin 9x6 prop direct drive with 4s LiPo at 40amps.
Any suggestions? So far I've found one: Dymond W35 E1 which seems to be some kind of AXI 2826 copy. http://modellhobby-shop.de/e-vendo/e...p=k_staufenb_e
I'm guessing that it might do fine but I'm still looking for other options.
From outside of EU, the price shouldn't be over 50USD, because of the customs. Inside EU, it isn't that important. Any way, suggestions please!
By the way, I remember that I've read about a cheap inrunner bought from Ebay, but can't find the thread. All I remember of the motor itself is that it's black and is about the size I'm looking for. If anyone finds it, I'd appreciate a link.
Jupeli is offline Find More Posts by Jupeli
Old Jan 11, 2007, 03:34 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
This Dualsky might just do what you want - it's rated at 650W, but if you want 40A on 4s continuous you probably need a 750-900W rated motor: http://2dogrc.com/ecommerce/os/catal...oducts_id=2071
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 11, 2007, 04:01 PM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
try www.orionhobby.net
great online place in Finland for exactly the type of equipment you're looking for.
oded mazor is offline Find More Posts by oded mazor
Old Jan 11, 2007, 06:43 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
This one might do the trick on 4s? http://www.orionhobby.net/index.php?productID=419
Old Jan 12, 2007, 01:53 AM
Bad Driver is offline
Find More Posts by Bad Driver
Daydream Believer
Bad Driver's Avatar
England
Joined Jul 2004
Possibly this one?
Quannum 36-55
A little info in this thread> http://www.rcgroups.com/forums/showthread.php?t=564118
Bad Driver is offline Find More Posts by Bad Driver
Old Jan 12, 2007, 08:41 AM
Jupeli is offline
Pirkkala, Finland
Joined Jan 2005
Exactly that one, thanks for the link
Old Jan 12, 2007, 08:55 AM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
I have the 40-70 version of that motor. I think Dymond sells them under another name but they appear to be the same motor.
I picked mine up on ebay for about $50 but it is larger than what you are looking for. The 36-55 would be great I bet.
mt_100 is online now Find More Posts by mt_100
Old Jan 12, 2007, 09:00 AM
Jupeli is offline
Pirkkala, Finland
Joined Jan 2005
Yea, I think so too and the price is good. I guess that 9x6 would be too much with 4s, but well.. I'm thinking of a speedy plane so 8-inch props won't be too bad. I think that if I end up buying that, I'll start with something like 8x5, 8x4.
Old Jan 12, 2007, 09:03 AM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
Not as cheap as mentioned, but some excellent spd 500-600 replacements are himax 3510 series and 3516 series outrunners. These are very powerful, have the same front bolt pattern as spd 500, and about the same diameter. They are a drop in replacement in most applications. Repare parts can be had at any hobby retailer that carrys himax.
topforce is offline Find More Posts by topforce
Old Jan 13, 2007, 12:57 AM
Funny Fishie is offline
Find More Posts by Funny Fishie
Wet around the gills
Funny Fishie's Avatar
Joined May 2004
Jupeli,
I bought one of those Quannum 36-55's recently but have not had chance to do any real testing as yet. I'll try and fit a 9x6 to it over the weekend and see what it pulls on a 4S pack.
Fish.
Funny Fishie is offline Find More Posts by Funny Fishie
Old Jan 13, 2007, 04:40 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Here is the motor for $33. Shipping is reasonable too. I've made 16 purchases from UH and have been quite pleased overall. I placed the latest last night.
https://www.unitedhobbies.com/UNITED...idProduct=2044
Len
LenBFP is offline Find More Posts by LenBFP
Old Jan 13, 2007, 02:02 PM
Jupeli is offline
Pirkkala, Finland
Joined Jan 2005
I now ordered the Quannum 36-55. Fish, I'd appreciate the data as I don't have a watt-meter myself yet. It's the next thing on my list, though...
Old Jan 14, 2007, 03:55 AM
Joined May 2004
J.,
Yup no problem; I'll do a few simple/quick tests with a range of 8-10" props, whatever I have available.
I also bought the Feigao Power Analyser - ~US$40 - from U.H. when I got the motor.... again only tried it briefly so far (my garage is so da*n cold at the moment! ) and it works but I'm not convinced of it's ultimate accuracy. Probably good enough so as not to fry the motor/esc/lipos
I'll be back later,
Fish
Old Jan 14, 2007, 07:47 AM
Joined May 2004
J. et al,
O.k. first part of my testing...
Measured my pillar-drill (drill-press) RPM by putting a prop - via adaptor - in the chuck and tach'ing it. Result = 2400RPM.
Then stuck the Quannum 36-55 in the chuck and measured the AC voltage from each winding with my Fluke DVM. Measured 1.29V, 1.29V & 1.27V so call that an average of 1.28V AC.
Using this formula -> kv formula I calculated that my motor has a kv of 1395 approx. Manufacturer specs 1350kv.
Next to prop the motor...
Old Jan 14, 2007, 08:22 AM
Joined May 2004
Motor: Quannum 36-55.
Prop: 9"x6" APC-E.
Batts: 4S2P 2200mAh 10-12C cont/16C burst, i.e. ~48Acont & 70A burst.
ESC: HobbyWing Guard 60A.
Meter: Feigao Power Analyser.
Tach: Glowbee Intellitach & 2xAA Maglite light-source.
Firstly, the 9x6 is too much prop I think for WOT. So I just increased the throttle until I hit approx 40A and got the following:-
38.5A
12.5V
12000RPM
All measurements made after 15-20 secs of running and are approximate cos it all happens at once
After a couple of runs to double check, the ESC & batts were just warm but the motor was quite warm (as hot as I'd like to run in a model) but note that I forgot to drill cooling holes in the plywood mount so no through-airflow!
This thrust calc Thrust Calc suggests 61oz/1730g of thrust at my altitude of 300'.
HTH,
Fish.
looking for a cheap brushless setup for parkzone p-51 terryh1313 Power Systems 11 Oct 01, 2005 08:12 PM
NEEDED WTT EVERYthing I have for 600 size brushless motors..... ObieinSeattle Aircraft - Electric - Airplanes (FS/W) 1 Feb 06, 2005 05:14 PM
Shogun - Looking for a cheap Brushless setup Legion Mini Helis 3 Nov 29, 2004 09:04 PM
Looking for a cheap (brushed) Skimmer 600 power upgrade BigShark Electric Sailplanes 18 Jan 25, 2003 04:12 PM
looking for cheap and easy, anyone??? newton Electric Plane Talk 1 Dec 05, 2001 08:36 PM
