Old Aug 07, 2001, 08:59 PM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Can you tell a 6v from a 7.2 volt speed 400 motor from the numbers on the can? How?
Only the numbers are on the can. How can I tell it it is a 7.2 volt or 6 volt motor?
erashby is offline Find More Posts by erashby
Old Aug 07, 2001, 09:27 PM
Kevin Klejwa is offline
Find More Posts by Kevin Klejwa
Bosque Farms, NM
Joined Jul 2001
I have 3 speed 400 motors. The 2 6V motors are labeled RS380PH. The 7.2V motor is labeled RS380SH.
Kevin Klejwa is offline Find More Posts by Kevin Klejwa
Old Aug 07, 2001, 09:38 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
If this doesn't help, hook them up to a battery pack, one after the other. The 6V will spin audibly faster.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old Aug 08, 2001, 06:52 AM
geoff.sim is offline
Find More Posts by geoff.sim
geoff.sim's Avatar
Northamptonshire, UK
Joined Oct 2000
The S and P stand for the type of magnets used . See the following URL for a full description of 400 can motor specs.
http://rcflier.rcplanet.com/RC_Info/...400/sp400.html
Geoff.
geoff.sim is offline Find More Posts by geoff.sim
Old May 18, 2002, 09:28 PM
ViperR is offline
Find More Posts by ViperR
Who's scaring the kittens
ViperR's Avatar
Joined Apr 2002
This is so cool and very interesting. I'm learning more and more thanks to you all. I'll re-install the stock RS-380PH (hence the Speed 400 6V) and hang on to the new Graupner when the kit motor goes. I might as well learn (and crash) on the kit motor since it's the same as the Graupner Speed 400 6V.
I used a strip of 1" nylon re-inforced strapping tape (the nylon won't burn off) and the motor was tight in the foam again. I also ran a bead of RTV around the front of the motor to sit over night. Then I'll install the gear box and go from there.
I don't know the total weight of my SS yet since it's still in the building stage.
I'll probably have some more questions on the SS since I'm new to this and I've certainly come to the right place with all you knowlegable people. How can I thank you?
ViperR
ViperR is offline Find More Posts by ViperR
Wanted speed 400 motors 7.2 volt shovelheadfreak Aircraft - Electric - Power Systems (FS/W) 3 Jul 29, 2007 08:34 AM
For Sale 5 new 7.2 volt speed 400 motors Steve H. Aircraft - Electric - Airplanes (FS/W) 6 Jul 21, 2005 10:36 AM
speed 400 6V or 7.2 volt...whats the differenceHey guys....question for ya....i have kindjordan Parkflyers 1 Jun 28, 2003 11:45 AM
What should I do with 7.2 volt speed 400 motors. erashby Electric Plane Talk 7 Sep 27, 2001 01:24 PM
Anyone please help - Can a 7.2 volt charger charge a 9 volt Battery pack? Jamie- Electric Plane Talk 5 Jul 29, 2001 07:49 PM
