Old Jan 10, 2007, 04:53 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Secrets To Taking Photos Of Your Plane In Flight
OK fellas, I see these fantastic in flight photos, what's the trick to it? I need to brief my photographer (my wife) on how to do it with the same results as I have seen posted here.
Of course it's with a digital camera so the lag time between pressing the button and the pitcure taking is making it tough.
Can you give a brief "how-to" take such good in flight pics please? Maybe I'm not the only one in the dark about it.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Jan 10, 2007, 06:54 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you set a fixed focus and exposure, the shutter won't have any lag.
..a
Old Jan 10, 2007, 06:55 AM
Downwind 1 is offline
Find More Posts by Downwind 1
Downwind 1's Avatar
massachusetts
Joined Aug 2003
Itís sort of like skeet shooting. I lead the plane with one eyes in the viewfinder and the other on the plane. Itís much easier shooting a picture of a plane coming at you, then a fast flyby in front of you. For fast moving subjects you need a high stutter speeds. And a lot depends on the camera you have. And how well you under stand it.
My camera will hold focus and the light reading when I hold the button half way down. So I focus at something in the distance first and told it. On a bright day.If youíre using auto. And shooting at the sky the plane will most likely be under exposed. That is, the sky will be bright and the plane will be too dark. So here is what I recommend , first focus halfway between the sky and tree line and hold it.
I use manual settings when I canít get the speeds or exposures I need. Try not to use too much telephoto as it will only get burly.
HAVE A GREAT DAY
Downwind 1 is offline Find More Posts by Downwind 1
Old Jan 10, 2007, 07:41 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Discussion - Secrets To Taking Photos Of Your Plane In Flight
Learn to put the tx down and pick up the camera very quickly, and vice-versa
Try to get your wife to follow the model, but you call "Now", when you want the shot.
That way if anything goes wrong with the shot it's your fault, and she will still help, cook meals, clean, wash, iron, etc
eflightray is offline Find More Posts by eflightray
Old Jan 10, 2007, 07:44 AM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Does your camera have a 'sports' mode? That takes instant and multiples.
Majortomski is offline Find More Posts by Majortomski
Old Jan 10, 2007, 08:09 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
I shoot at maximum resolution and maximum zoom at a speed setting of 400. Sometimes, early in the morning or late afternoon, I will use a flash to help illuminate the underside of the model as it flys by.
If I am alone and flying one of my ships, I try to get the plane trimmed for a gentle circle about 20 feet high and try and shoot with one hand--this can be tricky and expensive! I am not always successful at this as you can imagine. Here is a recent example.
Pat Daily is offline Find More Posts by Pat Daily
Old Jan 10, 2007, 11:31 AM
pd1 is online now
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
Frank, the camera helps a lot. All the sugestions so far are excellent, but a good camera will make a lot of difference.
With digital I take a lot of shots,delete most of them.
But every so often I get a few good shots,framed and in focus.
I broke down and bought a good camera last year,now I can get far shots that look good.
Now I have more good shots than bad.
Here's a few that came out well.
pd1 is online now Find More Posts by pd1
Old Jan 10, 2007, 11:46 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Flying and photographing at the same time takes a fair amount of practice.
Some cameras aren't suited for it.
On my Fujis SLRs, I've epoxied a 1/4" tube to sight thru.. trying to see the plane in the viewfinder can be disorienting/dangerous.
With my Pentax *1st, I use the viewfinder, it's brighter than the Fuji.. but still disorienting and dangerous.
With flying planes, to get a reasonable image, a good tele magnification is needed.
6x is OK, 10x is better! And lots of megapixels.
Auto focus can help, but if the camera "sees" there's nothing to focus on, although you can see the plane in the viewfinder, sometimes it won't take the photo!
Manual focus can help.. some cameras don't have that.
Fortunately tossing a digital image costs nothing, unlike a paper print.
I got the Pentax last May, and have taken over 12,000 photos with it since.
The good ones I keep, the bad ones no one ever sees..
That, BTW, is one of the secrets of getting the reputation for being a good photographer. Never show the bad ones!
When you can get one like these... you're there! Both with a Fuji 5100.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 10, 2007, 11:56 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
On many, suspend the plane from a tree, set the motor spinning and take the picture.//then clone the background to get rid of the suspension wire.
Aerials hanging straight down are a dead giveway.
I used to do a lot of aircraft and even bird in flight photgraphy, and the one thing that worked for me was a rifle mount, plus a long fixed length lens - I have a 400mm sigma..or a 200 mm zoom, but the sigma is a shade better.. automatic aperture, a fast shutter speed (at least 1/100 maybe up to 1/500 or higher) and fast film. When shooting against a dark sky I'd boost the aperture a couple of notches.
GENERALLY you can work at either a fixed focus..set so that when the plane fills the screen you are in focus, or at infinity for full size stuff.
The trick is to follow the plane with the rifle mount, and get the pilot to come in closer and closer as you pan..once the model is pretty much filling the screen shoot. If you have a motorised or rapid shoot digital, shoot all the way..and |DO NOT STOP PANNING..there is a delay in all cameras. Pan past the point of shooting.
Trouble is I am pilot AND photographer in this household.
Old Jan 10, 2007, 01:13 PM
Smash McCrash is offline
Find More Posts by Smash McCrash
89" Kool Aid drinker.
Smash McCrash's Avatar
United States, CA, Ventura
Joined Dec 2001
The biggest thing that I learned is to shoot it like you are shooting skeet... Follow through after you take the pic. Track the plane for a few seconds before and after the shot is taken.
Smash McCrash is offline Find More Posts by Smash McCrash
Old Jan 10, 2007, 01:20 PM
kestrel2003 is offline
Find More Posts by kestrel2003
No Guts No Glory
kestrel2003's Avatar
Switzerland
Joined Feb 2003
Get a good Lens
I agree with all the post so far. My pictures only become better with a good lens and a slr. The small digicams are good for pictures of slowflyers or planes on the ground but a SLR with different lenses is much better.
One tip is to try and constantly track the plane. A viewfinder is a must since the lcd is difficult to see in daylight. If there is no viewfinder make a loop from wire and attach it to the camera.
By playing around with the shutter speed you can either freeze the plane and background or get a more flowing dynamic picture. Mainly if you use digital instead of film, make as many pictures as possible and select them afterwards at home. That is no invitation not to try and be careful in every picture but a more pics give more selection later.
Not all planes look good from all aspects. Also the Background can add a lot to a picture.
Good luck on your images!
PS: never show the bad ones is a very good tip from Sparky Paul!
kestrel2003 is offline Find More Posts by kestrel2003
Old Jan 10, 2007, 01:30 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
SLR's are easier to get better results because you can track the plane easier. Digicams that have LCD viewfinders have a lag, and it makes it harder to consistently frame a good shot. My wife was really bad with a Panasonic DMZ-FZ10 that I had (lcd viewfinder), almost no usable shots. But with an SLR, she almost always got the plane dead center of the frame.
SLR's are great, but they are much harder on the wallet.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jan 10, 2007, 04:33 PM
Pat Daily's Avatar
Joined Mar 2001
Using an SLR one handed is damn near difficult. I like the digitals better for this. I am currently using a Canon with 7 megapixels which allows for a lot of enlargement. Tracking is the key--but that is hard to do with one handed shooting. You takes your chances but some shots come out. But then digitals photos are "free" as long as you don't crash the plane or drop the camera--then it gets a bit expensive. Don't ask how I know.
Old Jan 10, 2007, 04:43 PM
David Hipperson is offline
Find More Posts by David Hipperson
Kilsyth, Victoria, Australia
Joined Oct 2003
I used to use SLRs but over recent years have had pretty good success with the Canon 'A' series A40, A95 and now A710IS. These have an optical viewfinder and so tracking the aircraft is easy and you do not 'lose' the model when taking the picture. They also seem to have a very short lag time on focusing. After trying alternative methods I now use the camera on automatic and you can see a sample result below taken just a few weeks ago. I'm telling the truth when I say all my results are similar. Just track the model, presss the shutter button to first position to aquire focus and the press again to take the photo.
David Hipperson is offline Find More Posts by David Hipperson
Old Jan 10, 2007, 05:50 PM
Murocflyer's Avatar
Joined Nov 2005
Some great advice thanks! Also a bonus of some great in flight pics. I never tire of in flight pics.
I guess I shoud have mentioned I have a Olympus C-740 camera. I give those tips a try, well I should say, I'll suggest these to my wife and ask her to give them a try
Thanks again, and if they work out, I'll post them.
Frank
Onboard Video/photos of magpies attacking my plane in flight! Kahnx Aerial Photography 34 Aug 31, 2005 06:50 AM
So You Landed Your Plane in a Tree, huh? DNA Humor 1 Sep 15, 2003 06:07 PM
Skydiver re enters plane in flight shaneyee Electric Plane Talk 21 Jun 21, 2003 03:15 PM
Kolibri Bi-Plane in Flight Manchild Parkflyers 5 Apr 15, 2003 10:08 AM
FOR SALE: Your goodies in flight.. genovia Aircraft - Electric - Airplanes (FS/W) 14 Sep 22, 2002 09:35 PM
