Old Jan 05, 2013, 03:34 PM
catspaw is offline
Find More Posts by catspaw
catspaw's Avatar
United States, WI, Stoughton
Joined May 2003
What kind of motors would folks use on this plane today?
catspaw is offline Find More Posts by catspaw
Old Jan 05, 2013, 03:44 PM
Mark Wolf is offline
Find More Posts by Mark Wolf
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Personally speaking...Speed 400's just as it was designed for. Brushed motors still have a lot going for them in multi-motor applications. Only one speed control required, less wires to run, etc. This isn't a model that needs a ton of power, so why not keep it cheap and simple?
Mark Wolf is offline Find More Posts by Mark Wolf
Old Jan 05, 2013, 04:06 PM
Dangaras is online now
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
I am going the complicated way with what I had at home. Four 28-30 brushless as I plan to carry and drop stuff....
Dangaras is online now Find More Posts by Dangaras
Old Jan 05, 2013, 07:50 PM
SRush99 is offline
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Originally Posted by Dangaras View Post
Ok, I have a question. I started trying to lay down the foil tape on the plastic nose cone and I can't get it right.
I started with the bottom section that is solid silver by cutting 1/2 inch strips and trying to lay them down from the rear to the front but they started getting pretty messed up.
What's the trick?
I can do all the thin strips no issue.
thanx in advance..
Dangaras,
I used aluminum gutter tape from Home Depot - the kind without the print on it. Make sure you cut your strips of tape lengthwise with the roll. This seems to be the direction the "grain" of the aluminum goes. Takes a bit of experimentation but cut each strip about 3/4" wide but instead of cutting the edges straight, cut them in a slight oval. star at one end and place the centerline of the tape down first, then use an exacto knife handle to burnish the tape into place. Overlap each piece. You will get some wrinkles but that's where the burnishing tool comes into place. Put your finger on the inside of the canopy and rub the wrinkles down to get most of them out.
-Stuart
SRush99 is offline Find More Posts by SRush99
Old Jan 05, 2013, 07:55 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
If you are using retracts, you'll need more power than the 400's can deliver. With the edf brushed motors I had on my first B-29, take off roll was 100 + ft off of a grass runway to get it air born. I'm planning on using motors similar to brushless 480s in the bird I'm building now. 400s will work ok as long as you hand launch and keep it light. With brushless combos getting cheaper ( motor and esc) I'd prefer to have a bit more power - I can always throttle back
Old Jan 05, 2013, 07:57 PM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
What Stuart said. Also, when it is gleaming in the sun, the wrinkles get smaller.
Jim
Jim Young is offline Find More Posts by Jim Young
Old Jan 05, 2013, 07:59 PM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
The problems with this are brushed esc's are getting scarce, and 3s is a bit much for a 7.2v sp400.
Jim
Old Jan 05, 2013, 08:14 PM
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ah, the oval idea was going to be my next attempt. Starting from the mid line is the trick huh?
Thanks guys.
Old Jan 05, 2013, 08:43 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Close up picture of B-29 #2 canopy
Old Jan 05, 2013, 08:58 PM
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
ok, I got it. Need some practice.....
Old Jan 06, 2013, 08:57 AM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
Jim
They aren't as common, but still out there, not to mention that thousands of ESC's collecting dust in folk's shops. I'd wager a post in the WTB section would have a lot of ESC's available for cheap. I haven't run a 7.2v motor on 3s, but I've run them extensively on 10 cell nicad packs. They last quite a long time so long as you keep the amp draw below 10. I'd bet a 3s A123 pack would work quite nicely with the 7.2v S400.
Old Jan 06, 2013, 09:53 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
True on all counts, Mark.
Can you still get the "higher end" SP400 type motors with bearing and external brushes? THese might be an option too.
-Jim
Old Jan 06, 2013, 12:06 PM
quenda is offline
Find More Posts by quenda
Italy, Emilia-Romagna, Plaisance
Joined Aug 2005
Hallo!
A very good solution for multi-motors models is the MIG 400 3Li 12V.
This motor is made in Chzec Republic by MEGA MOTOR:
http://www.megamotor.cz/v4/script/de...ge_id=lang_eng
Same dimensions of a Speed 400 but suitable for 3 Li-Po battery.
I've installed 2 of these MIG 400 12v on my Multiplex Twinstar with one 2.000 Mah. 3 cells li-po and the performance is very, very good.......a lot better than the traditional Speed 400 motors.
The price (in Italy....) is very good too......about 10 USD.
Bye!
ettore
quenda is offline Find More Posts by quenda
Old Jan 06, 2013, 12:22 PM
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
-Jim
I'm sure those motors are still out there somewhere. Back to the S400/lipo voltage issue, a series-parallel setup may also work well. Divide the motors into inner/outer banks wired in series and the two banks then connected in parallel. With a 5s lipo you would effectively have each motor running on 2.5 cells and the total amp draw at the battery would only be ~20 amps.
It might be hard to find an ESC for this set-up new these days, but there have to be thousands of older Astro controllers out there for the asking.
Old Jan 06, 2013, 06:59 PM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Mark,
Don't you have a plane to be working on? ( ^ ;
-Jim
B-29 plans BRADJ Scale Kit/Scratch Built 17 Oct 31, 2013 01:53 AM
Discussion Giant Scale electric B-29 plans! Ryan Archer Scale Kit/Scratch Built 19 Sep 30, 2007 01:24 AM
Ralph Beck H-B W-29 plans? temacc Scale Kit/Scratch Built 1 Sep 09, 2007 05:46 AM
Discussion b-17, b-52, p-38, b-29 plans donanton Electric Plane Talk 5 Apr 05, 2007 10:25 PM
WANTED: Guillows B-29 Superfortress plans,(or equivilent) Demon-Leather Aircraft - Electric - Airplanes (FS/W) 0 Dec 22, 2002 11:32 PM
