Old Oct 07, 2012, 10:18 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Any pix of the aftermath?
Dangaras is offline Find More Posts by Dangaras
Old Oct 07, 2012, 10:39 PM
SRush99 is offline
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Sorry no. The wing was broken in 3 places, All the motor mounts were broken, nose canopy smashed almost flat (vertical dive straight in)front of fuse crumpled in and broke at the wing. From the trailing edge to the tail - perfect for mounting on the "Wall of shame"
SRush99 is offline Find More Posts by SRush99
Old Oct 07, 2012, 10:40 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
I just ordered 2 new canopies from Jim
Old Oct 08, 2012, 09:43 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ay! Painful just to think about it...
Old Oct 08, 2012, 10:02 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Wow,
Got an email today that Jim just shipped my new canopies ..... Guess I'm commited!
Old Oct 09, 2012, 12:11 PM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Sorry for your loss. The USPS should have control of your canopies (goodluck).
I do have 3 sets of parts for other interested parties, and flyingfoam (under new ownership) is still cutting the foam.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Dec 09, 2012, 08:51 AM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Canopies received and build is beginning - slowly but surely. There have been a few people over the years asking about how to mount retracts. My old B29 had Spring Air retracts which worked fine. For my new B29 I'm going to use Eflite 15-25 sized electric retracts. The pictures show you what I've done.
Old Dec 09, 2012, 04:59 PM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Very nice idea on mounting the nose gear, and thanks for sharing. Would you do better to make the mount wider and having solid sides to get more gluing surface?
Also, how did you make/where did you get the dual wheel mount? Very cool.
I'm getting too old for hand launching planes, so I may have to modify mine, or build a new one.
-Jim
Old Dec 09, 2012, 07:07 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Jim,
Great idea! I had given it consideration when I put the gear in and saw that the axle just overlapped the sides. I've got a new box to glue up now. The box will not only be glued to the fuse cut out but I'm also adding bulkheads leftover from the canopy mount to help stabilize the entire nose wheel box.
The dual wheels are simple. Best way to describe it is with a picture. I bought an assortment of "E" clips at a flea market a few years ago. I think you can get the same thing at harbor freight. I took a steel shaft and cut it to length, then cut a groove in the ends using a dremel cutoff wheel. Chucked the shaft in my drill press, then used the dremel tool to cut the groove to the depth where it would accept the E clip. This saves a lot of room versus using collets.
Old Dec 09, 2012, 08:00 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Updated nose gear box dry fitted into fuse with canopy. I have 2 bulkheads left over from cutting the canopy mount rings out. These were cut out to fit the nose gear box. Think I'll make the front a 1 piece design
Old Dec 09, 2012, 08:03 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Nice. Will get to mine this winter.
Old Dec 10, 2012, 06:56 AM
mmmdowning is offline
Find More Posts by mmmdowning
Spotsylvania, VA
Joined Nov 2005
Very nice , thank you for showing the retracts.
mmmdowning is offline Find More Posts by mmmdowning
Old Dec 10, 2012, 01:49 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
I suggest getting the metal trunion blocks, the plastic stock units let go real easy.
Nice work.
Mark
mrittinger is offline Find More Posts by mrittinger
Old Dec 16, 2012, 08:48 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
A bit more progress. Sheeted the forward fuse and applied gutter tape to canopy
Old Jan 05, 2013, 02:24 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Ok, I have a question. I started trying to lay down the foil tape on the plastic nose cone and I can't get it right.
I started with the bottom section that is solid silver by cutting 1/2 inch strips and trying to lay them down from the rear to the front but they started getting pretty messed up.
What's the trick?
I can do all the thin strips no issue.
thanx in advance..
B-29 plans BRADJ Scale Kit/Scratch Built 17 Oct 31, 2013 02:53 AM
Discussion Giant Scale electric B-29 plans! Ryan Archer Scale Kit/Scratch Built 19 Sep 30, 2007 02:24 AM
Ralph Beck H-B W-29 plans? temacc Scale Kit/Scratch Built 1 Sep 09, 2007 06:46 AM
Discussion b-17, b-52, p-38, b-29 plans donanton Electric Plane Talk 5 Apr 05, 2007 11:25 PM
WANTED: Guillows B-29 Superfortress plans,(or equivilent) Demon-Leather Aircraft - Electric - Airplanes (FS/W) 0 Dec 23, 2002 12:32 AM
