Old Apr 07, 2007, 04:38 PM
Bomberguy is offline
Find More Posts by Bomberguy
Turrets Syndrome?
Bomberguy's Avatar
Marina Del Rey California
Joined Dec 2003
Enola Gay at the Smithsonian
Shot a few picks of the beautifully restored Enola Gay a couple of weeks ago. The B-29 sure was a beautiful bird.
Bomberguy is offline Find More Posts by Bomberguy
Old Apr 07, 2007, 04:46 PM
Wade Joos is offline
Find More Posts by Wade Joos
Wade Joos's Avatar
United States, UT, Salt Lake City
Joined Aug 2002
Nice pictures - Thanks for sharing
Wade
Wade Joos is offline Find More Posts by Wade Joos
Old Apr 07, 2007, 05:40 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Looks like they couldn't round up a set of boots for Enola Gay. (No biggie, polished aluminum looks better, anyway)! Attached is a pic of "Dock Crew of the Month", 55 years ago. That's me, 2nd from the left, back row, just so you know what those Goodyear de-icer boots looked like.
(Docks were wooden structures that provided a roof over the engines, so we could perform maintenance on the engines, out of the weather).
Lancer31 is offline Find More Posts by Lancer31
Old Apr 07, 2007, 07:19 PM
Turrets Syndrome?
Bomberguy's Avatar
Joined Dec 2003
Birth of a B-29 on my YouTube page
Birth of the B-29 Part 1 (3 min 59 sec)
Birth of the B-29 Part 2 (8 min 50 sec)
Birth of the B-29 Part 3 (7 min 28 sec)
Old Jul 03, 2007, 12:31 PM
SRush99 is offline
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
All,
I'm going to be starting my B-29 soon and was wondering how you sheeted the fuselage. I've read several "how to's" on vacuum bagging sheeted foam wings but a cylinderical shape seems like it might be more difficult.
Stuart
SRush99 is offline Find More Posts by SRush99
Old Jul 03, 2007, 04:55 PM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Hi Stuart,
The principles are the same no matter what the shape. Just make sure to insert the off cuts in the fusealge or you'll crush the tube.
If you use contact cement, you can get around bagging it. You just roll the fuse on the sheeting, trim the overlap, and glue the seam with some foam safe CA.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Jul 03, 2007, 05:42 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Thanks Jim, I have some old formula 3M that I'll try. Let you know how it goes.
-Stuart
Old Jul 17, 2007, 09:25 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Jim,
I followed your advice and purchased some Weldwood waterbased contact cement to sheet the fuse . Everything worked great! I did use foam safe CA on the seam and then put both fuses in their original foam cutouts. I've glued up the horizontal stab tonight as well as part of the vertical stab. I'm planning a functional rudder and retracts for my plne. Hope to have it finished by the BEST fly-in in October.
Thanks for the plans and all of the work to get a foam cutter lined up!
-Stuart
Old Sep 02, 2007, 10:50 PM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Has anyone flown their B29 with a Spektrum radio/receiver yet? I was wondering if anyone is experiencing any glitching when using chrome Ultracote?
Here's a couple of pictures of my work in progress. The nacelles will be carved out of foam and I'm adding spring air 602 retracts.
-Stuart
Old Sep 02, 2007, 11:50 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I used Chrome Monokote on my version of Pat Tritle's Cessna 140 after checking with Monokote and Spektrum folks on potential problems , they assured me that Monokote is transparent to the 2.4ghz signals. I have had no problems with chrome Monokote. If I were using 72mhz gear, I would run an antenna outside the fuselage to the rudder .
E-Challenged is offline Find More Posts by E-Challenged
Old Sep 03, 2007, 06:22 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Nice job on the detailing, it really looks great.
I agree with E-C, and I know that Ultracote is transparent to RF.
-Jim
Old Sep 03, 2007, 07:20 AM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Thanks for the responses guys. So far, the build has been very easy. The foam parts cut by Flying foam have been outstanding.
I'll be fitting the LG to the Nacelles and building the motor mounts this week. I'm making adapters to fit dual wheels on my LG now.
-Stuart
Old Sep 20, 2007, 07:13 AM
SRush99 is offline
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Progress report
Thought I'd check in with everyone on my progress.
Rudder and elevator linkage installed.
Wing is sheeted and wing mounts installed. Set the wing to +1 1/2 degrees incidence
Installed retracts. I'm using Spring Air 602's.
Fab'd axle mounts to run dual wheels.
I've carved out 1 of 2 foam nacelles for the inboard motors -
Still have a bunch to do.
Does anyone know where I can find turrets & windows? I don't have a vacu-form machine yet ( on my list of projects ). I've seen where some are using salt shaker tops, etc for forms, then pull heated plastic over them.
I'm also trying to decide on decals to make, just haven't found a good subject yet!
-Stuart
Old Sep 20, 2007, 10:32 AM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
I have used the Harbor Freight foil without incident .....much more pliable as well, and it is REAL aluminum, how much more scale can you get ?
Mark
mrittinger is offline Find More Posts by mrittinger
Old Sep 20, 2007, 11:19 AM
Turrets Syndrome?
Bomberguy's Avatar
Joined Dec 2003
Originally Posted by SRush99
Does anyone know where I can find turrents & windows? I don't have a vacu-form machine yet ( on my list of projects ).
I find a lot of usable clear plastic at the 99 cent store. Packaging for a kids ball and jacks set yielded several small domes for example, they might work. I used one on my B-24 for the navigator astrodome
B-29 plans BRADJ Scale Kit/Scratch Built 17 Oct 31, 2013 01:53 AM
Discussion Giant Scale electric B-29 plans! Ryan Archer Scale Kit/Scratch Built 19 Sep 30, 2007 01:24 AM
Ralph Beck H-B W-29 plans? temacc Scale Kit/Scratch Built 1 Sep 09, 2007 05:46 AM
Discussion b-17, b-52, p-38, b-29 plans donanton Electric Plane Talk 5 Apr 05, 2007 10:25 PM
WANTED: Guillows B-29 Superfortress plans,(or equivilent) Demon-Leather Aircraft - Electric - Airplanes (FS/W) 0 Dec 22, 2002 11:32 PM
