Old Apr 02, 2005, 09:31 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Thomas,
Just what you need. Another airplane. LOL!!!!!!!
Steve
U812 is offline Find More Posts by U812
Old Apr 03, 2005, 07:45 AM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
There is no such thing as "too many airplanes!"
Hey guys, I've been sending out lots of parts, where are the construction and finished photos?
I got my latest shipment in, and I have 20 sets of parts to sell.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Apr 03, 2005, 12:53 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I have been collecting models at a fairly high rate lately, but there is always room for a B-29....
I have a 4 motor jones going on these days.
Steve, watch for my upcoming thread on my micro Republic XF-12 Rainbow.....blue foam and depron, 4X M20 motors, 22" span, (1/72 scale) and well under 4 oz...
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Apr 10, 2005, 06:49 PM
wildbill95823 is offline
Find More Posts by wildbill95823
NON PayPal Member
Sacramento Metro, California, United States
Joined Nov 2001
B 29
Hi Jim, are the foam parts still availble?
I had my B 29 at the field today and there are 3 guys that want to
build the big bird.
I flew my B 29 today and lost an engine on the third flight, the
Li-Po batteries are great but hard on the 400 brushed motors.
Let us know on the foam, I know you have the plastic.
Bill
wildbill95823 is offline Find More Posts by wildbill95823
Old Apr 11, 2005, 11:31 PM
pmallonee is offline
Find More Posts by pmallonee
Phil Mallonee
Olathe, Kansas
Joined Feb 2005
OK, here is my first ever post.
Jim, I saw the article in RCM and ordered the plans. I was even more excited to find the thread here since it has much more information than the magazine.
I'm pretty new to cutting foam. I did the forward section of the fuselage as you suggested by letting the bow drop onto and around the templates. That worked acceptibly, but not great. But I have ruined two aft sections trying to cut that round off-center taper. I finally realized that I let the wire get crossways between the small aft section and the large front section leaving a foam canal across the top of the fuse.
Is there a clever technique for cutting this section?
While I'm throwing out questions, how is the elevator hinged? I didn't find a reference but this thread has gotten pretty long and I might have missed it. I was assuming a hinge made of covering.
Oh, finally, are there any plastic parts still available? I think the last reference I saw was $34 for a set. Please let me know how I could pay you for these.
pmallonee is offline Find More Posts by pmallonee
Old Apr 12, 2005, 12:09 AM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
Sorry if this has already been asked - but from which issue of RCM can I order the plans?
Ted
(ahh... found it. Feb 2005)
Is anyone still cutting cores?
TRP is offline Find More Posts by TRP
Old Apr 12, 2005, 06:00 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
CUtting foam
Hi P?,
For cutting the cone for the tail section, see if your significant other can help you out. Mark your templates like a clock and each of you manually move one end of the wire around the templates. Use the clock markings to make sure you're both at the same relative position. If you hold the cutting wire out side of the power clips, it will be cold.
My elevator is hinged with the covering material. I recommend to use a strip on both sides to make it secure. If you're careful, you can also use CA hinges.
Bill & Ted,
Vulkanite is cutting the foam for me, his address is in the back of the RCM article or you can PM him here on the ezone. He is kind of hard to get a hold of, so be patient.
I have plastic parts, they are US$35.00 and that includes shipping in the U.S.
You can PayPal me at the address listed in the RCM article, except my ISP is SBCGLOBAL.NET and not SPCGLOBAL... Or I accept personal checks and my snail mail address is listed there as well. If using PayPal, PLEASE do NOT try to send a credit card payment. If I accept one credit card, PayPal has to upgrade my account and starts to take 2% to 4% of every transaction, and my margin is not that big on these parts.
-Jim
Old Apr 12, 2005, 11:10 AM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
Jim,
Thank you for the info on the plans / cores.
Any idea what Vulkanite is charging for them?
Thanks again,
Ted
Old Apr 13, 2005, 08:26 AM
Phil Mallonee
Olathe, Kansas
Joined Feb 2005
Thanks, Jim.
It's Phil by the way. I think I fixed my profile so that shows up.
I didn't have any help available last night but I realized after reading your post that it was a lot like tapered wing. I just anchored the cutting wire at the right height, did a little math, and cut a new one out by pulling the other end of the wire around the big template (I had both templates on). It came out pretty credibly except I was probably running a little hot on the small end. I never realized how much nichrome stretches when it is heated.
Looking back at the pictures I noticed that you didn't hollow yours out until after you sheeted. My tail section is still solid (well, laminated) but I actually built my front section with a partial hollow so I could feed a wire through and then cut the full hollow. Did I goof? Does that keep the vacuum bag pressure from deforming the cylinder? I've done a couple of kits but I'm not what you would call a seasoned builder.
Let's see... 2 questions down 998 to go....
I fired off the paypal for the nacelles and nose and I will follow that up with a regular e-mail to the same address so that you have my address. Thanks so much for doing that. There's now way you can be making any kind of real money doing this.
Old Apr 13, 2005, 07:56 PM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
B-29 build secrets
Hi Phil,
I got your paypal and the parts will go out this week.
I did hollow out the fuselage before vacuum bagging it. I just put back in the part I cut out. If you have some imperfections due to the hot wire, use some light filler (Carl Goldberg) to fill them in. This stuff sands like foam so you can true up your parts pretty easily. Use this to fill in around the aileron servo leads too.
I used contact cement to sheet the fuse, and vacuum bagged the main tube just to make sure I got a good bond. I didn't bother with the tail section and it is doing fine. If you have a small cutout through your fuse, I don't think the vacuum will crush it. If you can control the pressure just dial it down.
-Jim
P.S. No I'm not make a lot of money on this, but now I have a friend in the Netherlands, a couple in Canada, a few in California, two in Hawaii, and now another one in Kansas. So I'm still getting rich!
Old Apr 13, 2005, 08:20 PM
katana2665 is online now
Find More Posts by katana2665
katana2665's Avatar
Guilford, Ct.
Joined Jan 2004
Nice work fella's. I just wanted to say thanks, because although I am not building a B-29 (heresy!), I am scratchbuilding an Apollo 13 service and command module and hadn't worked out the mirror finish and all those rivets...Thank you for solving that for me. I'm out of here...
katana2665 is online now Find More Posts by katana2665
Old Apr 25, 2005, 01:43 PM
Phil Mallonee
Olathe, Kansas
Joined Feb 2005
Is anyone out there flying one of these beasties on Li-Po power?
I saw at Toledo where FMA was selling their 20C Li-Pos for a really good price and bought a couple of sets for my B29. Unfortunately, I hadn't done my homework ahead of time and at the time of my impulse buy I confused 7-cells and 7 volts(2S).
Is there any way to compensate for the lower voltage by using a lower voltage motor (e.g. a 4.8v motor). Two of those batteries onboard would let me source 80 amps.
Anyway, I was just curious for success or horror stories from other power plant configurations.
Old Apr 25, 2005, 03:09 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Yes, but you may even be able to use two of your packs in series. What are the voltages and mAh of the packs ?
Kevin Murray is offline Find More Posts by Kevin Murray
Old Apr 25, 2005, 03:58 PM
Tom in Cincy is online now
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
I am running a 2s2p 5200mah pack in my B29. The motors are 4x permex 6.0 volt speed 480 motors.Total current draw is about 48 amps. The props are 6.5x4 scale available from Hobby Lobby pn# GR6070P http://www.hobby-lobby.com/elecprop.htm The B-29 flys well on this set up. I also have B-17 running 4 permex 6vdc speed 400's. They also draw about 48 amps from the 2s2p LiPo. The controller is a Jeti 50 amp brushed JES50 now replaced by the JES60... I think you got the right battery...
I switch props and controller between the 2 planes....
Tom
Tom in Cincy is online now Find More Posts by Tom in Cincy
Old Apr 26, 2005, 01:17 PM
Phil Mallonee
Olathe, Kansas
Joined Feb 2005
The batteries are the new Kokam 2100maH 20C 2S1P cells. I was planning on two in parallel making it effectively a 2S2P pack. Theoretically that makes them a nominal 7.4v at abou 84A maximum. (Though I doubt they would do both at the same time).
Now that I think of it I think I read elsewhere on the forum that 10A to a speed 400 motor is about the limit they want. Is that the reason for the 480s?
My LHS was out of bananna to Deans charge cables and I still need to make a LiPo charging box out of leftover ceramic tile backer board so I haven't fired up the batteries yet. I was going to do some tests with the 6v Graupner and a 4.8v motor that I bought with the Whattmeter. I was planning on those Graupner props.
Tom, do you know what your motor terminal voltage is at full throttle? Maybe I'm worried over nothing. Actually, that probably goes for those flying Nickel batteries as well. Can anyone flying on a 7cell or 8cell pack tell me what motor terminal voltage they are experiencing with all four turning at power? If the pack and wire resistance is lower on the LiPos maybe that makes up for the extra cell difference. It's the voltage delivered to the motor that matters, isn't it?
Well, if this post doesn't peg me for an e-flight rookie, nothing will.
B-29 plans BRADJ Scale Kit/Scratch Built 17 Oct 31, 2013 01:53 AM
Discussion Giant Scale electric B-29 plans! Ryan Archer Scale Kit/Scratch Built 19 Sep 30, 2007 01:24 AM
Ralph Beck H-B W-29 plans? temacc Scale Kit/Scratch Built 1 Sep 09, 2007 05:46 AM
Discussion b-17, b-52, p-38, b-29 plans donanton Electric Plane Talk 5 Apr 05, 2007 10:25 PM
WANTED: Guillows B-29 Superfortress plans,(or equivilent) Demon-Leather Aircraft - Electric - Airplanes (FS/W) 0 Dec 22, 2002 11:32 PM
