Feb 07, 2004, 09:10 AM
USA, NC, Greenville
Joined Dec 1999
OK Thanks Jim. After asking that question I looked back at each page untill I saw the pic you posted of the nacell and nose.
One size is fine. I'm not a "Stand-Off Scale Nut".
The reason I was wondering is retracts. Wondering if there would be a place to fold the legs into. After seeing the pic I came up with an easy solution shouhd I go the retract route.
The knee jerk idea is to just pull a new set. Not. I have never done one.
Second idea is the winner. Use the Lexan ones from the pieces you provide, cut then at the widest part and use the two peices as the front and back of the new longer inbord nacell. The middle can be framed out in balsa with 3 or four bulkheads, stringers and sheeted with 1/16 balsa. The lower streached section would mainly be the doors to cover the wheels when up.
I need to find some pic or line drawings for the B-29.
