Old Nov 30, 2003, 05:50 PM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
Originally posted by rcav8r2
Perry; thanks for the feedback. I'll stick with what is proven power wise. No use re-inventing the wheel.
Also glad to hear reception is no issue. I have a 555.
Another ?: Are the Shotkey Diodes necessary on the motors? I've used them on 05 cans, but not the speed 400s.
Hopefull Steve will chime in on the gear.
THANKS again
Not a problem. Glad I could help.
You won't need schotkey diodes. I don't have them on any of my planes including the Martin Mars and I have four Mag Mayhems in her.
My antenna runs through the fuse all the way to the back of the rear gun barrel. I have the new Litenna http://www.rcgroups.com/forums/showt...hreadid=118944 from Jim Mcpherson which should eliminate the unsightly antenna lead running out the back. Once I install it, I will let you know how it works. I have read that these new antennas are very good and eliminate alot of receiver glitching issues plus you can install them entirely in the inside of your plane without any problems.
Here is a pic of my '29 on her maiden. Look at the back and you can see the antenna lead poking out. Grrrrrr.......
Perry
Rudderman98 is offline Find More Posts by Rudderman98
Old Dec 02, 2003, 07:39 AM
vulkinite is offline
Find More Posts by vulkinite
detroit
Joined Jan 2002
thanks for photos
still working on 108 wing span B36?
vulkinite is offline Find More Posts by vulkinite
Old Dec 03, 2003, 12:10 AM
AMA 670207
Joined Oct 2000
Re: thanks for photos
Can't find my plans. I think I might have loaned them out. I will have to make a few phone calls to locate them.
Perry
Old Dec 08, 2003, 07:52 AM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Hi All,
I got over to see Dennis' shop again and picked up some of his CNC cut parts for the B-29. The parts are coming out great and match up to the plans very well. They are much better than what I could do manually and his price is pretty reasonable. If you interested in this model, drop him a line for parts.
I still have 3 sets of vacuum formed parts left.
He also showed me some pieces for his B-36, and it is impressive. Dennis is able to cut some very complex shapes and has included slots for some internal structure. The wing will be huge and may need a spar or two.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Dec 14, 2003, 04:31 PM
vise101 is offline
Find More Posts by vise101
Vertically challenged.
Peachland B.C. Canada
Joined Nov 2002
Hi everyone.
I have just recieved a set of plans and nacelles/nose for my birthday (thanks Huckebien)
Just a thought and I would like everyones input.
I have 4 of the geared GWS EPS 300c's. Can I use these instead of the 4 speed 400's? My understanding is that it will fly a little slower than the direct 400's and that I will have way less amp draw with the geared motors. Is this correct and if not can some of you guys explain why?
This will be my first multimotor project so this is pretty new to me.
Thanks for the input and have a Merry Xmas.
Kevin.
vise101 is offline Find More Posts by vise101
Old Dec 14, 2003, 04:44 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
I'd stick with the proven set-up. I've been flying mine for 2 years now on direct sp 400.
You can always throttle back as I do once I ROG.
BTW Perry I had my first crack up. Was taking off and just as I got airborne she snapped to the left and broke the wing off from tip to the first engine.
Fuse managed to be spared and it's a good thing too after putting the new clear nose on with all the interior details.
Wing and nacelle was repaired in one night.
Upon inspection of the equipment to find the cause I found that the RX antenna came loose at the receiver.
I account this too placing the plane upside down in the cradle to mount the wings over two years.
Since the ant was attached to the tail, when placed in the cradle it would stretch the antenna. Could of been worse and I'll never do that again.
Steve
U812 is offline Find More Posts by U812
Old Dec 14, 2003, 04:49 PM
U812 is offline
Joined Sep 2002
Here's the nose I'm referring to if you didn't see it many pages back.
I used the aluminum taped Jim referred to a ways back. Works very well, cheap and has no writing on it. Got it from Home Depot.
Steve
Old Dec 14, 2003, 06:21 PM
AMA 670207
Joined Oct 2000
Steve
D'oh!
I hate it when that happens! At least she wasn't a total write off. I am replacing my antenna with one of those new Litennas to prevent this sort of problem in the future. Check out the thread here:
Old Dec 14, 2003, 07:11 PM
RandyL is online now
Find More Posts by RandyL
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Kevin, I too have better than 2 years of flying on my direct drive 400's. I see no need to use anything else. What you have may or may not work well enough but the extremely cheap 400's do work great. I'd save the 300 gear drives for something else if it were me. At about $4 ea for the 400's you can hardly go wrong with a proven setup. Then again, you may teach us something with the gear drives....
Randy
RandyL is online now Find More Posts by RandyL
Old Dec 14, 2003, 09:38 PM
vise101 is offline
Joined Nov 2002
Thanks for the input guys.
I know the proven setup will work great and what I think I will do is make the motor mounts removable so I can experiment with drives. Like I mentioned before I do have 4 of these things lying around and want to put them in something. Basically if I do this I have all the gear I need. Programable ESC, 3 1500 Kokam packs etc. I know that the amp draw will be much lower and I am looking also for longer flight times at a scale like speed.
If no-one has done this yet I will step up and let you guys know but I thought I would get some feedback first.
Thanks.
Kevin.
Old Dec 15, 2003, 05:44 AM
RandyL's Avatar
Silver Lake, Ks USA
Joined Dec 2000
Kevin... I'm all for it but wanted you to know that the direct 400's work very well. Do you have any prop in mind yet? What is the gear ratio on your 300's?
I'm putting a pair of geared 400's on a project that I've been told will not hand launch due to prop tip speed or some such thing...too techy of me. If it blows enough air, it'll fly.. or not.
Randy
Old Dec 15, 2003, 05:56 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Originally posted by Rudderman98
Sorry. Can't help you on the landing gear issue for I have none on mine. Maybe Steve will jump in.
Perry
So any suggestions on landing gear???
rcav8r2 is offline Find More Posts by rcav8r2
Old Dec 21, 2003, 10:53 PM
R. Carver is offline
Find More Posts by R. Carver
R. Carver's Avatar
Oviedo,FL
Joined Dec 2000
I was thinking of trying these- http://www2.towerhobbies.com/cgi-bin...?&I=LXES09&P=7
And this- http://www2.towerhobbies.com/cgi-bin...?&I=LXES10&P=7
Construction on mine has come to a standstill with the holidays and all. So far I have all the parts cut out and the fuse sheeted and glassed. Still have to sheet and bag the wings.
R. Carver is offline Find More Posts by R. Carver
Old Dec 22, 2003, 12:33 AM
U812 is offline
Joined Sep 2002
The only trouble you'll have is getting the tires up all the way into the wing.
You need to extend the nacelles to accommodate this as in the real plane. The airfoil is just too darn thin back there.
I would use air powered retracts too. Getting a mechanical retract to work is going to take some fancy pluming in the wings.
I got lazy and just used fixed gear. BTW they work just great. It's a real treat to watch her rotate off the runway and the taxi back gets everyone’s attention.
Good luck with it and be sure to post pictures of your work.
Steve
Old Dec 26, 2003, 06:27 PM
ArnoldC is offline
Find More Posts by ArnoldC
ArnoldC's Avatar
Dallas, Tx
Joined Jan 2003
Steve
Ive been watching the progress of your wonderful looking b-29.. I've been debating on building one with a wingspan of 180".. you have enspired me to start construction. The planed powerplant will be 4 astro 40's running on 48 cells.. I will start this project as soon as I bust out my other 2 projects, a cessna 150, and a RES sailplane...
Arnold
ps
keep up the good work!
ArnoldC is offline Find More Posts by ArnoldC
B-29 plans BRADJ Scale Kit/Scratch Built 17 Oct 31, 2013 01:53 AM
Discussion Giant Scale electric B-29 plans! Ryan Archer Scale Kit/Scratch Built 19 Sep 30, 2007 01:24 AM
Ralph Beck H-B W-29 plans? temacc Scale Kit/Scratch Built 1 Sep 09, 2007 05:46 AM
Discussion b-17, b-52, p-38, b-29 plans donanton Electric Plane Talk 5 Apr 05, 2007 10:25 PM
WANTED: Guillows B-29 Superfortress plans,(or equivilent) Demon-Leather Aircraft - Electric - Airplanes (FS/W) 0 Dec 22, 2002 11:32 PM
