Old Jan 09, 2007, 02:09 AM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Yippee!
PDF- Airfoil Templates for hotwire
All you newbies to hotwire,Hope this helps a few out. I will be trying a few myself.
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jan 09, 2007, 06:52 AM
Speedo125 is offline
Find More Posts by Speedo125
Glider guider
Speedo125's Avatar
United States, FL, Sun City Center
Joined Oct 2005
Thanks Doug.
Speedo125 is offline Find More Posts by Speedo125
Old Jan 09, 2007, 05:15 PM
Glendale,Az.
Not a problem, I am getting a price on getting these water jet cut out of mild steel . PM me if interested. Doug
Old Jan 10, 2007, 09:28 AM
John255 is offline
Find More Posts by John255
Pensacola, FL, USA
Joined Dec 2000
A Major contribution!
Thanks Doug.
John255
John255 is offline Find More Posts by John255
Old Jan 10, 2007, 02:21 PM
Glendale,Az.
Thanks John255
Thanks Doug.
John255
I appreciate it, appreciation makes it worth it.
(plus self gratification)
Doug
Old Jan 10, 2007, 02:42 PM
Glendale,Az.
Ok question number two. From the PDF, What would be the most wanted AG series airfoils?
I need numbers and requests to get these water jet cut. The first estimates were $3.00 per airfoil template(top and Bottom)60.00 per set of the PDF.
Unless everyone wants those sizes.
I personally would like
option 1
6" ag-04, 4" ag-11
7" ag-04, 5" ag-11
Doug
Old Jan 25, 2007, 11:02 PM
Glendale,Az.
Well i got some prices, for a full sheet it will cost me two blasters......ouch.
These are .063 mild steel.
I can get the aluminum in the equivalant for 25.00 a set, more to a cut sheet. but from what I have heard, aluminum sucks the heat right out of your cut wire, but I am not sure in this thickness.
I would like to see if anybody knows any cheaper water jet cutters, price per set-no shipping to me is 35.00. That isn't bad considering you get 5 sets of ag-04 from 4", 5",6"7" 8"
and 5 sets in ag-11.
thats a total of 20 pieces for 35.00 +s/h
is anybody interested, I need 20 purchasers to make the deal.
I asked them if they could send me a set to assure me the .dxf file didn't have any issues.
doug
Old Jan 25, 2007, 11:18 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Doug,
Not trying to put a damper on your idea, but why steel/aluminum templates? Seems like overkill. FWIW I follow a lot of the stuff you do. Its always innovative...
soholingo is offline Find More Posts by soholingo
Old Jan 25, 2007, 11:31 PM
Glendale,Az.
I can make positive templates for my builds myself, but I would like to try the compufoil designe templates for the thinner ag airfoils. These thin airfoils are a little more sensitive to MISTAKES when they are 3/8" to begin with. In the 100's of wings i have cut, a tapered thin wing is hard. especially when I just got the materials to try bagging a few.
Thanks for watching....let me know if you are interested in anything, I usually have a few extra somethings laser cut, or pods layin around. (including 3mm coroplast in 5 colors. doug
doug
Old Jan 25, 2007, 11:43 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Why the water cut aluminum? Wouldn't laser cut get you the same accuracy?
Old Jan 26, 2007, 12:46 AM
Glendale,Az.
laser?
I have not researched the metal lasercutting. I am steering towards the mild steel though. maybe I will check into that, doug
Old Jan 26, 2007, 02:07 AM
jkettu is online now
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Stupid question of the day: wouldn't metal (aluminium in particular) templates cool down the wire hence causing all kinds of problems?
jkettu is online now Find More Posts by jkettu
Old Jan 26, 2007, 06:11 AM
kf2qd is offline
Find More Posts by kf2qd
Joined Jul 2006
Template cutting methods
Water jet will cut a much nicer edge than laser will because the water jet abrades the alum. away whereas the laser heats the material and a stream of gas blows the alum. away, not quite as precise control of the surface.
With a water jet you can get right down to a knife edge, none of the heat methods will go that fine or smooth.
You might see if someone could mill the templates for you on a CNC mill, milling is a whole lot cheaper process and in 1/16 alum. would go pretty fast.
kf2qd is offline Find More Posts by kf2qd
Old Jan 31, 2007, 01:56 AM
1Freak is offline
Find More Posts by 1Freak
Dixon IL.
Joined Jan 2007
Wire Template Cutting Methodes
Find a shop that has a Wire EDM machine or a friend that works with one. These are by far more accurate than a water jet. +-.0002 in.
1Freak is offline Find More Posts by 1Freak
Old Jan 31, 2007, 02:30 AM
Chachi639 is offline
Find More Posts by Chachi639
United States, CA, Davis
Joined Sep 2004
How about water jet cutting phenolic?
Regarding the metal templates. Mild steel is only 1/5 as thermally conductive as aluminum, so that helps. The question does come up, though - could the water jet method work for phenolic or formica, etc?
Maybe splintering would be a problem? I have to imagine the water cutter's going to have no problem penetrating. Anyway, just asking. I admire your initiative and ingenuity in trying to source new template production methods.
Chachi639 is offline Find More Posts by Chachi639
Discussion Airfoil templates for Profile? Buzz Bomb Foamies (Kits) 0 Jun 22, 2006 04:07 AM
Parachute made by Airfoil Aviation for Skysurfer Minh Nguyen Parkflyers 20 Aug 23, 2002 09:48 AM
Templates for scratch building??? Grizzly Greg Beginner Training Area (Aircraft-Electric) 5 Jun 25, 2001 11:54 PM
Airfoil choice for flying wing, help needed slowflyer Power Systems 14 Jun 23, 2001 02:20 AM
