Old Jan 10, 2007, 05:10 AM
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by monkamarm2000
but unless you have a wind tunnel to eek out your percent's here and there your still gonna be in good shape looking at watts.
Barry
A simple spring balance or set of kitchen scales is all that’s required to measure static thrust…
Static thrust is not as ‘perfect’ as measuring actual thrust as flying speed (which would require a wind tunnel or air blower of some sort) but it’s still a lot more accurate a measure of actual motive power than measuring Watts at the battery. A simple spring balance is also cheaper than the hardware required to measure electrical power too.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 10, 2007, 03:17 PM
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
Lightning
JetPlaneFlyer - Your beating this thing to death. He asked a question, why do we use watts instead thrust. The answer is simple, because it is easy nobody said accurate.
The little boy asked his mother, "what's lightning?", mother said, "ask your dad he is an engineer" little boy said "I didn't want to know that much about lightning!"
Smile JetPlaneFlyer,
Hurricane Larry
lslewis is offline Find More Posts by lslewis
Old Jan 10, 2007, 04:27 PM
Aberdeen
Joined Mar 2006
Larry... i am an Engineer... i cant help myself
Old Jan 10, 2007, 07:03 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Originally Posted by JetPlaneFlyer
Eric,
I think the original question was asking why everyone quotes output power from the battery (in Watts) rather than quoting thrust (in Kg / pounds or whatever)...
I think he has a very good point because quoting power in Watts in the wires between battery and motor neglects all the inefficiencies and ducting losses in the total system, which as you point out can vary considerably from one system to another...
Ultimately it does not matter a jot how much power we put into the motor, it is how much thrust that we get out that governs performance. I still think my analogy to car gas consumption is valid... If I claimed my car was fast simply because it used lots of petrol (gas) then people would think me insane.
By the way; a 'Watt' is a measure of 'power'... Not just electrical power but any power. It is equal to one Joule of energy per second (in an electrical system it is also equal to Volts x Amps as you said)
Steve
Yup I could have given all the conversion factors that are relevant but it did not answer the question he asked and what I gave, even though short and sweet, did. He actually asked two questions and I did not see any previous posts that addressed it properly except Ed and myself. So if you want to find fault in anything that I wrote answer the question first and help the newby then you can have at me....
Eric B.
AirX is offline Find More Posts by AirX
Latest blog entry: T/A 37 Tweet/Dragonfly
Old Jan 11, 2007, 12:52 AM
Aberdeen
Joined Mar 2006
Eric,
This were the original questions:
Isn't it more correct to measure how many grams, ounce of thrust is actually produce, rather than how many watts is used?
The simple answer to this is 'Yes'.. in terms of flying performance it is more 'correct' to measure thrust.
I thought if a EDF have an efficient motor and ducting and duct fan can produce the same amount of thrust at a lower wattage than as system with less effecient motor, ducting and Duct fan system at a higher wattage?
Again... simple answer is 'Yes' an efficient system can produce more thrust on lower watts than an inefficient one.
Are they simple and concise enough?
Steve
Question Would Matt's 7mm shaft be good for a beginner Wantafly Electric Heli Talk 3 Dec 21, 2004 08:06 AM
li-poly cells for high power EDF's? Doc Watson Electric Ducted Fan Jet Talk 18 Sep 26, 2003 02:32 PM
Kontronik ESC's-- Can they be used for any dual brushless? Clayton Power Systems 1 Feb 01, 2003 12:00 AM
Bungee setups for light edf's? David Hogue Electric Ducted Fan Jet Talk 4 Jul 31, 2001 10:55 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
