Old Jan 08, 2007, 11:31 PM
jascamera is offline
Find More Posts by jascamera
Joined Jun 2006
Question
Why, EDF's power seem to be measure for Watts?
I am somewhat new to EDF, just got a Het F-18 couple of weeks ago. Flys sweet. What I want to ask is, why everyone seem to measure how fast, how powerful by how many watts a power system pulls. Isn't it more correct to measure how many grams, ounce of thrust is actually produce, rather than how many watts is used?
I thought if a EDF have an efficient motor and ducting and duct fan can produce the same amount of thrust at a lower wattage than as system with less effecient motor, ducting and Duct fan system at a higher wattage?
jascamera is offline Find More Posts by jascamera
Old Jan 08, 2007, 11:52 PM
roadhogtri is offline
Find More Posts by roadhogtri
Bakersfield, Ca
Joined Nov 2004
Alot of guys are running similar systems on the F-18, therefore know how each system performes. You're right about power to weight ratio an effeciency, but most measure watts just to get a ballpark figure .
roadhogtri is offline Find More Posts by roadhogtri
Old Jan 09, 2007, 12:51 AM
Richie Simpson is offline
Find More Posts by Richie Simpson
Pittsburgh,PA.,USA
Joined Mar 2006
Watts is a measure of Power, more power the faster the fan turns, making more thrust & speed.
Efficiency in motor means it will run longer not faster
" in ducting means it will make more thrust on less power (watts)
Light weight means it will accelerate quicker, not go faster
Bottom line is more watts (power) is faster
Richie Simpson is offline Find More Posts by Richie Simpson
Old Jan 09, 2007, 02:08 AM
kriptonic is offline
Find More Posts by kriptonic
kriptonic's Avatar
Los Angeles
Joined Aug 2004
We measure mainly in watts cus we are lazy... and also cus that's what the watt meter reads in,,, Watts......
Gene
kriptonic is offline Find More Posts by kriptonic
Old Jan 09, 2007, 04:55 AM
lslewis is offline
Find More Posts by lslewis
Stilwell Shipyard
lslewis's Avatar
United States, FL, Cape Coral
Joined Nov 2003
Also because the difference in fans (efficiency) is small as is the difference in motors (efficiency). Now all the fan people and motor people are going to flame me. I acknowledge that a specific fan with a specific motor in a specific application can be better than another. But I am talking generalities and that includes "because we are lazy"
Hurricane Larry
lslewis is offline Find More Posts by lslewis
Old Jan 09, 2007, 05:34 AM
birdseed is offline
Find More Posts by birdseed
birdseed's Avatar
sussex England
Joined Jun 2002
If it helps as a rough rule 1 W of power gives you 2g of thrust. So 1000W give 2 kg of thrust.
birdseed is offline Find More Posts by birdseed
Old Jan 09, 2007, 06:29 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I canít help but pick up on a few of these points...
Quote "Efficiency in motor means it will run longer not faster"
IMHO this is not true ... An efficient motor will convert electrical energy to mechanical work more efficiently... That means for a given electrical power input in Watts, it produces more torque or spins faster (or both) than an 'inefficient' motor. If the electrical power input in Watts is the same then length of run will be the same regardless of motor efficiency. You can only increase run length by reducing the Watts or by increasing the capacity of the battery.
Quote: "Light weight means it will accelerate quicker, not go faster"
This would be 'almost' true for a car or any vehicle supported on wheels, however it is not the case for an aircraft in flight... Induced drag is proportional to lift and lift (in level flight) is equal to weight. Therefore more weight = more drag and more drag = lower flying speed.
Quote: Bottom line is more watts (power) is faster
This is way over simplified... there are lots of factors to be considered, motor input power is one variable that effects top speed but it's probably not the most important... Drag for instance is proportional to the airspeed squared therefore reducing drag is a far more effective way of increasing top speed than increasing power.
Assuming that your model will be fast just because it uses up lots of Watts is like assuming your car will be fast simply because it consumes a lot of gas
The 'real' bottom line is electrical Watts do not push an aircraft forward, thust is what we are really after. As mentioned previously I suspect Watts is used simply for convenience on the assumption that it is reasonably proportional to thrust... This assumption may or may not be the case depending on other design variables.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 09, 2007, 07:16 AM
perttime is online now
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
Not really. More power may give you more speed or more thrust. Just like with propellers: depending on what propeller (fan + inlet + thrust tube) you use, you get more speed and/or more static thrust.
perttime is online now Find More Posts by perttime
Old Jan 09, 2007, 07:34 AM
IAD is offline
IAD
Find More Posts by IAD
IAD
UAV Driver
IAD's Avatar
New England, USA
Joined Nov 2002
Or, more watts on a given fan will give you more speed and thrust.
~Luke
IAD is offline Find More Posts by IAD
Old Jan 09, 2007, 11:04 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Thrust output can change with different exhaust diameters as well. Watts is probably the best measure, and not everyone has a thrust stand to measure with, and thrust can change when installed in a model, due to intake layout, size, smoothness, etc.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jan 09, 2007, 12:08 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Actually horsepower of motor alone wont say car is fast, but watts are like a measure of power to the wheels, since the motor see's the load the impeller creates, so it is a very good measure of just how fast your plane will go. I couldnt count how many planes I actually measured or cared how much thrust it had, but I always check the "installed" watts.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 09, 2007, 08:06 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
The reason why watts are used as the measure of power thru a fan or propellor is the system is electrical and the watt is the measure of power thru an electric motor(amps X volts = watts), it is directly convertible to horsepower as 750watts = 1hp.
Ducting can be disastrous to the airflow to and away from the fan where you can loose up to 30% of thrust with poor ducting and 5% to 10% with good ducting, rarely do you loose nothing as compared to no ducting, simply because of drag from wetted area.
This is all covered in high school and college physics books, not spelled out directly but all the concepts are there.
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 10, 2007, 01:11 AM
Aberdeen
Joined Mar 2006
Eric,
I think the original question was asking why everyone quotes output power from the battery (in Watts) rather than quoting thrust (in Kg / pounds or whatever)...
I think he has a very good point because quoting power in Watts in the wires between battery and motor neglects all the inefficiencies and ducting losses in the total system, which as you point out can vary considerably from one system to another...
Ultimately it does not matter a jot how much power we put into the motor, it is how much thrust that we get out that governs performance. I still think my analogy to car gas consumption is valid... If I claimed my car was fast simply because it used lots of petrol (gas) then people would think me insane.
By the way; a 'Watt' is a measure of 'power'... Not just electrical power but any power. It is equal to one Joule of energy per second (in an electrical system it is also equal to Volts x Amps as you said)
Steve
Old Jan 10, 2007, 01:30 AM
perttime's Avatar
Finland
Joined Nov 2004
Steve
Yup. It is a part of the metric system where everything is connected.
Old Jan 10, 2007, 02:04 AM
Joined Aug 2002
but unless you have a wind tunnel to eek out your percent's here and there your still gonna be in good shape looking at watts.
Barry
Question Would Matt's 7mm shaft be good for a beginner Wantafly Electric Heli Talk 3 Dec 21, 2004 08:06 AM
li-poly cells for high power EDF's? Doc Watson Electric Ducted Fan Jet Talk 18 Sep 26, 2003 02:32 PM
Kontronik ESC's-- Can they be used for any dual brushless? Clayton Power Systems 1 Feb 01, 2003 12:00 AM
Bungee setups for light edf's? David Hogue Electric Ducted Fan Jet Talk 4 Jul 31, 2001 10:55 AM
Will the new CP1300's be suitable for this? Slope Nut Power Systems 3 May 21, 2001 02:19 PM
