Old Jan 08, 2007, 04:32 PM
TheSaint is offline
Find More Posts by TheSaint
Deported Village Idiot
TheSaint's Avatar
A roamin' in the gloamin again
Joined Jun 2006
Question
Density of "Aircraft" ply vs Balsa?
As an alternative to sheeting surfaces in 1/16 balsa, something a little less fragile?
Was thinking ditching 1/16 bals in favor of 1/16 or even 1/32 ply.
Anyone got any figures on relative densities?
TheSaint is offline Find More Posts by TheSaint
Old Jan 08, 2007, 04:39 PM
SoCalGliderFlyr is offline
Find More Posts by SoCalGliderFlyr
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
Seen great results with 1/64" vernier. Keep thinking it was NOT poplar. Might have been birch. Also depends on what you are sheeting -- foam, structure?
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
Old Jan 08, 2007, 05:01 PM
TheSaint is offline
TheSaint's Avatar
Joined Jun 2006
Sheeting wings over rib substructure, no foam involved. Maybe also use on a fuse, but soaking ply in boiling urea per someone's advice doesn't sound too good.
Old Jan 08, 2007, 05:26 PM
Think Thermals!!!!
Joined Mar 2004
Don't think you will have to soak 1/64" vernier in boiling water. Depends on the radius of the curves. If you want to wrap it around a very small leading edge then you might have to steam it or soak it then let it dry wrapped around a mandrel such as a length of 1/8" diameter music wire. Vernier is not plywood as it is a single layer.
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
You can get 1/32" basswood sheets 3" wide and length of 24", 36" and 48". The basswood (21.8# per cubic foot) is about 2.18 times of balsa (10# per cubic foot) medium density.
See:
http://www.lonestar-models.com/cgi-local/Order.pl.cgi
Balsa density comes 4# to more than 24# per cubic foot! Basswood has more uniform density numbers.
Ollie is offline Find More Posts by Ollie
Old Jan 09, 2007, 08:30 AM
TheSaint is offline
TheSaint's Avatar
Joined Jun 2006
Plan is to sheet the upper and lower surfaces of the wings, not round LEs, which are pre-formed.
Ultimately I'm gonna glass the thing so I may just stick with balsa, rather than have the double whammy of heavier wood plus more weight from the glass.
Old Jan 09, 2007, 08:47 AM
Think Thermals!!!!
Joined Mar 2004
When balsa gets saturated it will droop between the ribs. Best to use something that is the same weight per square inch but has more support for a glassed surface.
Old Jan 09, 2007, 09:19 AM
TheSaint is offline
TheSaint's Avatar
Joined Jun 2006
The balsa will have to be soaked in alcohol to get it to bend in 3D so it'll be saturated when applied. It should then dry out and come "drum tight" as a result?
Old Jan 09, 2007, 11:51 AM
TheSaint is offline
TheSaint's Avatar
Joined Jun 2006
Quick sums say 1'll be adding about 1 3/4 to 2 lb to the weight of the model if I use ply. Forget I ever asked !
Lite-ply vs. Balsa... catfishchaser Scale Boats 4 May 18, 2012 05:51 AM
Carbon rods vs balsa stringers Martin Hunter Electric Plane Talk 3 Nov 24, 2002 08:44 PM
F3 vs Balsa crossup Foamies (Kits) 3 Oct 15, 2002 10:31 AM
foam vs balsa construction... Arbo Power Systems 3 May 08, 2002 08:53 AM
carbon vs. balsa weight kist2001 Power Systems 4 Aug 03, 2001 12:32 AM
