Old Jan 07, 2007, 02:11 PM
FatBill is offline
Find More Posts by FatBill
Joined Jun 2004
electric conversion of a ramtec fan
I have a Josh Harel A-10 that is designed for twin OS91vrdf's and Ramtec fans.
Does anyone know if there is a suitable brushless moter that would run these fans?.
FatBill is offline Find More Posts by FatBill
Old Jan 07, 2007, 02:18 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Not that I've heard of yet but somebody's bound to try it. I've seen that big A-10 fly at the QSAA Giant scale rally back in the 90s and lets just say there wasn't a lot of excess power there, it was a huge airplane to push around on those fans. The nacelles are huge, you could go with a larger fan if there was one. Well there is, the Byron Byrojet, some guys in Arizona are converting them with some Hacker outrunners. Don't recall the wattage their getting but probably more static thrust than a ramtec would do since it's a larger fan. I don't know if you have molded nacelles or you're doing an all balsa project but if balsa then you could change the design to suit the byron.
I believe Josh Harel's original design used his 3 bladed cut down master airscrew and custom designed 8" housing for power. If you ran that on maybe some outrunners that might be even better but I don't know what the flight speed would be. I heard the glow motors were throwing prop blades so that's why the guys in Denver who built the ones I saw went with the glow fans.
good luck
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jan 07, 2007, 05:37 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
yeah its a tall order right now for ramtec and dynamax stuff in regards to motor and ESC's . Bruff is messing with Byro stuff right now with some good result's, and parts for conversion are supposed to be available soon from EJF.com.
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 07, 2007, 05:40 PM
Whistling Watts is offline
Find More Posts by Whistling Watts
Braintree, Essex
Joined Mar 2006
Big fans
Winmodels made the wm2000 fan 125 mm for ivan goodchilds big a10, not cheap and you might wait for ever for delivery, but these would be the ultimare.
Otherwise the e-turbax might be a fair coice.
Steve
Whistling Watts is offline Find More Posts by Whistling Watts
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
yes it is a new model called a turbine!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jan 08, 2007, 08:01 AM
Braintree, Essex
Joined Mar 2006
Take this man out and give him a cigerette and a blindfold Get out of this thread!
Old Jan 08, 2007, 10:27 AM
gbruce is offline
Find More Posts by gbruce
gbruce's Avatar
Canada, AB, Airdrie
Joined Oct 2001
LOL good one whistling...
I have the Giant Jets F-16A semi kit from Josh Harel and I think a twin Byron conversion of his A-10 would be Perfect,and relatively inexpensive.
The Dynamax and Ramtec are a little on the small side for this one IMHO
From the looks of the plans that I have you could EASILY loose a few pounds just by substituting foam or hard balsa in alot of non structural areas....it calls for plywood EVERYwhere
I am working towards this build by getting the EDF setup and finding out it's capabilities on a sport jet before Diving into a huge build like the F-16 or in your case the very cool ,but very large A-10.
Bruce
gbruce is offline Find More Posts by gbruce
Old Jan 08, 2007, 11:23 AM
Braintree, Essex
Joined Mar 2006
new big fans
There is something going on in Germany on big edf and new fans at the moment. If I told you I would have to kill you
Sold Byron 6" fan w/ electric conversion bruff Aircraft - Electric - Jets (FS/W) 4 Sep 07, 2007 11:41 AM
Glow to Electric Conversion Ninjak2k Electric Plane Talk 5 Sep 04, 2006 08:08 PM
Modeltech ME 109 Electric Conversion Which Prop? Joe Elston Electric Plane Talk 6 Jul 09, 2002 07:34 PM
Eaglet 20 electric conversion endoplasma geared DanE Electric Plane Talk 9 Jul 05, 2001 11:59 PM
GP T-Craft electric conversion Joe Elston Electric Plane Talk 3 Jun 15, 2001 10:36 PM
