Old Sep 18, 2002, 08:04 PM
Q-HUNTER is offline
Find More Posts by Q-HUNTER
Thats gona be expensive
Q-HUNTER's Avatar
Glenside Pa
Joined Jul 2001
Sig LT25
Looking to power a LT25.
New area to me I usually fly sailplanes...
I really, really like direct drive but if I absolutly must use a gearbox I will.
I like climbouts at 45 degrees or better.
I like thrust not speed. ( I know, I know, geared is better for this) Can run from 8 to 16 cells. Are the new AXI motors too small?
Also would like to keep out of the welding amp ranges (60-100).
Pretty damn pushy huh
thanks Ken
Q-HUNTER is offline Find More Posts by Q-HUNTER
Old Sep 18, 2002, 09:10 PM
Bill Germanson is offline
Find More Posts by Bill Germanson
Name it, I've crashed it
Bill Germanson's Avatar
JAX, FL
Joined Feb 2002
LT-25 power options
Your a lucky man, IMO, to be having such a problem. I've been wanting to build a LT-25 for a while but have been focusing on other projects. I've attached 2 links that I saved for when I get my chance.
http://members.aol.com/KMyersEFO/page10.htm
http://www.ezonemag.com/articles/199...sig_lt25.shtml
I also had a few email conversations with Bernard Cawley (BEC here on EZone) about his LT-25 and his power choices. If you need more info you may want to drop him a PM.
Good luck,
Bill
Bill Germanson is offline Find More Posts by Bill Germanson
Old Sep 19, 2002, 12:29 AM
jmelzer is offline
Find More Posts by jmelzer
Gravitationaly Challenged
jmelzer's Avatar
La Canada, CA USA
Joined Oct 2000
Jeti 45/3
Jeti 70 amp ESC w/BEC
APCe 13X8 prop
Graupner prop adapter/ spinner
12 - RC2400s (3000 NiMH might be better)
Aero Vee MM1 motor mount
mods:
Nylon LG bolts
Bolt on wing
one servo ( Hitec 81mg) for each Aileron - can be used as spoilers
Top hatch for batteries
AUW - 83 ounces - over 100 watts / pound = about 7 mins
Have fun - This is a great building kit
jmelzer is offline Find More Posts by jmelzer
Old Sep 19, 2002, 12:30 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
Check out my build and fly thread as well as the previous resources. I went from a Turbo 10 brushed motor to a Mega 22/30/2. All the details in my thread. The Mega will give you thrust. I'm running 14 3000HV cells. My weight is 88 ozs. When I take off the LT can climb much better than 45 degrees. The glow flyers are impressed. I can't wait to try 16 cells.
My current specs are
Mega 22/30/2
Superbox 3.33:1
14x7 APC prop
14 Sanyo 3000HV
40amp Model Motors 40-16 ESC (same as MGM Compro)
http://www.rcgroups.com/forums/showt...ghlight=newbie
Kelvin
kelvin is offline Find More Posts by kelvin
Old Sep 19, 2002, 02:45 AM
cwalsh is offline
Find More Posts by cwalsh
Transfixus sed non mortus
cwalsh's Avatar
Joined Nov 2001
Hi,
Jmelzer : I use the same power system in my SIG Somethin'Extra, nice power package, capable of powerful areobatics for 6 mins. Not unlimited, but almost.
BR,
C.
cwalsh is offline Find More Posts by cwalsh
Old Sep 19, 2002, 09:11 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Ken
Check out GaryK on his experiences with an AXI2820/10 and ten cells in his Skyvolt. I've seen that one fly, quiet and with plenty of power. Suggests the same rig would power a LT25 well. I've gotten a Cuban 8 out of a LT25 on a geared Magnetic Mayhem on ten cells. Okay, not a big C8, but it didn't drop any height doing it. The AXI would be more powerful and more efficient.
OTOH, if you can run to 16 cells and can fly, why diddle around? Start with a brushless equipped Four Star 40 instead. Great flying model, and it's way easier to build a battery tray and access hatch into a low winged model than a high winger.
If you want peace and quiet over whining gearboxes, there's rumour of an AXI outrunner for 16 cells "coming soon" to the US, or contact Tom Hunt at MAT about his Mega motor / Beltdrive combos. Bit noisier than straight drive, quieter than gearing.
Regards
D
Dereck is offline Find More Posts by Dereck
Old Sep 19, 2002, 10:44 AM
fbw4 is offline
Find More Posts by fbw4
fbw4's Avatar
Phoenix, AZ
Joined Oct 2001
You may want to consider the Hacker B50 13S geared 6.7-1. This is a very popular motor for dozens of planes and gives me unlimited vertical performance in my LT-25 on 12 or 14 cells. Check out my web site for all the information and video.
http://www.rccraze.com/lt25.html
fbw4 is offline Find More Posts by fbw4
Old Sep 19, 2002, 12:45 PM
n3jpu is offline
Find More Posts by n3jpu
Silver Spring, MD
Joined Aug 2001
Hi Ken,
I recently built a LT-25 with the AXI motor. here are some links of the build process.
http://www.rcgroups.com/forums/showt...479#post358479
http://www.rcgroups.com/forums/showt...5&pagenumber=1
I also have a few short video's of take-off and landings on my website. http://www.mitchelson.org and click on the e-flight button.
Gary
n3jpu is offline Find More Posts by n3jpu
Old Sep 19, 2002, 01:05 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Ken,
I think there are three viable direct drive candidates for the LT-25 right now (read, among other things, readily available in the US). Listed in my guess of increasing available performance without toasting things:
AXI 2820/10 on 10 cells, 12X6 APC-E
(The 2820/12 on 12-14 cells and a prop about the same size - chosen to keep full throttle amps below 35 or so, should also work.)
Jeti Phasor 45-3 on 10 cells APC 14X7E (I've flown this combo) or the 12 cell combo jmelzler reports on above.
Mega ACn22/45/3 on 10-16 cells with appropriate prop choices depending on cell counts.
I am flying a larger, heavier plane on my AXI 2820/10 with the 10 cell system (the JK Aerotech Big T) and it performs much as you describe you would like to see. I am sure it would pull my LT even better (the one in the second link that Bill Germanson points to) but right now it has a Hacker B50L-13 geared in it on 14 CP1700s and can go straight up .
There are bigger outrunners available in the Aeronaut/Kohler Actro line that will do what you want, but there's no US source for them that I know of and the price jump is a big one above any of the three I mention and an appropriate Czech-made (like the motors) 40-50A controller (Jeti Gold label, MGM ComPro, or Jeti/Hacker).
BEC is offline Find More Posts by BEC
Old Sep 19, 2002, 07:25 PM
Q-HUNTER is offline
Q-HUNTER's Avatar
Glenside Pa
Joined Jul 2001
You guys are great!
I actually have a 28/20 10 sitting here.
I didnt think it had enough A** to do the job, but I will try that combo first.
And progress from there.
Derek, I just ordered a four star 40. the same time I ordered the LT25.
I was going to wait on the 4star but that may actually go first. Power system should be about the same.
THANKS ALL
Old Sep 20, 2002, 11:13 AM
mudfarmer_mike is offline
Find More Posts by mudfarmer_mike
Senior Member unum multum
mudfarmer_mike's Avatar
United States, AL, Huntsville
Joined Dec 2001
RE: LT-25
I have thought about using the AXI 2820/10 in my LT-25. I've noticed most of the LT-25 are coming in at an 80+ oz. AUW. I'd like to keep mine around the 70 oz. mark. Do you think this is feasible?
mudfarmer_mike is offline Find More Posts by mudfarmer_mike
Old Sep 20, 2002, 01:37 PM
edbuell is offline
Find More Posts by edbuell
edbuell's Avatar
Saratoga County, New York, United States
Joined Jul 2002
LT-25 Building
My Lt-25 should arrive tomorrow. This will be my first building project. It seems that several of us will be working in parallel.
I appreciate all the helpful tips and hints that come along.
I don't expect to build mine very fast, because I really like to ponder twice and cut once.
This will require some pondering on my part . My plans are to put servos in the wing. to move the tail end servos aft and place the power pack track down the middle. I will proabably follow a bunch of the hints from Kelvin Ritchie's project documented here.
Good Luck
Ed Buell
edbuell is offline Find More Posts by edbuell
Old Sep 20, 2002, 06:41 PM
kelvin is offline
Joined Jan 2002
Keep us posted on the construction. I'm going to recover mine this fall. I'm going to add a fairing on top of the wing adjacent to the F2 former and modify the hatch to cover the motor. I'm going to try to use small magnets instead of hinges.
If you use nylon bolts for the wheels use 10-32. I've had some bad luck with landings and the 10-32 bolt heads will strip off saving your fuselage from having the ply plate ripped out.
The wing blot mod is nice and putting the servos in the wing and direct connections is a nice mod. I may do that also.
Kelvin
Discussion Sig LT25 Conversions.. Let's see your motor mounts.. Tram Sport Planes 12 Sep 28, 2006 10:34 PM
Any Sig LT25 conversions DBono99 Glow to Electric Conversions 26 Dec 26, 2005 06:00 PM
ARF Sig LT25 FS powersmo Aircraft - Electric - Airplanes (FS/W) 1 Apr 27, 2003 10:01 AM
f/s Sig LT25 Q-HUNTER Aircraft - Electric - Airplanes (FS/W) 1 Oct 10, 2002 03:49 PM
Sig lt25 Roy G Johannsen Sport Planes 14 May 07, 2001 01:27 AM
