| Billet Bullet ’’Hot Wind’’ Single | |
| Specifications: | |
| Weight: | Weight- 20-24 grams (depending on options) |
| Max AMPs: | 10 AMP |
| Propeller: | 7x3.5 GWS HD on 3s |
| Propeller: | 8x4 GWS HD on 2s |
| Thrust: | 15-22oz |
| Pitch Speed: | 50-70 mph |
| Billet Bullet ’’Cool Wind" Single | |
| Specifications: | |
| Propeller: | 8x4 GWS HD on 3s |
| Propeller: | 9x5 GWS HD on 2s |
| Thrust: | 15-19oz |
| Pitch Speed: | 30-40 mph |
| ESC: | Castle Phoenix 10 and Thunderbird 18 |
The CustomCDR 'Cool Wind' Single with available "wobbly" prop adapter |
| US distributor: | CustomCDR |
| Available From: | CustomCDR |
CustomCDR has two brushless sub-ounce motors that have really brought our smaller ships to life.
Although these motors are very small and light they do not lack power. We could not wait to get them mounted and flying! Lets take a look at these great little powerhouses.
Motors Include:
Motors require:
Deans makes a micro-size 3-pin unpolarized connector that works wonderfully for this purpose. Unfortunately, the 3-pin unpolarized connectors have recently been hard to find so we used the 4-pin polarized connector with the last offset pin removed.
Both motors include a high quality integrated firewall mount that has three legs that extend beyond the motor bell. The engines accept small servo-type mounting screws to mount to the firewall, but they can also be ordered with a tube type mount.
Ronnie's thoughts on the CustomCDR 'Hot Wind' Single motor: The motor is small and very light. This is important for the A-7 pusher jet, which needs a light motor to achieve the proper CG. I highly recommended it for this application.
Mike's thoughts on the CustomCDR 'Cool Wind' Single motor: This motor is an excellent choice for park flyers that swing 7" to 9" props. It worked well for the Mini Sport.
RCGroups member Dr Kiwi tested both of the motors on a 3s pack with the following results (posted with his permission - thanks Dr. Kiwi!):
| Billet Bullet ‘Hot Wind’ Single | |||||
| APC E Props | Volts | Amps | Watts | RPM | Pitch Speed(mph) |
| 4.2x4 | 10.9 | 3.65 | 40 | 16170 | 61.3 |
| 4.5x4.1 | 10.7 | 4.45 | 47 | 15450 | 60 |
| 5.25x6.25 | 10.9 | 10.1 | 110 | 13530 | 80.1 |
| Zagi 5.1x4.9 | 10.9 | 7.05 | 77 | 14850 | 68.9 |
| Billet Bullet ‘Cool Wind’ Single | |||||
| GWS HD Props | Volts | Amps | Watts | RPM | Pitch Speed(mph) |
| 7x3.5 | 10.9 | 4.9 | 54 | 12240 | 40.6 |
| 8x4 | 10.9 | 9.4 | 101 | 10020 | 38.0 |
| 9x5 | 9.9 | 10.55 | 104 | 7410 | 35.1 |
As shown in the numbers above, these are both very strong little motors. The bearings are smooth and the cogging is very strong on both motors making it clear that high quality curved magnets are used and that the stator to magnet gap is very small. The machining and anodizing work are excellent.
The Castle Thunderbird controllers used with these motors started them without stuttering or hesitation. For more information on the Castle ESCs please see Castle.
Total weight of each motor not including the prop adapter is just .85 oz.
Since the ‘Hot Wind’ motor is really for faster ships, we installed it on a pusher type jet: a semi-scale A-7 Corsair designed by friend and fellow flier Doug Cohen.
The A-7 with the 3S 1320 DualSky pack weighed in at 13.8 oz. I used an APC-E 4.5x4.1 prop on this plane. The CustomCDR 'Hot Wind' single proved to be the perfect power plant for the A-7. It's easy to mount, extremely lightweight and has significant power for it's size. The A-7 Corsair has a broad speed envelope and the 'Hot Wind' Single performed flawlessly at all speeds.
For the ‘Cool Wind’ motor we selected the Herr Mini-Sport airplane. This 36” span plane tips the scales at 12 oz. with a 3s 350Mah Tanic pack. Since we were trying to keep the amp draw at around 5 amps to accommodate the 15C pack, the the GWS 7x3.5 HD prop was chosen for this aircraft. As the video illustrates, The ‘Cool Wind’ motor provides plenty of power for this small airplane.
The ‘Cool Wind’ motor and the Herr Mini-Sport make an excellent combination. Even though the motor is capable of nearly twice the power, I used the 7x3.5 propeller to be kind to the smaller cells used with the Mini-Sport. The 5amp draw and GWS HD 7x3.5 propeller still give this airplane more power than it needs. It has enough power for continuous loops and great rolls.
The ‘Cool Wind’ motor would also make an excellent choice for small 3D ships. The bearings are of a high quality - something missing in a number of the overseas motors that we have seen on the market recently.
As you can see, these tiny motors don’t lack power. The A-7 is propped for 10 amps and the Herr Mini-Sport is propped for about 5 amps, yet the power is significant!
The single stator Hot and Cool wind motors are winners. The Billet Bullets are indeed bullets! The motors performed flawlessly both in the static amp-draw tests and where it matters... in the air. Even with the included 3 screw firewall built-in mounts, they are amazingly light.
Plusses:
Minuses:
These are very impressive and light power plants. We were both happy with the quality and the power these little monsters put out. For more information, go to CustomCDR.com and order your own CustomCDR Billet Bullet single motor today!
| Thread Tools |
Well I can't fault this review as these motors really are great. They are my workhorse for all types of planes. Steve |
Latest blog entry: WATTS over Owatonna
But I can tell you - these little motors are fantastic - super for use where light weight is key - yet you can pump 10 amps through them.... I have the red hot single in a HL Lynx right now - I can tell you with the 5.25x6.25 prop and a tad over 10amps and it goes like stink! Nothing negative about these little motors they are fantastic! Mike |
From what I can tell, they only bother to put the good stuff into an article. In E-Zone...no news is BAD news!
When there will be some NEGATIVE reviews on the E-Zone? That is what is nice about RCG and these forums ... if YOU disagree with something you read and your experiences are otherwise, you are free to post it for all of us to see and discuss as mature adults.
I am ready to test them to get * Io no load versus Voltage * Rm internal resistance @ 20°C * Kv * Thermal behaviour (Kth °C/W and thermal time constant) So I could judge with my software the complete performances and compare with competitors. It's up to you Louis |
| Thread Tools | |
| Sold CustomCDR Cool Single (Billet Bullet) | adamg | Aircraft - Electric - Power Systems (FS/W) | 2 | Nov 15, 2006 09:42 AM |
| Sold CustomCDR Cool Wind Single w/ backplate and propsaver $35 shipped | verruckt | Aircraft - Electric - Power Systems (FS/W) | 5 | Oct 25, 2006 12:01 PM |
| Wanted CustomCDR "Cool Wind" Billet Bullet | Ted U | Aircraft - Electric - Power Systems (FS/W) | 1 | Jan 16, 2006 11:29 PM |
| Jeti Phasor 30/3 and 45/3 brushless motors review! | dave_lilley | Electric Plane Talk | 0 | Oct 25, 2001 12:00 AM |
| Jeti Phasor 30/3 and 45/3 brushless motors review! | dave_lilley | Site Chat | 0 | Oct 25, 2001 12:00 AM |
