Old Apr 29, 2007, 01:04 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by PLATINUM
Great review!
I have one of these with a Medusa on a 6x4 on 2250's.. vertical out of site, 90mph dives.. and about 75-80mph level flight.. I have to tape the canopy on. Somewhere there is a lipo in a field launched from the canopy popping off.
If you plan on putting an uber motor in this. The stock canopy latchs are not enough.
I don't think the Lipo was launched because the canopy came off. I think it was rather the other way round. My Lipo is secured with a velcro strap, and the stock canopy holders are good for well above 100mph.
Jurgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 01, 2007, 08:38 AM
stuka is online now
Find More Posts by stuka
Marshfield, Wisconsin, United States
Joined Sep 2002
Would a 2025-5300 HImax and a four inch prop fly this? I dont need blistering speed, but would appreciate decent stability?
stuka is online now Find More Posts by stuka
Old May 01, 2007, 09:32 AM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
stuka,
I think that's a little too high kV; the FunJet likes thrust as much as speed, so a 4" prop is pretty small for this application.
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old May 01, 2007, 11:09 AM
stuka is online now
Joined Sep 2002
Kind of what I thought. Thanks for the input. Im still getting a hang of brushless equivelents vs brushed etc.
Old May 02, 2007, 08:46 AM
stuka is online now
Joined Sep 2002
ON the other hand, what about outrunners on this and similar such as the Stryker etc? The high pitched noise of direct drive is a concern in town, and outrunners seem to have this under control.
Old May 06, 2007, 12:43 AM
r1derbike is offline
Find More Posts by r1derbike
Yankin' and Bankin'!
r1derbike's Avatar
Bella Vista, AR
I've got one that I'm putting my old Stryker's running gear in, as soon as I open the box. I had a servo failure that caused my old Stryker to auger-in very nicely. Never did find the battery, either.
I got another Stryker, but needed something to put the motor and esc in, and voila!
Charles
r1derbike is offline Find More Posts by r1derbike
Old May 06, 2007, 02:39 AM
Joined Sep 2000
It does not matter whether you use an inrunner or an outrunner. It is the disturbed airflow which hits the prop at high rpm which causes the noise.
Running a prop with higher pitch at lower rpms helps in this area, but they are less efficient at lower speeds, as they are usually running in stalled conditions then.
Jürgen
Old May 06, 2007, 08:41 AM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
stuka,
I run a "CDR Hot Wind Double" outrunner motor using a 6x5.5 prop. The noise is loud enough to drown out some nitro birds. As Jürgen says, inrunner or outrunner does not determine the noise developed.
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Nov 03, 2007, 05:58 PM
GassPasser is offline
Find More Posts by GassPasser
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
Have The Kit, Will Build.
GassPasser is offline Find More Posts by GassPasser
Old Nov 03, 2007, 11:21 PM
faststick is offline
Find More Posts by faststick
faststick's Avatar
BOTHELL,WA. NORTHEAST OF SEATTLE
Joined Jun 2005
I powered mine with a kontronik 400-28, a t-bird 54 amp esc, 5.5x4.5 apc, it peaks at 46 amps with 380-395 watts. I like the 3s 2200-20c packs from todd's models. I can run wide open till I can't see strait and not a problem and I think they're only 42 bucks a copy. Been abusing them for months now and no problem. The funjet is a total blast to fly, and where i fly it's on an open hillside, it's a gas to do huge highspeed circuits diving down past you at blistering speeds! I'm getting all worked up can't wait till tommorrow!
Bye now, George
faststick is offline Find More Posts by faststick
Old Nov 04, 2007, 06:45 AM
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
good luck, been trying to finish mine all week. but been busier than ever at work. good luck tommorow faststick.
Old Nov 04, 2007, 11:28 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Just put my funjet back into the air yesterday after not having flown it in a couple months. Kinda forgot the need for speed.
Mine is powered by a Mega 16/15/3 through a 60amp Dynam opto, with a UBEC. HS-65HB's for the servo's since there is no way I would trust an HS-55 or an S-75 to be able to provide enough torque for the surfaces in high speed yanking and banking. The prop is a 6x4 since I like to have lots of thrust to go straight up. I had tried a 5x5 which is a little faster, but I didn't get unlimited vertical with that one.
The batts I use in the Stryker are FP Evo 25 11.1v 2500mAh and when these have run dry, I use a couple Mystery 2100 11.1v 20c cheapies that work great as well.
If the weather cooperates, I'm heading back to the school yard with the Funjet before the seahawks game, oh and of course, the Colts/Patriots game.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Nov 05, 2007, 07:39 PM
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
the colts are the real deal.
Old Nov 06, 2007, 07:05 PM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
This plane is pretty sensitive to CG issues. Balance it just in front of the marks for the first flight or so...
beafraid8 is offline Find More Posts by beafraid8
Old May 27, 2008, 01:51 PM
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
Originally Posted by mike3976
Pretty pork'ey at 102 grams!
finally flew my FJ for the first time today and i guess i got lucky. hand launch went perfect and i didnt have to make one trim adjustment, she flew as if on rails. landing after 7-10 minutes without a scratch. my brother was yelling at his wife to come out and see this thing fly. he thought it was a toy plane and had no idea how fast and great it would fly. heck, my hands are still shacking alittle bit...lol!
Article Stevens Aero Groove Aerobatic Park Flyer Lasercut Kit Review Christine Electric Plane Talk 9 Sep 25, 2009 05:35 PM
Discussion Multiplex Fun Jet tIANcI Pusher Prop Jet Models 12 Oct 16, 2008 11:30 PM
Twinkle - amphibious park flyer - foam? theKM Foamies (Kits) 44 Oct 20, 2005 01:12 AM
GWMP Delta Jet Park Flyer Robert Wick Parkflyers 1 Apr 01, 2004 11:30 AM
GWMP Delta Jet Park Flyer Robert Wick Electric Ducted Fan Jet Talk 0 Mar 31, 2004 03:24 PM
