| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
Thread Tools |
| This thread is privately moderated by zaguruinzasky, who may elect to delete unwanted replies. |
#1 |
Smoke on , go !
What to buy for video piloting. Updated Jul. 07th 2009
Everything in the attached PDF document.
Send me a PM to add a link. Thanks Last edited by zaguruinzasky; Jul 07, 2009 at 04:13 AM. |
#2 |
Maybe we can have a sticky put up with URL's of all the better sites. It seems to me I just posted something like this, each category with at least a couple of choices.
http://www.blackwidowav.com/ http://www.rangevideo.com/ http://www.futurehobbies.com/ These are a good place to start. Basically I think you should read as many threads as you can and get a feel for what people like and don't like. I haven't personally dealt with all of them. As far as goggles and head tracking, it changes daily. If I say. "Buy this," by tomorrow it will be obsolete. Get something and plan to get something new by summer! BTW, it seems that getting head tracking to work with tx's other than Futaba can be tricky so I will definitely leave that for someone with experience with non-Futaba gear. Pete |
#3 |
I don´t know for sure because I haven´t one but, do you think (experienced fpv flyiers with HT) that starting with HT might be more confusing?
As Pete says, this is evolving almost each day, and if maybe could do the first steps into fpv harder I think would be a good idea waiting a little for the HT But as I´ve said, I don´t have any HT so I don´t know for sure... |
#4 | |
If you look out at your wing tip and turn to that heading you have done a 90 degree turn effortlessly. Even if you have only 45 degrees each side of center, as long as your horizontal FOV is 90 degrees you should be able to see your wing tip. No, I haven't actually done it. I managed to fly head up and locked listening to both of my safety pilots. Next try with head tracking I will make a point of looking around. I think it should make things easier. Pete |
#5 |
Smoke on , go !
Thanx guys for your info.
I normally fly formation flight with Lock On simulator ( www.iat-aerobatic.com )using the TrackIR (www.naturalpoint.com ) head movement tracking system so for me it should be very natural becouse the only difference is the real aircraft and real enviroment. I remember I took about 20 / 30 hours to get used to head tracking but now i can't fly without it... Any goggles link from the many? Thanx |
#6 |
Smoke on , go !
another good website I found is this www.rc-tech.ch (french and english). They got complete system but they'r a bit expensive...
#7 |
Intuitive Circuits has a few OSD's that work off of GPS. These update every 2 sentences. The problem is size. I run 3" ribs and usually put the OSD in the wing between two ribs...
Mighty GPS has a few OEM GPS units you can use to tie into the OSD. |
#8 | |
Pete |
#9 |
Smoke on , go !
I'm adding a lot of links in my first post.. if some user needs them..
#10 |
Smoke on , go !
ok thanx for the links, but now I'm a lot more confused... eheh
from your experience, what products do you think are the best available to date from these manufacturers?? |
#11 | |
Pull out early!
ZaGuru, What are your goals for the plane? There is a very nice predator in the Show Us Your Planes thread with equipment listed. Since the pred is pretty light, I'd order a 500mw 2.4ghz tx/rx set and panasonic kx131 from rangevideo. Goggles, I'd probably go with the red set at futurehobbies. Pan, tilt, headtracker from the above link (anthonyRC) with a Futaba 9CAP Super radio. Diversity receiver (futurehobbies) with two 14db flat patch antennas (or antenna of your choosing). On Screen Display (w/GPS) - Inspire from www.dpcav.com is a really good one (I have one ordered and use the lower Vizion OSD now). www.u-nav.com has a $350 Return to Launch GPS rudder-steerer, and a $200 altitude hold board (ALT3). www.fmadirect.com for a Co-Pilot system (I use FS8) that acts as a wing leveler. After a good 300 watt motor, ESC, rcvr, servos, I'd say most of that $2500 is wrecked. ![]() Dave Last edited by DiveBombDave; Jan 06, 2007 at 10:03 PM. |
#12 |
Hey can you break your links down into categories? Maybe like Video Downlink, Flight stabilization, head trackers?
#13 |
The TrackR1s should be in stock shortly, and this time there should be plenty to go around (I greatly underestimated their popularity!)
www.aeropix.ch/store |
#14 | |
Pete |
#15 | |
Smoke on , go !
| Thread Tools | |
| What camcorder for video ? | Goleith | Aerial Photography | 7 | May 08, 2009 04:52 AM |
| Discussion What to Buy for Indoor Season? | stuka | Micro Helis | 0 | Sep 25, 2006 10:48 AM |
| Question What to buy for T-rex micro, HB2 | Lino | Mini Helis | 9 | Jan 06, 2005 08:20 PM |
| What to buy for my HackerB20-31s | Zagi miester | 3D Flying | 1 | Apr 28, 2004 04:23 PM |
| What to buy for 2nd heli...? | Arne KK | rec.models.rc.helicopter | 3 | Apr 28, 2003 04:01 AM |
