Old Jan 03, 2007, 10:20 PM
jconwell is offline
Find More Posts by jconwell
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
Smiley build log: my first home built micro
I would say its a scratch built, but i'm using the plans from derJuF posted in this thread (http://www.rcgroups.com/forums/showt...=605621&page=7) called "Smiley".
I'm planning on putting the AA components on it, with the motors setup as pullers vs their default pusher setup.
This is my very first home built RC plane so we'll see what happens. Here are the pictures of my progress so far:
jconwell is offline Find More Posts by jconwell
Old Jan 03, 2007, 10:24 PM
epicdoom is offline
Find More Posts by epicdoom
Micro Crazy Man
epicdoom's Avatar
Baltimore, Md.
Joined May 2004
Looks good so far Hope all goes well what Material you using for the build Depron?
Epic
epicdoom is offline Find More Posts by epicdoom
Old Jan 03, 2007, 10:37 PM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
Yup, I just got some 2mm Depron yesterday. Though I think next time I'm gona get 3mm instead. I'm not sure how sturdy the 2mm will be.
By the way...hot cutters are so much fun! LOL
Anyone have tips on how to cut good curves with a hot cutter?
Old Jan 03, 2007, 10:38 PM
ghostmechanic is offline
Find More Posts by ghostmechanic
1 paycheck away from homeless
ghostmechanic's Avatar
United States, KS
Joined Mar 2006
That'll be a neat little plane. I thought about building it too. I ended up building one I created from a couple of plans I saw. I joined them together. I am waiting to test this weekend. I hope it flies. Your doing a great job. Good luck, Steve
ghostmechanic is offline Find More Posts by ghostmechanic
Old Jan 03, 2007, 11:07 PM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
Thanks epicdoom and ghostmechanic! Ghostmechanic, I'd like to see a picture of the model you came up with.
Here are a few more pictures of my progress. Its going faster than I expected.
Old Jan 03, 2007, 11:59 PM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
Almost done...This has been a lot of fun
One question. My little Smiley has a case of the droopy wings. Both wings hand down instead of straight out or a little up. What can i do to fix this?
Old Jan 04, 2007, 01:33 AM
FFFlier is online now
Find More Posts by FFFlier
FFFlier's Avatar
Boston, MA
Joined Nov 2002
You could build a little more structure in the fuse to hold the wings at the correct angle, or run flying wires (thread) from the top of the fuse to the wings to hold them up. Or let the wings droop when the plane is stationary and see if they actually bend upwards when the plane is flying since they are supporting the weight of the plane at that point.
Bill
FFFlier is online now Find More Posts by FFFlier
Old Jan 04, 2007, 03:47 AM
Graham Smith is offline
Find More Posts by Graham Smith
Graham Smith's Avatar
Birmingham / England
Joined Feb 2003
You could put a former in the fuselage in the shape of a shallow 'V" above the centre of the wing. this would push the wings down where they meet in the centre. this will give the wings dihedral, (tips of the wings higher than the root) which is essential if you want the plane to be stable and to turn properly.
By the way nice plane.
The other Graham
Graham Smith is offline Find More Posts by Graham Smith
Old Jan 04, 2007, 12:12 PM
britchris is offline
Find More Posts by britchris
"To Fly is Everything"
britchris's Avatar
athens georgia
Joined Dec 2006
im going to start building the smiley today,think ill cut a one piece wing and score it and brace for some dihedral,thats once ive figured out the wingspan im not sure im printin the plan the right size
britchris is offline Find More Posts by britchris
Old Jan 04, 2007, 01:39 PM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
britchris...I think thats what i'm going to do too, drop the two piece wing design and cut myself a single wing, score it and put a brace on it to hold the dihedral.
I dont like the two piece wing thingy. The only reason that the two piece wing makes sense is that it'll be easier for you to put the reciever and battery in. With the one piece wing it'll be harder. I'm thinking about making a cut in the bottom of the fusalage and inserting the reciever and battery there, with the reciever user interface flush with the bottom of the fusalage.
Another thing i did was put brace in the bottom of the wings about 1 inch outside the fusalage to hold the wing curve.
Old Jan 04, 2007, 02:19 PM
britchris's Avatar
athens georgia
Joined Dec 2006
ok i got a prob with printing the plan for the smiley,anyone got a non pdf of the plan? i cant get the bloody thing to print it right scale ie 22.5 cm wingspan grrrrr
im sure its me doin summin daft lol
Old Jan 04, 2007, 02:35 PM
derJuF is offline
Find More Posts by derJuF
derJuF's Avatar
Lahr / Germany
Joined Jul 2006
hi @ all Smileybuilders
Wait some minutes please, i just prepare the plan as .tif and .jpg with markers for the motors and the pieces for the undercarriage.
Greetings Juergen
derJuF is offline Find More Posts by derJuF
Old Jan 04, 2007, 02:38 PM
britchris's Avatar
athens georgia
Joined Dec 2006
thanks jurgen,your a star
Old Jan 04, 2007, 03:15 PM
derJuF is offline
derJuF's Avatar
Lahr / Germany
Joined Jul 2006
hope you can open the zipped files if you need .tif...
Greetings juergen
Old Jan 04, 2007, 04:06 PM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
derJuf: Your not a star, your a super star! This is a cool little plane
I have a question though. These plans are a bit different then the ones you posted on the AA mod part 3 thread (page 7) that I followed. In the plan you just posted, the fusalage bottom width is almost twice as wide as thes the original plan called for (the long rectangle with the triangle at one end). Did you find that a wider body gave better flight performance? Or is it just a cosmetic change?
britchris: One piece that isnt on this plan derJuF posted is the piece that joins the two fusalage halfs together on the TOP of the plane. The top piece is similar to the long rectangle with the triange at one end, except the rectangle is shorter.
Discussion Build log My first RC boat. SDJ Scale Boats 26 Jan 11, 2009 12:52 AM
Discussion Home built micro 5 gram pager actuator that cost no more then 50 cents to build!!! gguy Scratchbuilt Indoor and Micro Models 13 Dec 02, 2006 12:57 AM
Trying to build my first wing... built up FFF? Newberry Parkflyers 3 Jul 16, 2004 04:53 PM
My First Scratch Built Plane - Thanks Hoppy Andycart Foamies (Kits) 12 Nov 12, 2002 02:22 AM
12 inch home built micro heli, Yeah! RC Gonflyin01 Electric Heli Talk 19 Jul 30, 2002 01:42 PM
