Old Aug 03, 2001, 11:54 PM
WindRover is offline
Find More Posts by WindRover
Joined May 2001
What's hotter than a S400?
Ok, except for going up to a brushless motor or "bigger" motor, what motors would give a better performance than a stock S400, say, for less than $35?
Assume staying with a 7 cell pack and same ESC as comes with the Sky Scooter Pro.
WindRover is offline Find More Posts by WindRover
Old Aug 04, 2001, 12:42 AM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
Turbo 450. It puts out way more power then a 400. Amp draw will increase though, so you'll have to watch your packs. Are you using a geared setup or direct drive? The 450 is also a bit heavier---rob
slowflyer is offline Find More Posts by slowflyer
Old Aug 04, 2001, 10:39 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Be sure you are using a 6 volt vs the 7.2 volt version.
Ball bearing version also has more kick
frankenfoamy is offline Find More Posts by frankenfoamy
Old Aug 04, 2001, 03:39 PM
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
Does the 450 put out more rpm's? K/V?
Foxtrot is offline Find More Posts by Foxtrot
Old Aug 04, 2001, 03:45 PM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Possibly the Multiplex Permax 400BB. I haven't tried it but I have heard good things about this motor.
The Multiplex Turbo 450 is a LOT heavier than an S400, and is actually a slower motor (lower Kv), so though it is more efficient, I wouldn't describe it as "hotter".
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Aug 04, 2001, 06:53 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Change the timing on the S400.
http://www.ezonemag.com/pages/efaq.htm#motor7
Pierre Audette is offline Find More Posts by Pierre Audette
Old Aug 04, 2001, 08:02 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Moved to Modeling Science...
dave_lilley is offline Find More Posts by dave_lilley
Old Aug 04, 2001, 11:06 PM
Northern Ca.
Joined Dec 2000
Ok, so EXACTLY what are you referring to when you say "hotter"? More overall power or what? My friend Greg, uses a Rocket 400 which if I remember correctly is a 4.8 volt speed 400. It of course does not have a very long life span.
Most of us that fly Zagis use the 450 turbo to increase our performance. You can swing a larger prop with it then the 400, I use a 6x5 Aeronaut. It is definately a Hotter/faster setup. It also fits most places that a 400 does. It is priced under $30----Rob
Old Aug 06, 2001, 02:13 AM
Blue Bird is offline
Find More Posts by Blue Bird
Blue Bird's Avatar
Slovenia, Europe.
Joined Nov 2000
Hi!
Is the Turbo 450 the same diameter as speed 400?!
Cheers,
Bostjan
Blue Bird is offline Find More Posts by Blue Bird
Discussion UK Builders - What's better than Solarfilm? S_D The Builders Workshop 6 Nov 02, 2006 12:08 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
What's worse than crashing your Dandy? JamesD Parkflyers 10 Jul 31, 2003 10:29 AM
What's better than epoxy? HIGHFLYER99 Electric Plane Talk 23 Jan 15, 2002 01:59 PM
What's hotter than a S400? WindRover Foamies (Kits) 6 Aug 04, 2001 08:02 PM
