Espritmodel.com Heli Air
Old Jan 03, 2007, 01:46 PM
Inventor
conversion's Avatar
Sweden, Gothenburg
Joined Mar 2005
LiPo - FireSafe Box question ??
Hi.
After seein a couple of lipo fires I got really scared thou I live in an apartment with other neighbours over an under me. I dont have a parkingspace, neither garden to safe-charge my lipo-RTF soo I got me some metal-box at work today, got to put some metal-plate over side-holes, that ar NOT air-tight..
The question goes, if I make it air-tight, can a single cell lipo, say 130mAh explode or get out of this metal-case ? ->>
conversion is offline Find More Posts by conversion
Old Jan 03, 2007, 01:55 PM
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
130mah will not make that much fireworks but it will cause the spark which can bring down the place. I think you are fine with what you have.
If you step up above 1000mah then I would re-evaluate and get a lipo sack.
ymmv
fly_boy99 is offline Find More Posts by fly_boy99
Old Jan 03, 2007, 02:38 PM
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
In general, you don't really want to make it air tight. That just makes it kersplode.
Unterhausen is offline Find More Posts by Unterhausen
Old Jan 03, 2007, 04:55 PM
Inventor
conversion's Avatar
Sweden, Gothenburg
Joined Mar 2005
fly_boy99-
okay, you just get scared up with those nifty youtube.com vids about fires of lipo! thanks for input!
Unterhausen-
I looked over the box once again, n I got some idea about takin thos side-plates n make some minor holes.. for smoke/pressure to get out, but no flames. thanks for input!
/Daniel
Old Jan 03, 2007, 04:58 PM
Inventor
conversion's Avatar
Sweden, Gothenburg
Joined Mar 2005
just curious.. if you buy a air-tight, fire-protected safe.. n kept a lipo that went a'wall n got lit up inside.. would the 'fire' flame up when I first opened later ? (this is spooky how fire works with oxygen..) ?
cheers.
Old Jan 03, 2007, 05:07 PM
Kraeuterbutter's Avatar
Europe, Austria, Burgenland
Joined Mar 2002
first:
maybe you can place such a thing into your box:
http://www.cfs.nl/firepro/
at 150°C (so if there is a fire in your box) the patron starts and kills the fire
if - some problem ? - the mechanical 150°C-mechanism should not work it will start at 300°C anyway...
this patron in a fire-proof box should be great for a further risk-minimation...
and here:
a good link of somebody who has already build some Lipo-Fire-boxes and also tested them with different lipos...
also a lot of pics:
http://www.rc-heli.de/board/index.php?topic=38426.0
before:
after:
there are also other solutions in that thread with pictures
here for example a not so good version:
here, were the cables come out of the box there can in case of fire the flames can come out !!
and they can be - because of the pressure inside - be 2meters long !!!!
so you have to solve this problem (look at the first pictures)
as said: follow the link, and look at the pictures to get some feel of how it can and should be made...
and i think if you consider building one: i would contact KLAUS KOLB in that thread...
he has build some boxes, tested a lot and has so a some experiences
Kraeuterbutter is offline Find More Posts by Kraeuterbutter
Old Jan 03, 2007, 05:41 PM
Joined Mar 2002
video of the box test above:
http://www.klaus-kolb.homepage.t-onl...ipobrand-3.wmv
eek
Old Jan 03, 2007, 05:53 PM
Joined Jan 2002
http://www.rcgroups.com/forums/showp...32&postcount=6
RD Blakeslee is offline Find More Posts by RD Blakeslee
Gear box question Tin Pusher Beginner Training Area (Aircraft-Electric) 2 Jul 31, 2002 11:44 PM
JR buddy box question Hammer Electric Plane Talk 5 Jun 05, 2002 06:03 AM
battery box question avie Electric Plane Talk 7 Apr 01, 2002 12:04 PM
Horst gear box question Harry Mueller Parkflyers 5 Jun 28, 2001 10:28 PM
