Joined Nov 2004
E-power for HOB 36"-ers
One of my first efforts at e-power was to convert my existing HOB P-47 (MPJet .06 diesel powered) to electric. E-powered, my P-47 weighs 24.1 ounces, and is set up with all four flight functions plus Robart 1/2A retracts (which is why it's a bit heavy for that much wing) [BTW, all the HOB 36" kits use essentially the same wing at about 220 SqIn]. On an APC 8x4 E prop, it was a missile--far too fast--, so it flies now with tamed authority on a regular ol' 8x3 wood prop. 10+ minute flights on a 950 mah 23C LiPo pack. Full throttle pulls 12amps, which is 88 (input) Watts/Lb, and is PLENTY for this much airframe. It will cruise (maintain level flight) at about half that much juice. I ended up with about 3 degrees of downthrust and 2 degrees of right thrust to keep the trim changes from power on to power off at a minimum. All the HOBs will be pretty much the same, since they all use the same moments, same wings, same tail volumes--they just fudge the outlines. Mine is also converted from bubble canopy to razorback.
My power setup is this: KMS 31/21 bell-type outrunner and matching KMS 18A ESC. The P-47 was such a success that I immediately turned around and bought another combo set for some other similar project or a twin. You can buy both as a combo for under $50 at http://www.hobbypeople.net/combos/999841.asp. The only thing that was confusing for me was the setup for 2- vs 3-cell selection. There is no programming to the ESC; to set for 3-cell use, you simply remove the "jumper" attached to the extraneous lead. I thought this was odd, since when you do that, you leave two pins exposed, so I covered/insulated them with a bit of tube and a piece of tape. It works fine, with no fuss. I've had no issues with pulling the current needed for all 4 servos thru the ESC. I'd post some photos, but I don't have them available here at my office; if you reply to this and request that I do, I'll post some next time I'm online from home. It's pretty fun watching this little thing tuck its undercarriage up after takeoff. The airframe is getting a bit tired these days, but it's still presentable. One other thing: if you build the Bf-109, the stab setup will not be correct, and you'll have to shim the trailing edge of the wing (or do something at the tail during the build) to get the decalage correct and eliminate "pitch-twitch." I avoid these kinds of issues by converting these "sort-a-scale" projects to a flying stab setup, which avoids any such issues. I would recommend this modification for all of them, as it sure makes things better. And in case you're interested, HOB had more than just the kits available now. My memory is that originally, they had a P-40, P-39, Macchi 202, and maybe some others, but this trivia is taxiing my memory. Maybe plans for those others are still available somewhere. The power setup I described above will work fine for any of the HOB 36" kits. I would keep the weight down to below 24 ounces, if you can. Mine is no big deal to fly, but you don't do much "floating" or "stretching the glide" with it at that weight!! And, no, I have no connection with Hobby People--I just went shopping for a cheap setup and I think I got lucky with what I bought, so thought I would pass the info along. JGO |
| Thread Tools | |
| Discussion House of Balsa 1/12 Me-109 | peskeybobcat | Scale Electric Planes | 7 | Mar 31, 2009 05:48 PM |
| Sold House of Balsa 1/12 scale FW-190 (x 1.5?) | RAFster | Aircraft - Electric - Airplanes (FS/W) | 6 | Feb 06, 2007 08:29 PM |
| What would be a lighter 1/12 scale P-51, balsa or foam? | Daniel11 | Parkflyers | 20 | Mar 16, 2005 08:54 PM |
| House of Balsa 1/5 scale EXTRA 300L | Bearzilla | Aircraft - Fuel - Airplanes (FS/W) | 3 | Jun 04, 2003 06:55 AM |
| House of Balsa 1/12 P-51 as a Sloper? | Foxtrot | Electric Sailplanes | 9 | Jul 12, 2001 09:54 AM |
