Old Jan 02, 2007, 11:35 AM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
succeess!!! first FPV flights are too much fun!!
thanks to Anthony RC for his fantasitic head tracker, it adds such an awsome element to flying, it is hard to describe how cool it is. I used a slow stick for the initial tests, I haven't decided for sure what I want to do for my next attempt. I am a very accomplished fixed and rotary winged pilot but flying FPV is incredibly hard. by the end of my first charge I was able to take off and fly around below tree level within the confines of the park and land all by video. I found it much easier to climb a bit and fly around, but then its hard to tell where you are and where you're going... I am having so much fun!!!
I have an all new appriciation for VR flyer's videos now that I am doing it myself. thanks VR flyer for the inspiration
sorry no video for now, my cobbeled together setup still does not have provisions for recording...yet
aaronredbaron is offline Find More Posts by aaronredbaron
Old Jan 02, 2007, 12:45 PM
igiveup is offline
Find More Posts by igiveup
The Colony, Tx
Joined Sep 2004
Congrats on your first solo! I would like to use my Slo-Vee for my intial tests. Could you list your components and maybe a pic or two of your set-up?
igiveup is offline Find More Posts by igiveup
Old Jan 02, 2007, 01:02 PM
AnthonyRC is offline
Find More Posts by AnthonyRC
AnthonyRC's Avatar
Switzerland
Joined Sep 2004
Glad it worked well for you :-)
Did you sling the camera under the 'stick', or above it?
AnthonyRC is offline Find More Posts by AnthonyRC
Old Jan 02, 2007, 01:30 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Congratz! Just remember practice makes perfect
typicalaimster is offline Find More Posts by typicalaimster
Old Jan 02, 2007, 04:15 PM
Spektrum Dev Team
Joined Apr 2002
I am using a black widow 200mw transmitter, iTheater HMD, anthony's head tracker with a 9C. the camera is a $40 cheapo from supercircuits.com I have the camera mounted on top, just behind the leading eadge of the wing.
Old Jan 02, 2007, 05:22 PM
AnthonyRC's Avatar
Switzerland
Joined Sep 2004
With the slowstick, it is also interesting to suspend the camera below the plane, just in front of the undercarriage. This gives you a great view of what you are flying over, for higher altitude flights.
You really need to put something in the camera's view if you do this though, to let you know when you are looking straight ahead. For this I just mount a piece of piano wire vertically below the motor mount.
Old Jan 02, 2007, 07:47 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Congrats!
An OSD of altitude & airspeed helped me transition from big aircraft to my FPV EZ*. Still hard, but good enough to get me my flying fix.
Also, try a wide FOV (90 deg +)black and white camera, and see what you think.
I use a cheap Aiptek MPVR to record.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jan 02, 2007, 10:12 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Well done, I'm glad to see another one flying this way, it's so cool!
VRflyer is offline Find More Posts by VRflyer
Old Jan 02, 2007, 10:55 PM
ob1 is offline
ob1
Find More Posts by ob1
ob1
Southeast TN
Joined Jan 2006
What OSD do you use?...and what provides the source for the altitude and airspeed values?
Thx...
ob1
ob1 is offline Find More Posts by ob1
Old Jan 03, 2007, 02:42 PM
Spektrum Dev Team
Joined Apr 2002
I actually own a decent camcorder with a firewire connection, so all I need to record is a video splitter, I only have one output on my video receiver... I have heard its not good to just split the video line with a "Y"
Old Jan 03, 2007, 03:09 PM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
The important point is to have an analog video input too.
Kilrah is online now Find More Posts by Kilrah
Old Jan 03, 2007, 03:59 PM
Spektrum Dev Team
Joined Apr 2002
it has an analog video input... I can record from an outside source... I just can't "get it in the loop" with what I have
Old Jan 03, 2007, 05:24 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
A "Y" will work in a pinch, and I've used them. I got a four output splitter from this guy.
http://www.mp3playerstore.com/stuff_...ries/VA-14.htm
I am not crazy about the outfit, but I've heard here, and probably there also, that you can find similar devices on eBay for about the same price. The klutz at this place had it shipped via DHL with a note: "Hold for pickup." Since the DHL office nearest me was about an eighty mile round trip I called DHL and they said they would have to check with the shipper!
I got it later the same day, but that was bizarro stupid and I've heard that its the norm for that outfit.
Anyway, use a Y connection until you get the splitter. It works but some people think it degrades the signal. I'd rather get the video degraded than not at all. And yes, I've done it with just a Y and I am happy I got the flight recorded.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jan 03, 2007, 05:32 PM
robmoll is offline
Find More Posts by robmoll
67N2F
robmoll's Avatar
Menomonee Falls, Wisconsin
Joined Dec 2005
I had previously posted this in the AP forum...
I had the same experience with mp3player.com when I tried to order the video amp. I even emailed and finally called them in an attempt to get around having to fax or email a copy of my CC (ain't happening). They were rude and uncaring so I cancelled my order.
I finally found this from electrogalaxy.com...
BVAM5 from electrogalaxy.com
Digging a little deeper I found that for the same low price I could order this from Amazon.com, who I trust and have made many non-RC purchases...BVAM5 from Amazon.com
I placed the order with Amazon and, as usual, got my stuff in a couple of days. I was surprised to see that what I received was this...
Boss Audio AM5
In my search for a video amp I had seen this one for sale on many sites but it was listed for $45USD so I was surprised to see this show up. They do have the same part number and I think the only difference is the metal vs. plastic case, but I am very happy to have received what I did.
So, in summary, I ordered the BVAM5 from Amazon.com thinking it would be the one shown in the first picture and received the one shown in the second picture
Your results may vary.
Hope this helps,
Rob
robmoll is offline Find More Posts by robmoll
Old Jan 03, 2007, 05:33 PM
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
If all the devices in the "chain" are conforming to the standard, video level amplitude will be divided by 2, darkening the image a lot. Some devices will adjust for it, some simply won't display any image (some camcorders like Panasonic ones tend to be picky on the signal quality and will smply ignore it).
Bandit: Too much fun Al P High Performance 19 Sep 19, 2003 09:49 AM
Slow Stick + Wingo Floats = Too Much Fun KenV Parkflyers 3 Jul 24, 2003 08:03 AM
Multiplex Pico Jet...too much fun Hammer Head Electric Ducted Fan Jet Talk 5 Feb 02, 2003 12:08 PM
M100 + QC30 + DS = Too Much Fun ! costath Parkflyers 1 May 03, 2002 12:30 PM
Having too much fun to be flying?. Richard ll Life, The Universe, and Politics 4 Sep 29, 2001 10:35 AM
