Jan 01, 2007, 09:48 PM
Stonington, Ct.
Joined Nov 2001
An Axi 2820/10 or 12 would do the trick quite nicely. In my direct experience, I have had the /10, and it had no trouble swinging an 11x7 APC on 3s. That's about 300 watts in the air. The /12 will tolerate higher cell counts. It's basically a .25-.30 to the glow guys. There is also the 2826 series, which has the same size as the 2820, but it has thicker stronger 26mm curved magnets. On high (5s) cell counts this motor is capable of 800 watts. This motor is a drop in replacement for a .40-.45 glow. This is maybe overkill for your plane. Although it is fashionable to underpower twins, I like 60w/lb as a target better than 50. You don't want to discover that you're underpowered when you're running out of altitude, amps and ideas all at the same time.
BTW, there are some cheap chinese units at united hobby that would do it too, but AXI means quality. I think I sold my 2820 for $10 less than I paid for it, a year and a half later- it was literally as good as new.
-tim
