Try this to stiffen it
http://www.rcgroups.com/forums/attac...mentid=1177008 a piece of CF at bottom and pieces running from tob/bottom of tail. A CF rod at the hinge line also helps. It makes the tail of my 16" bipe very stiff, which I like. you can do it post-build by sharpening the end of the rod and twisting it in then secure w/thin CA. -Mike |
With regards to the stiffness of the tail - mine was stiffer than any other EPP 3D type plane that I've had/flown before, there is still a little flex there - but just enough to give in the case of a crash. |
Estonia
Joined Sep 2005
depron silent mite
The photo is taken from estonian forum: http://foorum.pistik.com/viewtopic.p...r=asc&start=20
and the modellers user name is pipercub. |
I'm not able to do a video at the moment as I don't have the time - but I hope to do one in the future....I may be able to do a very basic video soon if I can find the time.
I have been flying the Silent Mite recently outdoors for the first time - I love it & really like its responsive controls, it really is a point it where you want it type plane and flies very cleanly. I think the reasons why this thread didn't pick up are partly due to the off topic waffle on the first couple of pages & the fact that it is a more involved build than many others - also that it uses EPP sheet is also a slight stumbling block for some I think as its not always easy to get hold of...but I think its worth the effort
Maryland, USA
Joined May 2004
Soundman,
Thanks for sharing your design. This plane is very similar to another design made in depron, called the Pink Star. Here is a link to the build thread, if you want to see his depron building method. I bought the pdf plans a while back, but haven't built anything yet. http://www.rcgroups.com/forums/showthread.php?t=184991 |
| Thread Tools | |
| Discussion Full fuse 3D plans for EPP use? | flyingace451 | Foamies (Scratchbuilt) | 2 | Apr 23, 2007 04:37 PM |
| Discussion EPP Full Fuse 540 plans and pics | eightdayslate | Foamies (Scratchbuilt) | 0 | Nov 20, 2006 10:22 AM |
| have you any EPP plans? | shuty | 3D Flying | 4 | Jul 15, 2004 03:45 AM |
| Full Fuz Yak! | edible_engine | 3D Flying | 8 | Jul 14, 2004 01:34 PM |
| Who can print out full size DXF plans? | KMKAZE | The Builders Workshop | 11 | Dec 07, 2002 10:17 PM |
