Old Jan 01, 2007, 10:18 AM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
It will be a while yet need more foam and need to finish mt "big P-40 " first. I'll have to figure out a good airfoil to use on the wing also.
Jason
JAM is offline Find More Posts by JAM
Old Jan 04, 2007, 11:53 AM
richard boyd is offline
Find More Posts by richard boyd
richard boyd's Avatar
Northern Ireland
Joined May 2006
Soundman,fantastic plane +plan ! You could be responsable for alot of desperate house wives,as all the men will be in the workshops building your plane . Many thanks for sharing it with us .
richard boyd is offline Find More Posts by richard boyd
Old Jan 04, 2007, 02:54 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
OK, seriously - what AM I doing wrong ???
I cannot Download those plans whatsoever ???
I'm going nuts here :-(
Whether I simply try to open them or
Copy then into a directory and try to open them I get ERRORS !
Online it simlpy says there are errors opening this page.
In my directory it says it cant decrypt the file !
And this happens with BOTh the Plans aswell as the build guide.
I've never had probs with pdf stuff her ein the RCG forums.
Have I got a virus or something ???
birdofplay is offline Find More Posts by birdofplay
Old Jan 05, 2007, 12:27 AM
soundman is offline
Find More Posts by soundman
soundman's Avatar
Norfolk, UK
Joined Jul 2002
I think you must have some sort of issue at your end - there is no reason why there should be any problem at all....maybe it's a browser/system version problem?
soundman is offline Find More Posts by soundman
Old Jan 05, 2007, 06:31 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Jam , you got a new job .... again ???
gpw is online now Find More Posts by gpw
Old Jan 05, 2007, 12:23 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
So I got to Pusher Prop Jets forum JUST FOR A TEST.
I try opening several PDF's ...
No problem with ANY of them !
I have discovered that even tho I have acro 5.0 but it WILL LNOT allow itself to be ASSOCIATED !?!?!
So my browser is using the older acro 4.0 which wont work with the file.
I HAD TO Control Panel REMOVE Acro 4.0 ...
"The expensive one that was paid for " To get the latest 5.0 to work .
Still it only works with IE7
my poor Mozilla is clueless even though I Changed the
Helper App to the new Acro 5.0
I've never liked Acrobat or Adobe !
Old Jan 05, 2007, 04:56 PM
Hughbert is offline
Find More Posts by Hughbert
Planes are cool ;)
Hughbert's Avatar
Bath, UK
Joined Dec 2006
Looks great! Can I ask you how you came up with the dimensions for the cockpit/top fuse? I'm working on a similar project (a park flier, not a 3D pattern ship, but similar fuse) and I'm having a problem with converting a flat sheet of EPP to a skin which perfectly fits the fuse formers... any tips?
Cheers
Hughbert is offline Find More Posts by Hughbert
Old Jan 05, 2007, 11:06 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Rhino3d has a feature that UNROLLS a bent forms to a flat one !!!
It doesnt always work but its been neat to play with for me.
Old Jan 06, 2007, 04:37 AM
soundman is offline
soundman's Avatar
Norfolk, UK
Joined Jul 2002
I design all my planes in Adobe Illustrator (similar to Corel Draw) in only 2D. I have used some 3D software but find the unrolling a little unreliable, also I find designing in 2D much faster - particularly with Illustrator as I use it quite a lot.
This stage of working out the fuselage skin should be the last thing you do to the design before printing - everything else should be finished & finalised at this point.
The easiest way to work this out is if the fuselage top profile is a semi circle - then its a case of simple maths. Start off by drawing out the top & side views of your plane as you would normally do, draw out the formers that you want - from this you need to know the former width & height, then use this formula:
((Pi * width)/4) - (width/2) = extra foam allowance
Height + extra foam allowance = total fuz skin height at that former point
Do this at a few key points along the fuselage length & join the dots....straight sections just need straight lines joining them - curved parts like the canopy need the curve moving to the new position - the curve will appear slightly different, but when cut & glued up it should appear as it did in your original side view.
Broken down this means:
Pi * width = circumference of circle with the diameter of the fuselage width.
Divide this by 4 to give the length of a quarter of this circle.
Subtract width/2 (radius), this length is already included on your side view drawing, giving us the extra amount of foam needed to be added.
Add the height to the extra allowance & you now know the full height of the fuz skin needed at that point.
This works perfectly every time - I'm working on another plane now & have done it using this method again.
Below I have given a link to the excell file that I use, you just need to enter the width & height of the fuz/former & it will tell you the full dimension. As a bonus I have left all the other calculators on the spreadsheet that I use when designing a plane - the weight setup, wing area, wing loading etc is all saved with the Silent Mite info entered.....I find this excell file very useful when designing a plane & it saves lots of time & effort guessing, trying to predict weights etc
Plane Calc Excell File
I hope that answered some of your questions.....I'll deal with non-circular fuselage shapes later & let you digest this first.
Tom
Old Jan 06, 2007, 07:15 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Tom: Thanx for that calculator. I'm one of those folks who uses the pencil and paper (and eraser ) to do my design work - I haven't figured out these new-fangled computer thingies yet. Learning how to unroll shapes is my aim though - whether it's new school or old school. Any info on how to do this is always appreciated!
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Jan 06, 2007, 08:16 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Math hurts my head That's what I have this PITA 'puter for!
I can't draw a straight line on graph paper, much less a perfect arc...
That's why I use CAD, xacto, razor blades and sandpaper! TLAR on CAD, trim and sand to fit.
My hat is off to anyone who takes the time and effort to pre-calc all these 3D fits. I can't focus on a detail like that long enough to stay awake
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 06, 2007, 03:17 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Hi again Soundman..
Have just downloaded it all from your page....
Again THANK YOU for sharing this with us all. You have probably spent quite some time on this, so remember.... your work is greatly appreciated.
Kim
kimhey is offline Find More Posts by kimhey
Old Jan 06, 2007, 04:55 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Take it one more step Gene !!!
I cant CUT a straight line so I have CNC to cut my foamy parts !
I use Rhino3D for those UNrolling thangs but, I have to agree with soundman as
it doesnt always work.
Still the more time I'm on the Computer the less time I'm making scrap
out of good stock !
Old Jan 07, 2007, 04:30 AM
soundman is offline
soundman's Avatar
Norfolk, UK
Joined Jul 2002
out of good stock !
Yep - & it literally takes 10 mins to do the needed alteration if you use the calculation on the spreadsheet.....perhaps 15 mins if you do it on a calculator - it's certainly not rocket science.
Old Jan 11, 2007, 10:06 PM
New Foamie Guy is offline
Find More Posts by New Foamie Guy
Umm....Yeah....
Joined Jan 2007
I am going to build it. I am cutting out the templates now. Hey, does this plane have ailerons? They seem to be missing on my plans. Also, you do not specify on all parts what thickness they are to be made from. Can you clarify just a bit. I am using 3 and 6 MM depron. Oh, and about those forward fuz formers you mention in the guide. Don't see 'em either.
great looking plane BTW
New Foamie Guy is offline Find More Posts by New Foamie Guy
Discussion Full fuse 3D plans for EPP use? flyingace451 Foamies (Scratchbuilt) 2 Apr 23, 2007 04:37 PM
Discussion EPP Full Fuse 540 plans and pics eightdayslate Foamies (Scratchbuilt) 0 Nov 20, 2006 10:22 AM
have you any EPP plans? shuty 3D Flying 4 Jul 15, 2004 03:45 AM
Full Fuz Yak! edible_engine 3D Flying 8 Jul 14, 2004 01:34 PM
Who can print out full size DXF plans? KMKAZE The Builders Workshop 11 Dec 07, 2002 10:17 PM
