Old Sep 16, 2002, 12:54 AM
flytowner is offline
Find More Posts by flytowner
flytowner's Avatar
Texas,USA
Joined May 2001
Super sub-micro airplane utilizing guts and radio from a Tomy Bit car...
Has anyone built a SUPER small airplane using parts from a Tomy Bit car? I've read that these little things can run 5 minutes on a 45 second charge (one cell NiCAD)!
Seems like it might be pretty easy to remove the 2CH micro Rx, motor, and battery and drop them into a tiny airplane to be flown in the house using the supplied Tx. You could use the two channels to drive a couple of small actuators for the tail feathers. The motor could just be wired for on/off control. I think you could literally fly a paper airplane with this setup. The problem might be finding props small enough...
Prices seem to be coming way down on these little gems: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1766233625
I think I'm gonna get a couple of these babies. One to play with and one to dissect!
flytowner is offline Find More Posts by flytowner
Old Sep 16, 2002, 03:52 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Slight snag with these - the range is very short. I also think that there is not power enough for flight on only one cell.
I think this has all been discussed before.
They are great fun to drive though - I have several.
Michael
epilot is offline Find More Posts by epilot
Old Sep 16, 2002, 04:53 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
However you can whip out the one cell and replace it with a LiPoly, this does have enough volts and weights the same. I did this with an actuat car and boy does it move.
Michael is correct on the reange front although it is possible to boost the power of the transmitter by using 4 nicad cells I think. This has been done on the canned heat stuff but not sure about the bitcharger. There is a japanese site with a full conversion of a bitcharger but I forget the web address.
It also struck be that the actuator drive on these things is perfect for a mw actuator as built by Matt keenon and shown in RCmicroflight. Either that or use the origional coils. Would be good enough for guided FF.
The supplied motor might be ok for flight using a big enough gear ratio but I don't know, the Japanese guy used a geared KP00.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 16, 2002, 07:31 AM
drliu is offline
Find More Posts by drliu
Living Room Aviator
drliu's Avatar
Joined Jun 2002
It should be possible (indeed it has been done before, as reported on some Japanese web sites). The Bitchar-G motors are the largest motors I use to fly now and as a nice benefit come in many different speeds. They are definitely powerful enough if your plane is light enough. I usually gear them 1:16 now with a 160 x 120 mm prop from Westec. I've also used a BitChar-G motor geared 1:5 and flown with a much smaller U80 prop (less power but looks better), and geared 1:21 as well with the 160 mm prop (comparable performance).
The radio, however, is not proportional. You will get off/on throttle control, and left/right/neutral steering. There is a new generation of Tomy BitChar-Gers with 2 speeds if I remember; they might be more promising. Also, the radio is small, but not that small. I would be surprised if it weighed less than a RFFS. The actuator coils are not really well-suited to BIRD-style actuators. In the cars they are more or less simple electromagnets and affect steering by simple attraction rather than by rotating an magnet held within the coil.
Still, for about $20-40 it is a pretty attractive project.
-David
drliu is offline Find More Posts by drliu
Old Sep 16, 2002, 09:18 AM
Sticky Shepherd
Oxford/England
Joined May 2001
I think the receiver something like a gram, I aggree the coils supplied aren't the greatest for lightness etc. You could wind your own, if you do it with two wires on the same former yuo end up with one coil that is actually two and you can mount them BIRD or RFFS style. The best bet might be bang bang for a rubber powered model or a simple outdoor model you guide away from the trees.
Muscle wire is a definate option.
Graham
Old Sep 16, 2002, 01:14 PM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
Just play with the cars and
use a Z Tron proportional IR system for the plane
You can save a lot of weight if you leave out the voltage booster and circuit board. Use a Li poly cell and one low voltage senor, 150 Ohm coil a the smallest neodium magnet ....
Costs nothing, weighs nothing !
Power the plane with a geared pager and ultra thin prop?
Make all of the plane from 2mm wall foam,shoudl weight 10g at most? Save a bit more weight by using a Muscle Wire actuator, Matt is working on an IR Rx with special centralising software.
Its a great time to be an aero modeller!
Mark
(I was thinking of doing a 9" span B17 as above design)
aeronutz is offline Find More Posts by aeronutz
Old Sep 16, 2002, 06:12 PM
lrc is offline
lrc
Find More Posts by lrc
lrc
UK
Joined Aug 2002
I found that the range on the BitChar-G receiver can be increased by increasing the ariel length, up to 50 metres or more with a 100 cm ariel, although this becomes less when it is coiled.
lrc is offline Find More Posts by lrc
Old Dec 20, 2002, 01:33 AM
bipeflyer is offline
Find More Posts by bipeflyer
My cat up close
bipeflyer's Avatar
England
Joined Feb 2001
How about this then?
Take a look at this:
http://www.rcgroups.com/forums/showt...threadid=79154
Yes,a six motor micro car gut conversion EDF An-225......Amazing!
Matt.
bipeflyer is offline Find More Posts by bipeflyer
Old Dec 20, 2002, 03:58 AM
jandirks is offline
Find More Posts by jandirks
Amersfoort, The Netherlands
Joined May 2002
You should read this thread:
http://www.rcgroups.com/forums/showt...threadid=79245
Edit: It describes how to get a range of ~250 feet!
Jan-Dirk
jandirks is offline Find More Posts by jandirks
Gallery Super Sub Micro Heli Orion_V Micro Helis 5 Dec 28, 2005 06:28 PM
what sub micro servos for old airtronics radio eran_k Parkflyers 9 Nov 10, 2004 08:12 AM
FS Futaba 6EXA Radio w/ Sub-Micro Flight Pack FL62 Aircraft - Electric - Helis (FS/W) 0 May 29, 2004 09:29 AM
~~~Free Sub-Micro Airplane Plans~~~ speeddemon281 Scratchbuilt Indoor and Micro Models 0 May 19, 2004 12:49 AM
For Sale Jr Quattro Radio & Receiver Plus 2 Sub Micro Servos wats Aircraft - Electric - Airplanes (FS/W) 8 Sep 20, 2002 06:26 AM
