Old Dec 29, 2006, 05:11 PM
kiwidave is offline
Find More Posts by kiwidave
Seattle
Joined Jul 2006
Can I connect 2x 109 to one 13.6v powersupply?
Well.......I guess the title asked my whole question. I will repeat for redundancy
Can I connect 2x AstroFlight 109 to one Astroflight 13.6v powersupply?
Thanks!
David
kiwidave is offline Find More Posts by kiwidave
Old Dec 29, 2006, 05:25 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Yes. Just add the amp loads together and keep the total under the limit of the power supply.
Miami Mike is offline Find More Posts by Miami Mike
Old Dec 29, 2006, 06:14 PM
kiwidave is offline
Seattle
Joined Jul 2006
Cool, Thanks.
So if I am charging 2 sets of TP 6S3PL 6000 (2x 3S3PL 6000 in Series) at 4.5 amps each (9 amps total). I should be ok with the 13.6V @ 12.5 Amps limit of the power supply?
Thanks!
David
Old Dec 29, 2006, 06:26 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
No, I meant the amp draws of the battery chargers. It takes a whole lot more current into your charger than what comes out to charge 6S packs, because of the big step-up in voltage.
Old Dec 29, 2006, 07:07 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Determine power (Watts) required.
6 x 4.2 volts x 4.5 amps = 113.4 Watts for one pack. Add about 15% for losses and you need 130 Watts. 130 Watts/13.6 volts = 9+ amps per pack.
Bill
ebill3 is offline Find More Posts by ebill3
Old Dec 29, 2006, 07:59 PM
kiwidave is offline
Seattle
Joined Jul 2006
Bill
LOL, Great job of completely confusing me
Is that 130watts per charger or do I split it between 2 AF 109s so each one needs 65 watts?
I am not big on electrical theory (if my hair stands up on end, then I have touched the wrong wire, is the extent of my knowledge)
So do you think I can attach 2 astro flight 109, to the power supply and charge two of these 6s3p 6000 @4.5 amps at one time without burning down my house
Thanks!
David
Old Dec 29, 2006, 08:04 PM
kiwidave is offline
Seattle
Joined Jul 2006
Bill
Ok, so after reading your post again, I think I need a 13.6 power supply with 19 or so amps to charge both of these packs with 2 109s or I should just get another power supply with the 109.
Is that right?
David
Old Dec 29, 2006, 08:08 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
You can:
1. Get a second power supply for the other charger.
2. Get a bigger power supply to run both chargers.
3. Use your existing setup at a lower charge rate.
Old Dec 29, 2006, 09:17 PM
kiwidave is offline
Seattle
Joined Jul 2006
Thanks!
Old Dec 29, 2006, 11:15 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I'd go with one big supply and don't cut it too close. A slightly larger supply than what you'll actually use can't hurt. Pay attention to the power supplies continuous rating which is usually less than its max (peak) rating.
Ohmic is offline Find More Posts by Ohmic
Old Dec 29, 2006, 11:23 PM
Probedude is offline
Find More Posts by Probedude
Probedude's Avatar
Ventura, CA
Joined Jul 2006
One good thing with 2 power supplies is if you ever want to charge 2 packs that are in series at the same time, you won't have to worry about common ground or source problems (as long as the power supplies don't tie either of their outputs to earth ground.)
Probedude is offline Find More Posts by Probedude
Old Dec 29, 2006, 11:38 PM
quietfly is offline
Find More Posts by quietfly
Joined Jul 2001
http://hobby-lobby.com/powersupply.htm
quietfly is offline Find More Posts by quietfly
I can't believe i can't find the right one :S pascal Parkflyers 4 May 10, 2003 11:12 AM
Looking for a charger that can charge more than one battery pack at a time thor4944 Batteries and Chargers 10 May 02, 2003 02:05 PM
Can't Decide Which One LockedINgooD Beginner Training Area (Aircraft-Electric) 7 Jul 31, 2002 05:28 AM
3 planes .... only 1 can be built .... which one ? bsumpter Sport Planes 13 Mar 13, 2002 11:55 AM
