Old Dec 29, 2006, 03:11 PM
kilmerrc36 is offline
Find More Posts by kilmerrc36
Joined Dec 2006
Question
Oops, I may have messed up my DL50?
Ok, so I glued the horizontal stabilizer's stand-of on the top instead of the bottom...... is it going to matter? Can I mount the Hor. Stab. on the bottom of the boom instead of the top? Will it have any adverse effects?
kilmerrc36 is offline Find More Posts by kilmerrc36
Old Dec 29, 2006, 04:38 PM
Endless Sloper is online now
Find More Posts by Endless Sloper
Rick Rogahn
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
Interesting, have seen other DLG's w/ the H stab mounted on the bottom. Have often wondered what advantage this might give you. Cleaner airflow over the stab?
Endless Sloper is online now Find More Posts by Endless Sloper
Old Dec 29, 2006, 05:27 PM
Joined Dec 2006
Well, if I have not heard otherwie by tomorrow..... I'm just going to mount it on the bottom. What the hey.....
Old Dec 29, 2006, 05:31 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
@ES: I believe it had to do something with the servo being able to pull for up elevator with those under-boom elevators and the trade off being that the horiz stab was then easier to rip off.
@Kilmerrc: I think your DL50 will be fine, just a little care should be taken not to let it land on the ground - hand catches only.
ha ha - just joking. may be just a little more fragile, but shouldn't be a problem.
I don't quite follow though - you mounted the "stand off" on the top of the boom or on top of the horizontal? That's a pylon that attaches the boom to the horizontal, right?
ajroahkni is offline Find More Posts by ajroahkni
Old Dec 29, 2006, 05:41 PM
Joined Dec 2006
The Hor. Stab. has a small 1/4 inch stand off block that is mounted between itself and the boom. I believe to help give the Elivator clearance from the boom for complete movement since all of it is mounted in front of the Vert. Stab and rudder which as mounted at the end of the boom. The instructions say to mount the Hor Stab on top of the boom but I glued to stand off block on so that the Hor Stab will be mounted on the bottm of the boom. It is literaly a matter of 1/4 to 1/2 in difference. It just means that the Hor Stab will be a little lower in reference to the Ver Stab and may be a little more prone to brake off if I have a hard tail landing..... (which of course I never do... ha ha).
Thanks for you comments.
Old Dec 29, 2006, 06:43 PM
shhhhh! is online now
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Nope,won't make any difference at all.Lot of european DLGs mount the stab on the bottom.
shhhhh! is online now Find More Posts by shhhhh!
Old Dec 29, 2006, 06:51 PM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
What's the problem? Remove the stab mount and glue another one on the top.
John Gallagher is offline Find More Posts by John Gallagher
Help! Messed up my transmitter Vol GWS (Grand Wing Servo) 2 Jul 16, 2004 04:35 PM
HELP! I have messed up a model... soholingo The Builders Workshop 5 Jun 06, 2004 12:33 PM
TOG you sure have messed up my bench MatRat Foamies (Kits) 1 Dec 29, 2003 10:26 PM
Have I messed up my HE cells....? roguewolf Batteries and Chargers 1 Feb 26, 2003 01:04 AM
M-IFO one thing I may have forgotten for my build... Phat Phreddy Scratchbuilt Indoor and Micro Models 7 Jan 23, 2003 04:56 PM
