Old Jul 29, 2001, 08:27 PM
mopar_man is offline
Find More Posts by mopar_man
Terry Dunn
mopar_man's Avatar
United States, TX, Lubbock
Joined Jan 2001
Can my ESC be fixed?
I was recently given a zagi/Aveox ESC where the negative battery lead had been separated from the board. The problem is that the etched part of the board where the lead is soldered delaminated is still connected to the lead. I can post a pic if necessary. Do any of you EEs out there think it is repairable?
Terry
mopar_man is offline Find More Posts by mopar_man
Old Jul 30, 2001, 02:46 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Contact Steve.
stevem@fesi.com
hoppy
hoppy is offline Find More Posts by hoppy
Old Jul 30, 2001, 03:07 PM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
You should be able to CA the delaminated trace back on to the board.
MK is offline Find More Posts by MK
Old Jul 30, 2001, 04:11 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Originally posted by hoppy:
Contact Steve.
stevem@fesi.com
hoppy
Please - don't. I would love to help but have called it quits on the ESC repair sideline.
Yes it is repairable, and please don't ever call me an EE
The CA trick will work but do not solder it after doing this as the CS will not take the heat and the trace will come loose again.
Alternate method would be to epoxy it down - you can even get a little sloppy and cover the trace.
Good luck!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jul 30, 2001, 06:27 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Ok Steve, sorry to hear you've decided to "retire". I'll withhold any further referals . Thanks for your past help!!
hoppy
Old Jul 31, 2001, 08:52 AM
Terry Dunn
mopar_man's Avatar
Joined Jan 2001
Thanks for the replies guys. No worries Steve. When I was racing RC cars, I used to airbrush bodies for free. It didnt take long for it to get out of hand. I know where youre coming from.
Anyway, I just want to make sure I explained this situation correctly. The part of the trace where the negative lead is soldered separated from the rest of the trace and is still soldered to the lead. So I guess the real question is:
" Is there another place on the board where I can attach the negative battery lead?"
Old Jul 31, 2001, 09:20 AM
MK is offline
MK
MK
NJ
Joined Feb 2001
How about at the point where the trace broke off?
Old Jul 31, 2001, 09:41 AM
Terry Dunn
mopar_man's Avatar
Joined Jan 2001
It broke off right at the edge of the transistor. I cant see any part of the trace left there.
Old Jul 31, 2001, 01:38 PM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
I would offer to do this for you, but im in Australia, so the turn-around could be quite long, upto a month I guess, depending on the postal services involved.
If your not confident doing it yourself, and dont mind the possible wait, I may consider it if your interested.
MrBungle is offline Find More Posts by MrBungle
Old Jul 31, 2001, 02:02 PM
Terry Dunn
mopar_man's Avatar
Joined Jan 2001
Thanks again guys.
Looking at it closely, I found a piece of copper that appears to go through to the other side to feed the BEC. It's hard to tell, but I think that youre right MrBungle about the trace going to 3 legs of the MOSFET. Im going to get out the multimeter when I get home to see if I can confirm that. If that is the case, I think I can handle the solder job. Otherwise I may take you up on your offer.
Terry
Old Jul 31, 2001, 02:32 PM
MrBungle is offline
rebmeM roineS
MrBungle's Avatar
Joined Apr 2001
OK im 100% certain thats where to solder now (yellow dot), Ive just had a look at the datasheet for the IRF7805 Mosfet, which are likely the ones used on that speedy, if not they would surely have the same pinout. The three legs next to the Gate are the Source and the 4 on the opposite side are the Drain on this datasheet.
I have Surface mount rework gear I use, so if you do decide to get me to do it for you I would be removing the Mosfets, laying down some new copper clad, and then replacing the Mosfets. That way the legs dont have to take the strain from the Batt lead.
Im off to bed now it's 3:30am! gotta be up at 7 :/
Old Aug 01, 2001, 12:51 AM
MrBungle is offline
rebmeM roineS
MrBungle's Avatar
Joined Apr 2001
Looking at your photo, it appears that the lead went to the 8pin SOIC Mosfets on the edge of the board where there is not alot of copper, if you have a look closely you might see if the trace did actually go under the Mosfets to those legs there, you will then probably be able to solder onto the legs on the Mosfets where the Yellow dot is in the pic below. Im pretty sure of this because the mosfets are connected on the other side to the area in the center where the Red dot is, and all the copper there appears to be connected to the blue lead for the motor. I cant really tell because the pic is so small, but Im sure it wont be going to the same legs on the mosfets that the motor is connected to So please check carefully where the trace went before soldering onto the legs. It looks like theres another small trace running along the edge of the board where the Yellow dot is, try not to solder that when you solder onto the legs. that smalltrace is going to the gate of the Mosfet, the 1st leg closest to the area that the lead was originally, so you want to solder onto the remaining three legs, not all 4.
Yeah its Dodgy but if your carefull you will do it. This can definatelly be fixed, just have to be absolutelly sure where its going, im feeling confident with the yellow dot. Good luck
grrrr posting images takes me far sometimes..lol
try #12, I cant see what im doing wrong, its no different to the way ive posted other images, trying html code now
try #13 YAY!! UBB can bite me! lol
Oh yeah I just thought of something else, check that there are no via's(a small copper plated hole approx .5mm dia going through to the other side of the board) where the copper was that the lead went to originally, I cant see any in the pic but there may be one or two there.
[This message has been edited by MrBungle (edited 07-31-2001).]
Old Aug 02, 2001, 09:34 AM
Terry Dunn
mopar_man's Avatar
Joined Jan 2001
Thanks a million guys!! I think it's gonna work.
A check with the multimeter confirmed the trace goes to those 3 legs of the mosfet and to the other side of the board. I coated the gate leg and its trace with a thin layer of epoxy then made a solder bridge across the other 3 legs. I soldered the battery lead there and then added a jumper to the other side of the board. The bench test seemed to show normal operation. I'll throw it in my zagi to see if it will still hande operating currents. The photos are fuzzy but they show the fix...the dashed yellow line is the added jumper:
[This message has been edited by mopar_man (edited 08-02-2001).]
Old Aug 02, 2001, 11:38 PM
MrBungle is offline
rebmeM roineS
MrBungle's Avatar
Joined Apr 2001
Congrats Terry
Dont forget to throw some heatshrink over it to hold that lead firm, it wont take much to break those legs off the mosfet. Maybe even put a drop of thin CA where the silicone insulation runs along the board before shrinking.
Old Aug 03, 2001, 12:54 AM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Hi Mopar !
Smear the wire ends and reworked components with epoxy, after testing the ESC, and before recovering with heatshrink . . .
That'll hold it all tight . . .
Keven.
keven64 is offline Find More Posts by keven64
Question Can the Hitec Receiver be fixed? Shogun Radios 1 Aug 25, 2005 02:55 PM
Could my esc be causing this problem? OUAndy1807 Radios 1 Jul 11, 2004 06:57 PM
Can my esc take the heat? thor4944 Power Systems 0 May 16, 2004 09:31 AM
Will the BEC on My ESC be ok? stu78 3D Flying 1 Dec 01, 2003 07:32 AM
Can my hacker be saved? Pork Tornado Parkflyers 6 Jan 21, 2003 11:00 AM
