Old Dec 28, 2006, 08:45 PM
DonA is online now
Find More Posts by DonA
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
Can I use a 146iP PCM RX with the stock Blade 3 in 1?
I have a Blade CP Pro and wanted to use my Futaba PCM 146iP instead of eFlight PPM RX . I swapped out the PPM RX for the 146iP, all servos move correctly, but tail rotor doesn't function like it did with the PPM RX.
Servo output (pulse width) shouldn't change between PCM and PPM so I guess I am asking will the stock Blade CP Pro 3 in 1 work with a PCM receiver?
thanks
DonA
DonA is online now Find More Posts by DonA
Old Dec 28, 2006, 09:06 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Yes, it sure will. I fly my CP2 with an E-Flite 3-in-1 and a JR 770 PCM receiver. Works fine!
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Letcraft is offline
Find More Posts by Letcraft
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
That's the set-up I am using presently with no problems. What is the tail doing that's different? Are you using a separate gyro?
Letcraft is offline Find More Posts by Letcraft
Old Dec 28, 2006, 11:33 PM
DonA is online now
DonA's Avatar
Joined Feb 2006
Using the 3 in 1 gyro but the tail rotor quits spinning if I give it any more than half stick right rudder.
DonA
Old Dec 29, 2006, 12:20 AM
Austin, TX
Joined Sep 2005
That almost sounds like the rudder channel is reversed? The tail motor on mine stops spinning with left rudder....
-Chris
Old Dec 29, 2006, 12:43 AM
InsomniaZZZ is offline
Find More Posts by InsomniaZZZ
InsomniaZZZ's Avatar
SF Bay Area, CA
Joined Dec 2006
I have JR 790 Rx, stock 3-in-1 and HH Gyro (G90).
I connected the G90 inputs to Rx.Rudder (for rudder) and Rx.Aux2 (for gain). Works like a charm.
InsomniaZZZ is offline Find More Posts by InsomniaZZZ
Old Dec 29, 2006, 01:00 PM
DonA is online now
DonA's Avatar
Joined Feb 2006
-Chris
I checked that and the direction is correct. Just swapping receivers shouldn't change servo direction but I checked it anyway. It's got me stymied right now, I don't know what to check next.
DonA
Old Dec 30, 2006, 01:56 AM
Crash549 is offline
Find More Posts by Crash549
RALEIGH, NC
Joined Feb 2006
Is your tail motor plugged in backwards? Tail motor wired backwards?
Crash549 is offline Find More Posts by Crash549
Old Dec 30, 2006, 10:09 AM
DonA is online now
DonA's Avatar
Joined Feb 2006
No, tailrotor is running correct direction. Everything else also goes correct direction, but when I install the 146iP PCM RX, tail rotor quits spinning when you get to about 1/2 right stick.
I plugged a servo into the rudder channel on both RXs and the servo works correctly with both RXs. Got a real puzzle here.
All I can think of is the 3 in 1 is picking up some other signal or pulse width variant that confuses the gyro function.
DonA
Old Jan 05, 2007, 09:30 PM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Tried to help ol' Don out through PMs' he initiated. Here's what I got for the trouble:
Nope, already checked that and just rechecked. Rudder channel direction is correct.
BEEEEEEEEEP, thanks for playing our game!!!!
Don
Old Jan 05, 2007, 10:21 PM
DonA is online now
DonA's Avatar
Joined Feb 2006
Don
Letcraft,
Sorry for my smart@$$ reply, I was kidding but rereading my email, I can understand your reaction. Just a saying we use when we have been chasing a problem and the latest solution didn't work either.
Don
Can I use an AC adaptor with Hitec CG-330? John Webb Batteries and Chargers 8 Feb 16, 2009 02:21 PM
Sold Futaba 146ip PCM Rx, $35 shipped in USA Phishnvdub Aircraft - General - Radio Equipment (FS/W) 7 Aug 01, 2007 05:41 AM
For Sale Futaba 9CH Super with synthetizer and 146ip PCM rx manu2604 Aircraft - General - Radio Equipment (FS/W) 1 Mar 24, 2007 05:24 PM
May Buy GWS Zero - Can I use my Qualcomm Bats with it? mrebman Parkflyers 21 May 05, 2002 09:06 PM
Can I use this type of battery with a Soarstar? f2racer Foamies (Kits) 9 Oct 01, 2001 02:30 PM
