Old Jul 26, 2001, 08:54 PM
kist2001 is offline
Find More Posts by kist2001
Senior Gravity Checker
Tampa, Florida
Joined Mar 2001
carbon vs. balsa weight
Does anyone know the weight per mm2 of balsa versus carbon? I'm just looking for a few constanta to play with designing a plane....Thanks Ken
kist2001 is offline Find More Posts by kist2001
Old Jul 26, 2001, 10:04 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you want an area comparison then you must specify the thickness. In volume, however, I'd say CF is lighter. Not much good alone, however, as it's not very stiff - best laminated, formed, or otherwise with epoxy resin. This will add significant weight, but you don't need much CF for equivalent tensile strength.
..a
Old Aug 02, 2001, 11:46 AM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
Ken,
I do a lot of scratch building and incorporate carbon in all of my designs.It makes wings virtually bulletproof.. If you go to my site www.skydelight.com you will find weights of both round and flat stock graphite.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Aug 03, 2001, 01:29 AM
avie is offline
Find More Posts by avie
Tel-Aviv,Israel
Joined Apr 2001
the specific weight of balsa is 0.1 (that is gr/cm^3) and the carbon with epoxy( done as it should) is 1.6.
however, you don't need as much carbon to get the strength of balsa, and you would probably take some weight off the airframe, but it will cost you much more...
regards
Avi
avie is offline Find More Posts by avie
Old Aug 03, 2001, 01:32 AM
kist2001 is offline
Tampa, Florida
Joined Mar 2001
Thanks everyone!, Ken
Discussion Trex XL Weight VS Trex SE Weight VS Carbon fiber frame Weight ? djdaveq Mini Helis 6 Apr 11, 2006 04:20 AM
Discussion Trex XL Weight VS Trex SE Weight VS Carbon fiber frame Weight ? djdaveq Micro Helis 7 Apr 10, 2006 10:31 PM
Weight of Depron vs balsa built up Mahoo Foamies (Kits) 0 Dec 31, 2003 11:22 AM
Balsa vs. Depron weight... Mighty Dingus Foamies (Kits) 14 Nov 15, 2003 02:57 AM
Carbon rods vs balsa stringers Martin Hunter Electric Plane Talk 3 Nov 24, 2002 09:44 PM
