Old Aug 01, 2001, 10:18 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
Sanyo 720mah NiMH max current drain?
anyone know the max practical current drain that can be put on the sanyo 720 mah NiMHs? are they ok for s400 use?
thanks,
ben
Ben74 is offline Find More Posts by Ben74
Old Aug 01, 2001, 10:49 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
No! About 6A or so..
..a
Old Aug 02, 2001, 03:08 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
They drop down to ~1V/cell at 3A load but can take 5A short time. As Andy said no go on s400's.
The smallest NiHM for s400 would be ~1000mAh cells and keep the current at 8A or less. (= gearbox)
Haldor is offline Find More Posts by Haldor
Old Aug 02, 2001, 02:02 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I guess the confusion is that most of us run speed 400's near their operating limit. That is 10A and above. If you're well below that, which I undestand the Hawk is, they may work OK. Just don't exceed 4-6A..
..a
Old Aug 02, 2001, 02:14 PM
greg morrison is offline
Find More Posts by greg morrison
San Francisco
Joined Jul 2000
The Wattage Hawk uses a 7.2 volt Speed 400 motor and 5.5x2.5 prop to keep the amp draw down. This combo flies the heck out of that little bugger though and does allow for the use of nimh cells which give the benefit of less weight and excellent duration. I'll bet you could get away with a 6x3 prop as well for even more omph. I'm planning on using the above combo in an Elipstik. It would probably work pretty well in a lightweight pylon/sport ship like the Flea or Bare Bones if you wanted longer flights albeit with less performance.
Greg
[This message has been edited by greg morrison (edited 08-02-2001).]
greg morrison is offline Find More Posts by greg morrison
Old Aug 02, 2001, 02:56 PM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
I tried the 5x2.5 that comes with the Hawk on a 6V 400 and an 8-cell, 1 amp nicad pack. It drew 9.8 amps, static.
astroboy is offline Find More Posts by astroboy
Old Aug 02, 2001, 03:20 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I've used 7x720 nimhs at 7.4A (S280BB direct drive on 4.7x2.3 prop). They didn't get much more than warm at this current, but I don't think they were operating very efficiently! The current shot up to 11.4A when I substituted 500ARs, and I had to go down to 6 cells to keep within the ESC rating.
Bill Glover is offline Find More Posts by Bill Glover
Old Aug 02, 2001, 08:23 PM
modest-master is offline
Find More Posts by modest-master
modest-master's Avatar
Palm Bay, FL, USA
Joined May 2001
My Speed 280BB 3.5/1 MP-Jet gearbox/APC 10x7 almost 11A the 720mAh NiMH no problems at all. I have been flying for 10 monts with this set up. The packs are still good and alive.
Speed 400/Gunter prop full throttle 13A.
Speed 480/APC E5.5x4.5 prop full throttle 10A
modest-master is offline Find More Posts by modest-master
Site Sponsor
Old Aug 03, 2001, 12:52 AM
Ben74 is offline
Ben74's Avatar
Joined Jun 2001
hmm. i'm sort of surprised to hear that. i have one 8 cell pack of 720 NiMHs that i originally bought for a 280 plane, but have been using it in my Wattage Hawk, and a s400 glider with good results. the Hawk goes like a bullet, and the glider performs well too. the battery never seems to get that hot. maybe because i'm giving it good ventilation. i hope i don't ruin it by using it this way.
FS 4 Wild Rc.com Lithium Polymer Batteries and 1 Sanyo 720Mah Nimh shill Aircraft - Electric - Airplanes (FS/W) 0 Mar 27, 2004 08:44 PM
8-cell Sanyo 720mah NiMH and cold weather... down_shift Batteries and Chargers 3 Feb 18, 2003 03:56 PM
FS: 10 cell Sanyo 720mah NiMh pack plus 5 extra cells JohnM Aircraft - Electric - Airplanes (FS/W) 7 Jun 12, 2002 03:39 PM
Sanyo 3000HV NiMH max currents ? ayrtono Sport Planes 7 Mar 31, 2002 08:09 AM
Sanyo Cell Specs - Max Current Crash King Power Systems 2 Sep 22, 2001 12:31 PM
