Aug 02, 2001, 09:05 AM
Cincinnati, OH USA
Joined Oct 2000
A couple of clarifications: People talk in terms of using the center line of the foil section or drawing a line through the longest axis of the foil. That will get you close.
Every airfoil has a "zero lift line". As the name implies, this is the angle of attack at which the foil is generating no lift. On a Clark Y, the zero lift line is (if memory serves) just under -3 degrees.
So to build a model with zero incidence, you want the zero lift line of the wing and stab to be parallel to the thrust line (which may also be the datum line).
Jim
