Old Dec 26, 2006, 04:01 PM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
6975HB Digital Servos for Giant Scale P-47? (top flite)
Hello Gang,
One of our local hobby shops was having a 40% off sale on all in stock items. I went down and found 4 Hitec 6975HB Digital Servos and two 422 Pro serovs at a price which I couldn't pass up.
I picked up the 4 6975HB's for the Ailerons, Rudder, and Elevator and the 422's for the flaps.
It wasn't until I got home that I had a second thought about using these servos in this plane. Do you guys think these servos will be up to the job? I plan on packing this pig around with a G-62. AUW should be around 22lbs.
Ted
TRP is offline Find More Posts by TRP
Old Dec 26, 2006, 09:00 PM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
what is the torque rating on these servos and what serfaces are you using them on?
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Dec 26, 2006, 09:04 PM
Joined Jul 2004
opps just re-read the post if the servos are over 4kg you should be fine, as for the flaps provided your using one per suface you should be ok provided you have mechanical advantage on your side ie- bottom hinged flaps top horned linkage, but I would prefer to see 6kg on each flap, 4kg for all others is fine.....don't forget the 2amp battery so supply the hungry little suckers as coreless tend to draw more power from constantly hunting for centre.
Old Dec 26, 2006, 10:12 PM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
My biggest concern is that I read on a different site that these servos are not reccomended for anyplane over 12lbs.
Yet- they are rated:
Torque 4.8/6.0v :
English
119/144 oz.
Metric
8.6/10.4 kg
I think it's the Karbonite gears that limit the weight application.
I'm thinking I'll need to sell these suckers and get something with metal gears.
Ted
For Sale Short kit for the Meister Scale P-47 Thunderbolt fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 2 Jul 31, 2007 05:21 PM
Discussion What servos for giant-scale Stinson? dk944s2 Radios 1 Dec 26, 2006 01:56 PM
Discussion Which Servos for Giant scale Stinson SR9 Ground Hugger The Builders Workshop 0 Oct 01, 2006 07:39 AM
For Sale TF Giant scale P-47 Thunderbolt. dirtdiver Aircraft - Fuel - Airplanes (FS/W) 7 Sep 11, 2005 07:33 PM
Giant Scale P-47 Thunderbolt GSAV8R Aircraft - Fuel - Airplanes (FS/W) 1 Nov 27, 2004 11:04 PM
