Old Sep 14, 2002, 08:28 PM
Thumas is offline
Find More Posts by Thumas
Beloit Wisconsin
Joined Jul 2002
Tank filling problem glow fuel
I know this sounds like a dumb question but here it goes.
Being new to glow fuel I`m having trouble filling my 6oz tank, I have a small fuel pump mounted to my flight box which came from tower hobbies, the tank is from Dubro with 2 fittings one is attached to a weight on the bottom.
But every time I try to fill the tank the pressure in the tank pushes the fuel back out..I did try to leave the other line off but then the fuel goes on the ground, no matter what I try I cant get the tank more than 1/3 rd full, so what am I doing wrong?
Thumas is offline Find More Posts by Thumas
Old Sep 14, 2002, 10:22 PM
mumblety-peg is offline
Find More Posts by mumblety-peg
mumblety-peg's Avatar
USA, CA, Martinez
Joined Feb 2001
The fitting that leads to the clunk goes to the carb. This fitting is the one u should use to fuel up. I've reversed 'em my self and had the same problem. I have no idea why.
mumblety-peg is offline Find More Posts by mumblety-peg
Old Sep 14, 2002, 10:28 PM
Thumas is offline
Beloit Wisconsin
Joined Jul 2002
I have tryed both lines with no luck, which way should the other line point up or down?
Old Sep 14, 2002, 11:24 PM
Far4nugn is offline
Find More Posts by Far4nugn
Far4nugn's Avatar
Raleigh, NC
Joined Nov 2000
Fill via the clunk line. The other tube (the vent) should be bent up inside until it is very close to the top of the tank. This way, you will be able to fill the tank up to that level. Connect it with a silicone hose to your muffler's pressure tap.
Far4nugn is offline Find More Posts by Far4nugn
Old Sep 14, 2002, 11:27 PM
Thumas is offline
Beloit Wisconsin
Joined Jul 2002
Ahh, Thank you I belive that line is pointing down
Glow fuel tank question... Arbo Fuel Plane Talk 7 Nov 27, 2003 11:16 AM
Help! Glow Fuel Corrosion Russell2 Fuel Plane Talk 7 Sep 14, 2003 01:35 AM
