Old Dec 25, 2006, 06:15 AM
EdBall Flies! is offline
Find More Posts by EdBall Flies!
EdBall Flies!'s Avatar
Joined Apr 2004
Rave
TL50 video from Singapore :) + some flight log data
As promised, I finally solved the throttle cut issue with the help of a simple plastic spoon scoop inspired by PaulVI's creation.
Enjoy!
http://www.rcgroups.com/forums/showa...mentid=1110816
From the Jeti box, I am able to get the following data. This was after implementing the air cooling.
Max Temp: 101 deg celsius 2:29s
Min Temp: 30 deg celsius
Actual Temp: 25 deg celsius
Max Amp: 89.4/ 15.04v 0:03s :S
Min Amp: 61.8/ 14.19v 02:06s
Max Volt: 17.21v
Min Volt: 13.96v 02:27
Actual volt: 17.24v
Motor Run time: 02:42s
On time: 03:45s
Motor RPM: 31240 00:20s
Prop RPM: 31240 00:20s
In this flight alone, I experienced ESC throttle down after about 2:40s of flight time. The Jeti box is telling me that I have exceeded the Temp and current threshold. Will think about the air cooling portion again and show some pics later.
EdBall Flies! is offline Find More Posts by EdBall Flies!
Old Dec 25, 2006, 07:31 AM
pitch black is offline
Find More Posts by pitch black
Holy Slopes!
Joined Jul 2004
I knew it, its you edmond.
Thanx!
pitch black is offline Find More Posts by pitch black
Old Dec 25, 2006, 10:11 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Very nice work EdBall Flies!!! Looks like your're having a lot of fun and have it together
Charger is offline Find More Posts by Charger
Old Dec 25, 2006, 11:13 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Edd that thing is smokin fast with some awesome handling.
It looks to be dialed in perfect.
To me it looks to be doing around 120 mph to 130 mph.
The little extra weight is a plus on that wing,it really make's it track pefect.
The question of the day is can you find a wing or airplane at the hobby shop that flies like that?
If you like the 50 you will love the demon.
ck
klique is offline Find More Posts by klique
Old Dec 25, 2006, 12:57 PM
Joined Apr 2004
yar man, I was having a lot of fun flying the wing around. When the motor starts spinning, it usually signals also the time for others to land and wait it out kekekeke.
CK, no way to find any wing or plane (other than pylons) to go that fast and yet fly so predictably under full control. I have about 45gram of weight at the nose. I am still experimenting with the CG and like the current balance at about 8 for all out speed and 8 1/2 for some slower aerobatic tighter flying. Hope you find the inflight data useful.
Old Dec 25, 2006, 01:22 PM
klique is offline
Mum is the word!
Joined Jun 2003
Edd I really apreciate the vid it is awesome and truley shows the characteristics of the 50'.
It also shows how good of a pilot you are, you are correct about the way these fly it is almost like a pylon type plane.
The motor batt combo you have on that thing is verry fast and has ben clocked on the 40 demon at 150 + mph so It has to be cookin along pretty good.
Your field gets too small quick.LOL
ck
Old Dec 25, 2006, 11:09 PM
PaulVi is offline
Find More Posts by PaulVi
resU deretsigeR
PaulVi's Avatar
Dublin Ca
Joined Aug 2004
Trully impressive
I like your field makes for a lot of fast low flight.
Mine is too short for any real fast low level flying
PaulVi is offline Find More Posts by PaulVi
Video Ritewing TL50 video - Singapore EdBall Flies! Electric Plane Talk 0 Dec 25, 2006 07:54 AM
New Product New Video from HigherPlane: Extreme Flight Yak 54E fmidgett 3D Flying 43 Sep 09, 2006 02:29 PM
Video Some Video from Alabama lmopar69 Electric Plane Talk 1 Nov 26, 2005 03:52 AM
Idea [b]funtana .90e, Video, Cheap Setup & Flight Data Recorder [/b] FREEFLY PR Sport Planes 20 Jul 01, 2005 08:52 PM
In flight video - from the Big T Sal C Electric Plane Talk 17 Apr 15, 2002 08:36 PM
