Old Dec 24, 2006, 01:08 AM
galloping gimp is offline
Find More Posts by galloping gimp
galloping gimp's Avatar
Ohio, USA
Joined May 2002
Servo Tester vs. TX/RX for Motor Testing
I've always done motor testing by using a transmitter and receiver to operate the ESC and run the motor.
Is there a downside to using one of those little servo testers instead of the TX and RX?
I've (finally) built a proper test stand (Dr Kiwi Mk III style) and it occurred to me that using a servo tester would sure make a nice, neat configuration.
Just curious.
- Jeff
galloping gimp is offline Find More Posts by galloping gimp
Old Dec 24, 2006, 03:45 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
None that iv'e found Jeff, in fact i find it darned handy when setting up servo's in a new model as well ,just set it on 1.5ms plug in and hey presto your servo is centred.
olmod is offline Find More Posts by olmod
Old Dec 24, 2006, 05:44 AM
trashbug is offline
Find More Posts by trashbug
trashbug's Avatar
United States, OH, New Franklin
Joined May 2004
Ditto.
No downside that I'm aware of. Use this one all the time with my test stand. Has always worked perfectly. My only complaint is the "scrunchy" plastic jacket that his servo tester is wrapped in. Could be more durably cased to protect it from abusers such as myself.
trashbug is offline Find More Posts by trashbug
Old Dec 24, 2006, 10:04 AM
Keith Wilson is offline
Find More Posts by Keith Wilson
AMA 6418
New Stanton, Pa.
Joined Jan 2004
Originally Posted by trashbug
Ditto.
I use a VEXA servo tester do a search under vexa and you will find there home page.
...Keith...
Keith Wilson is offline Find More Posts by Keith Wilson
Old Dec 24, 2006, 10:13 AM
kit is offline
kit
Find More Posts by kit
kit
USA
Joined Oct 2001
I have both servo testers and use them for motor testing all the time. I like this servo tester better. It has a hard case and more features.
https://www.unitedhobbies.com/UNITED...idProduct=3874
kit is offline Find More Posts by kit
Old Dec 24, 2006, 11:13 AM
Ohio, USA
Joined May 2002
Thanks everyone.
I purchased the servo tester linked in my first post for USD5.80 at a Hobby Lobby sale. At that price, I couldn't afford NOT to have one.
- Jeff
Old Dec 26, 2006, 03:34 AM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
I use the GWS servo tester (P/N GW/STII/RC):
It has a digital read-out that shows the exact pulse width which can be manually set to any value or automatically swept from limit to limit at whatever speed you chose, and has a built-in 4.8 - 6 volt power source (depends on whether one is using alkyline AA batteries or rechargables). One other thing it will do that I've not seen in other testers is the ability to show the actual pulse width a transmitter is sending. This is accomplished by plugging the tester into a receiver channel that you want to monitor. Then as you move the corresponding stick on the transmitter, you should see the pulse width change to follow the stick movement. Note: this is a great way to test your TX and RX channel by channel.
One other thing - one cannot accurately match a servo's center to a TX's center using just a servo tester. In theory, 1.5ms should cause the servo to move to it's center point, but if you measured the pulse width from a TX channel that is centered, it may or may not be at exactly 1.5ms. It will, at least, get you in the ballpark.
babblefish is offline Find More Posts by babblefish
Old Jun 04, 2007, 11:58 AM
frankyfly is offline
Find More Posts by frankyfly
frankyfly's Avatar
Italy
Joined Sep 2004
A question for you guys.
What if I am going to use this one....?
As you see it is rated 5-6 input volts.
Is it going to burn if I use it with 2S or 3S Li-poly battery pack ?
Franky
frankyfly is offline Find More Posts by frankyfly
Old Jun 04, 2007, 01:16 PM
Ohio, USA
Joined May 2002
Franky
If you are using this on a thrust stand to test motors, just plug your ESC into one of the servo inputs and connect your 2S or 3S pack to the ESC.
- Jeff
Old Jun 04, 2007, 01:46 PM
bluesky123 is offline
Find More Posts by bluesky123
Crash=change of flying medium
bluesky123's Avatar
Boulder, CO
Joined May 2002
Not to praise our product (well, not only to ), but to point at another option: check out our new USB interface, which can also drive a servo or an ESC:
http://www.milehighwings.com/
You can either pre-record channel sequence and then play the throttle channel back, or you may create a script file, with throttle vs. time program:
http://milehighwings.com/manual_usb_v4.htm#tools-menu
Boris
MHW R&D
bluesky123 is offline Find More Posts by bluesky123
Old Jun 04, 2007, 02:38 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank you Galloping,
I started this hobby reading your thread about the AND-NOW park flyer.
Great info.
Franky
Old Jun 04, 2007, 03:21 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Just to be clear.
Is this the correct connection scheme ?
Franky
Old Jun 04, 2007, 06:45 PM
trashbug is offline
trashbug's Avatar
Joined May 2004
Looks right to me. Keep in mind that most of the servo testors have a univeral connector. All this means is that you can plug it in with the connector reversed. Nothing bad will happen, just reverse the plug.
Good Luck.
Old Jun 04, 2007, 11:42 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I didnt see the REAL BEST REASON for using a servo tester ...
You'll never forget to turn off your TX !!! :-)
You might forget to unplug the rx battery from the tester tho.
birdofplay is offline Find More Posts by birdofplay
Old Jun 05, 2007, 04:33 PM
herbertkabi is offline
Find More Posts by herbertkabi
Joined Jul 2004
Are you also tired to change AA batteries like me?
Regards,
Herbert
herbertkabi is offline Find More Posts by herbertkabi
WTT..rtf upgraded piccolo pro minus tx,rx for 1/8th truck neofreek01 Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2004 06:37 AM
Universal power supply for motor testing? Radiofly Power Systems 42 Mar 23, 2004 11:15 AM
Wireless camera TX and RX for sale mwilhelm100 Aircraft - Electric - Airplanes (FS/W) 5 Nov 17, 2003 04:51 PM
Can you convert 4ch TX/RX for CP worck Electric Heli Talk 3 Aug 15, 2002 07:04 PM
Wanted: 4 Channel FM Tx + Rx (for Australia) AutoMatt Aircraft - Electric - Airplanes (FS/W) 0 Nov 26, 2001 08:08 PM
